Old 04-22-2010, 09:05 PM   #1
SynerJersey110
SynerJersey110's Avatar
Drives: 2011 2SS BLK, 2010 Synergy Camaro
In Search of LED Rear Bowtie Install Step by Step Instructions
I've been searching the forum, did anybody post a DIY with pics for the rear bowtie LED install? Please help....
SynerJersey110 is offline   Reply With Quote
Old 04-22-2010, 09:07 PM   #2
Orange5thGen
Orange5thGen's Avatar
Drives: 2011 Convert
Send a message via Yahoo to Orange5thGen
Had mine done at Fest by AAC...... Its not hard the longest part was getting the old one off.
Come see me at www.chicago5thgen.com TEAM LLT, , 2011 Covertible 1LT RS, JDM Color Shift Halo's, Showstopper Camaro Bowtie Led Mirrors, Side Markers and Engine Cover, Pace Setter Catback Exhaust, BK Coilover Kit, 21" Full Crome GM wheels, Tinted windows, I WIN BEARS Plate. Full amber ABL dash and door update with IOM interior panels.
Orange5thGen is offline   Reply With Quote
Old 04-22-2010, 09:32 PM   #3
Synergy SATX
Mike and Debbie
Synergy SATX's Avatar
Drives: 2014 Corvette Stingray 3LT Z51
Not much but might help a little. http://www.automotivelightstore.com/LEDbowtie.aspx##
Synergy SATX is offline   Reply With Quote
Old 04-29-2010, 08:27 AM   #4
SynerJersey110
It would be good if AAC could document an install & post pics here. The instructions I got seemed like they were for a Chrysler wing install, not our bowtie
Old 04-29-2010, 01:12 PM   #5
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
They give you instructions...
1) heat stock bowtie
2) cut a good length of dental floss or fishing line and slide it between the bowtie and trunk lid to seperate the bowtie from the trunk. You will have to maneuver around the posts on the back of the bowtie.
3) use rubber wheel or goo-gone and elbow grease to remove remnantsa of 3M adhesive
4) run wires through appropriate hole
5) clean area thoroughly
6) remove red backing from AAC lighted bowtie
7) stick bowtie to trunk lid where old bowtie used to be
8) follow instructions supplied to determine which color wire to connect to vehicle wiring harness
bonus: if you use the dual-intensity circuit and attach the "brake wire" (which I believe is the red wire) lead to the brake wire on the right-hand side of the car, your bowtie will blink with your right turn signal but not with the left turn signal. If this is not desired, you will need to tap into the brake wire for the third brake light that's in the rear deck. This is a little more involved, and access isn't exactly simple. There is a write-up for this somewhere, but you'll have to use the search button to find it because I forgot
If I remember, when I get home I will try to upload the correct istallation instructions that they sent me...
Old 05-27-2010, 03:41 PM   #6
Frojas3440
Yogi
Frojas3440's Avatar
Drives: Cyber Gray 2SS/RS
The 3rd brake light has a white wire (power) and black wire (ground). How would you go about connecting the dual intensity circuit?? I know the single red wire goes to the red wire on the bowtie. But on the other side of the circuit theres another red and an orange wire together. How do i connect those??
Frojas3440 is offline   Reply With Quote
Old 04-14-2011, 09:37 PM   #7
FED728
Drives: Aqua Blue SS
Can you put the bowtie on a switch and if so how would you go about doing it? Thanks in advance.
FED728 is offline   Reply With Quote
Old 04-14-2011, 09:44 PM   #8
KnightRiderSS
Voodoo Medicine Man
KnightRiderSS's Avatar
Drives: Black 2SS with RS package
If you have a 2011 you will have to drill a hole just to warn!
KnightRiderSS is offline   Reply With Quote
Old 04-14-2011, 09:54 PM   #9
FED728
I have a 2010, I just don't understand how to put this on a switch.
Old 04-22-2011, 10:04 PM   #10
anglwngss
Texas Camaros
anglwngss's Avatar
Drives: 2011 Synergy Green 2SS/RS
ah man.. Thanks for the warning, I didn't know that.
anglwngss is offline   Reply With Quote
Old 12-26-2011, 08:59 PM   #11
nikos30
HT5 EastSide
nikos30's Avatar
Drives: 2010 Camaro 2LT
I have the dual circuit...the instructions are black and white and the words are not to specific on what to do. Somebody please help me. pics or a video would be sweet especially for the dual circuit because I cant even find one thing on it on the entire internet.
nikos30 is offline   Reply With Quote
Old 02-14-2013, 07:42 PM   #12
djdredre
Drives: 2012 Camaro 2Ls aka White Night
Exclamation
need help installing too! anyone please?
djdredre is offline   Reply With Quote
Old 02-15-2013, 12:00 PM   #13
nikos30
HT5 EastSide
nikos30's Avatar
I used their instructions..
Old 02-15-2013, 09:02 PM   #14
VFR880
VFR880's Avatar
Drives: 2010 Camaro 2SS, 2009 Avalanche LTZ
You don't have to connect for dual circuit, i just connected mine to tail light circuit, it comes on when lights comes on, i did that install 2 years ago and still lights up! i didn't want to connect it dual circuit (coming on with brake lights) felt it wouldnt last as long!
VFR880 is offline   Reply With Quote
How to remove gold center from rear bowtie SSyanide Cosmetics and Lighting Modification Discussions 20 03-12-2012 07:33 PM
Bowtie Install Clips For Heritage Grille Now Available At CCC! CleanCutCreations Exterior Parts & Accessories 4 04-06-2010 11:58 AM
Colored rear bowtie and truck blackout Tonka Camaro Photoshops / Renderings Forum 2 07-27-2009 12:38 PM
How is the rear bowtie attached? VenomZ302 Cosmetics and Lighting Modification Discussions 4 07-10-2009 10:03 PM
