Old 04-23-2010, 05:59 PM   #1
Andy_10
Drives: 2010 camaro rs ss
Permanently keep DRL's on
Hi, I just brought a U.S. 2010 camaro to canada. In order to pass inspection, the day time running lights must remain on at all times while the car is running. currently there is a switch to turn the DRl's off, how can i disable this switch to keep the DRL's on at all times?
addtitional information: the car trim is RS SS
thanks in advance
Andy_10 is offline   Reply With Quote
Old 04-23-2010, 06:31 PM   #2
strauchpete
Drives: 2010 Camaro 1LT
There are some threads on here about this subject for the RS models look under the DIY area you should find something easy.
strauchpete is offline   Reply With Quote
Old 04-23-2010, 07:19 PM   #3
theone
Drives: 2010 2ss/rs camaro
just keep the switch on auto and the DRL will stay on all the time
theone is offline   Reply With Quote
Old 04-23-2010, 07:57 PM   #4
OUR72GTO
2010 SIM Beige RS 6M
OUR72GTO's Avatar
Drives: SIM RS 6M 66 Corvair Silverado LTZ
Pop the switch out....it is just a friction fit.
Disconnect the green wire with white stripe. Go for your inspection.
Put it back on.
All non factory tint has to be removed from door and front glass.
Your done.
CAMARO.. 2010 The Heart Beat is back in CHEVROLET
Now let's put it back in America
OUR72GTO is offline   Reply With Quote
Old 04-23-2010, 08:56 PM   #5
Andy_10
Alright, poped the switch out and i've got it down to just the connectors. I see which wire i need to disconnect but i am unfamiliar with how to pull the wire out of the "block". Do you just pull really hard to get it out? it seems very secure in there
I could cut the wire and solder it back up but i'd rather try keep things as clean as possible
Old 04-23-2010, 09:16 PM   #6
CaniacFan
CaniacFan's Avatar
Drives: '10 SS CGM #75,288, '14 Stingray
Andy:
Unless I missed something, your DRL will remain on when your car is running if your simply adjust your headlight setting to Auto. Mine are always on in auto mode. Sorry if I misunderstood.
CaniacFan is offline   Reply With Quote
Old 04-23-2010, 09:18 PM   #7
skuttduck
skuttduck's Avatar
Drives: 2010 RJT 2LT Camaro
Send a message via ICQ to skuttduck Send a message via AIM to skuttduck Send a message via Yahoo to skuttduck
I used a paperclip to release the pins for the GM door lamps. I'm thinking you could probably do the same thing.
Also let us know if this allows the daytime running lights to be on the same time as the halos.
skuttduck is offline   Reply With Quote
Old 04-23-2010, 09:32 PM   #8
Becca
Frog
Becca's Avatar
Drives: 2011 Camaro 2SS/RS
You could cut the wire with space on both sides to put a male and female electrical fitting so u can connect and disconnect as needed with out needing to continuing to cut and splice everytime inspection time comes.
I'm not speeding....
.... I'm qualifying
IYAAYAS
Becca is offline   Reply With Quote
Old 04-23-2010, 09:36 PM   #9
Andy_10
Andy:
yes, the DRL's will automatically come on when the lights are on auto mode, but they can be turned off, which in turn is illegal in canada. they must remain on at all times without the possibility of them being turned off.
Old 04-23-2010, 09:50 PM   #10
OUR72GTO
OUR72GTO's Avatar
Just push a small screw driver in to release the wire inside the connecter..
This will only be inspected once.
Old 04-25-2010, 08:33 PM   #11
Andy_10
okay that worked for getting the wire out. there wasn't actually a dark green and white striped wire, but i looked up the pinout and pulled a turquoise wire. now when the car is started the DRL's come on automatically, next position turns on only halo's and 3rd postion turns on halo's plus low/high beams. rotating the switch to the left does nothing (the DRL's stay on)
now we'll see if the car passes inspection, thank you to everyone for your input
Old 05-01-2010, 02:18 AM   #12
OUR72GTO
OUR72GTO's Avatar
Did you pass?
Old 05-01-2010, 11:49 AM   #13
Jay2SS109
Redemption
Drives: .
Jay2SS109 is offline   Reply With Quote
Old 05-02-2010, 04:51 AM   #14
OUR72GTO
OUR72GTO's Avatar
The US cars allow them to be turned off......While the car is in motion.
Ours are not built that way so if we import a US model the switch needs to be defeated.
DIY-Wired DRLs with switch to have full control over DRLs IROCanSS Cosmetics and Lighting Modification Discussions 33 04-13-2015 10:27 PM
DRLs that match headlights? TaylorRyanSS Cosmetics and Lighting Modification Discussions 5 03-12-2010 09:52 AM
Running foglights and halos simultaneously? novajess1972 5th Gen Camaro SS LS LT General Discussions 56 02-24-2010 11:34 AM
K I have a weird problem with my 2ss 2010CamaroOutlaw 5th Gen Camaro SS LS LT General Discussions 45 10-25-2009 12:35 PM
Where are the DRL's? Captain Awesome Cosmetics and Lighting Modification Discussions 42 11-19-2008 02:26 AM
