Old 05-01-2010, 11:34 PM   #1
Rupe24
Rupe24's Avatar
Drives: 2010 Camaro 2LT
Rear Park Assist Shuts Off
I could not find anyone on here that had a similar problem with the rear park assist, so here it goes.
When I put my car in reverse, the beep noise works (for the rear park assist), then as I start rolling backwards, a digital message pops up on the dash saying "Rear Park Assist OFF." This seriously isn't cool because I found this out by backing up in a parking garage spot and waited for the beeps (and they never happened). I almost hit the wall !!
I then went into the Configuration settings and checked to see if Rear Park Assist is ON, and it is ON.
Just a note...This happens every single time I put my car in reverse, and my Rear Park Assist worked for the first 2000 miles, and now my camaro has 3500 miles. I thought it might just jump back to working again, but it hasn't.
Any ideas, solutions!! If not I will obviously go to my dealership to check it out. Somehow since there isn't any issues on this yet (from what I have seen), then even the dealership won't know how to fix it.
Rupe24 is offline   Reply With Quote
Old 05-02-2010, 09:22 PM   #2
gtjacket
2G1FT1EW0A9118618
gtjacket's Avatar
Drives: 2010 Camaro 2SS Black/IOM M6
What is this rear park assist you speak of?
1100, Preliminary order accepted 12/5
2000, Order accepted by GM 05/05
3000, Order accepted by production control 05/05
3400, Order broadcast 6/4
3800, Order produced 6/15
4000, Available to ship 6/16
4104, Bailment Invoice
4200, Shipped 6/19
6000, Delivered to the customer 6/25
2SS/RS BLK M6 GFX IOM interior
gtjacket is offline   Reply With Quote
Old 05-02-2010, 09:37 PM   #3
Rupe24
Rupe24's Avatar
Rear Park Assist is the correct name for the Backup Sensors that beep when in reverse, letting me know if I am close to a car or wall behind me.
Old 05-06-2010, 08:51 PM   #4
Rupe24
Rupe24's Avatar
Bump...
Anyone
Old 05-06-2010, 09:16 PM   #5
Sterling
Sterling's Avatar
Drives: 2010 Camaro 1LT/RS M6
I haven't heard of anyone having this issue yet. I'd take it to the dealer and have them check it out.
Sterling is offline   Reply With Quote
Old 05-07-2010, 12:17 PM   #6
dealer issue
Old 05-10-2010, 01:42 PM   #7
blkngldbabe
Barossa's handler
blkngldbabe's Avatar
Drives: 2LT/RS RJT
MIne beeps out of control when I'm still several feet away. Are you lightly on the gas or just rolling backwards?
SLP's GTA Master Specialty Vehicle and Master Parts Dealer
blkngldbabe is offline   Reply With Quote
Old 05-11-2010, 09:47 PM   #8
Rupe24
Rupe24's Avatar
It doesn't matter if I push on the gas or let the car roll backwards, the message of "Rear Park Assist Off" comes on when I put the car in reverse.
No beeps for me.
I am taking my camaro to the dealership to see what the hell this is, since I am obviously the only one who is experiencing this particular problem.
Old 10-08-2013, 04:48 PM   #9
bngummow
HT
bngummow's Avatar
Drives: Camaro SS
No beeps for me.
Did you ever figure out the problem? This same exact thing is happening to me now. I have an amp as well as some aac brake light halos and my assist stopped working about a month after installing the brake light halos. Also, when i go to the settings and try to turn backup assist on, it will not swith to on.
bngummow is offline   Reply With Quote
Old 10-08-2013, 05:21 PM   #10
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
Mine stopped working and I would get "service park assist" when out in reverse. Turns out a sensor had failed.
Caswell239 is offline   Reply With Quote
Old 03-13-2020, 09:32 PM   #11
knined4
Drives: Chevy Camaro
I'm having the same issue. I replaced the reverse light with LED lights and now the park assist and the reverse lights are not working. Need help?
knined4 is offline   Reply With Quote
Old 07-10-2021, 04:36 AM   #12
Nokke
Drives: Camaro SS 2010
No beeps for me.
Did You solve this? I have same problem...
Nokke is offline   Reply With Quote
Park Assist Retrofit Kocomo 5th Gen Camaro SS LS LT General Discussions 3 03-10-2020 09:34 AM
