Old 05-03-2010, 04:16 PM   #1
RJT
Drives: LT CGM
Need in depth AAC footwell DIY
I've seen the threads on this, but I'm a complete novice when it comes to taping into wires and such.. so they seem a bit like gibberish to me..
I don't want my footwell lighting tapped into the dome light, I want it to be a stand alone light that is controlled by this switch :
http://www.automotivelightstore.com/...ingswitch.aspx
Can anyone send me a PM with detailed instructions on how to do this mod? including how to take off panels and such.. Never done a mod or a wire tap etc.. so idk what pieces/wires/terms all mean or where to get the tools i'll need..
Would be greatly appreciated
RJT is offline   Reply With Quote
Old 05-03-2010, 07:05 PM   #2
iwanttogofastNY
iwanttogofastNY's Avatar
Drives: 2010 Camaro 2SS/RS ABM
pretty sure someone has already put this up in the DIY section........
2SS/RS/M6 | ABM | White Stripes | Black Int
Mods: American Racing Headers & Exhaust, Airaid Intake, Pfadt Front/Rear Sway Bars, Stealth Bulbs, AAC LED bowtie, AAC Concept LED Side-markers ABM/Tinted, 20% Tints, Chuck COW Tune, MGW shifter (blue with white racing stripes).
Coming Soon: 4:10 Gears?
iwanttogofastNY is offline   Reply With Quote
Old 05-03-2010, 07:07 PM   #3
iwanttogofastNY
yep there are a bunch here is one
http://www.camaro5.com/forums/showthread.php?t=54183
Old 05-03-2010, 09:48 PM   #4
RJT
Drives: LT CGM
I've seen this one, but he dives into a lot of things I've got no experience with.
For example, I don't know where to get a T-Tap or how to connect them, etc..
What tools do I need in order to do this?: "stripped them, crimped on a spade/ring terminal"
Need clarification on this part.. "I attached the t-tap mating terminal to a fuse holder,"
Also, he taps into the dome light.. I mentioned I don't want to do this. I want the light to be tapped into a wire that I can turn on/off.
Also, I want to have it controlled by the LED switch I provided a link to.. All of which are not explained in that DIY.
Old 05-03-2010, 10:06 PM   #5
rmnc3r
Drives: me up the wall.
Well,
as I tell a lot of 'electricians': If ya can't read a wiring diagram, ya shouldn't play with electricity; it's too dangerous. You might fry something, or worse, fry yourself.
BUT, since we are talking 12V here, there's not too much danger. Google will be your friend here to learn about such basics as 'ground' and 'hot' and 'butt connectors' and
'crimping' 'T-Taps'. The most daunting part to me is removing the panels without breaking something
Also, use the search function, search titles only, 'footwell' and you will find
several threads. Read them all, something not covered in one, may be explained in another.
Rotsa ruck, G.I. !
rmnc3r is offline   Reply With Quote
DIY - Footwell LED lighting In tune with Dome Light markmass Camaro DIY & HOW-TO instructions & discussions 52 09-03-2010 08:00 PM
AAC Footwell lighting questions RJT Cosmetics and Lighting Modification Discussions 6 05-02-2010 12:24 PM
In regards to AAC footwell lighting Winslow Cosmetics and Lighting Modification Discussions 10 04-29-2010 07:43 AM
Switchplate+lots of AAC lights assistance... TRSS2 Cosmetics and Lighting Modification Discussions 13 03-27-2010 10:31 PM
Footwell And Foglight Installation question. xpanda305x Cosmetics and Lighting Modification Discussions 5 03-03-2010 08:34 PM
