Old 05-05-2010, 01:30 PM   #1
JoeKay
Drives: Red Jewel Tintcoat 2SS
Tap Shift Related Questions
Hello All,
I have a few questions all related to Tap Shift (Sport Mode) in the 2SS V8.
1) I noticed I can launch from 3rd gear (from a dead stop). Is the computer supposed to allow this? Can this be harmful to the transmission?
2) Can you shift between 'D' and 'M' (Sport Mode) and vice versa when the car is moving ? If so, are there any speed or load thresholds at which this should not be done?
3) Is AFM (Active Fuel management) present in both modes 'D' and 'M' ? or does it work only in 'D' ?
Thanks in advanced..
Joe
JoeKay is offline   Reply With Quote
Old 05-11-2010, 08:31 AM   #2
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Originally Posted by JoeKay View Post
Hello All,
interesting ... I knew it could start from 2nd but not 3rd.
switching between modes isn't a problem. It just takes the control away from the computer or gives it back.
Joe
I don't think its disabled in manual or sport mode
reply in bold
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 05-11-2010, 11:07 AM   #3
Scott@Bjorn3D
Actually if you use the paddles to shift, AFM does get turned off. But putting the car in sport mode it does not.
Scott@Bjorn3D is offline   Reply With Quote
Old 05-12-2010, 04:51 PM   #4
SonnyakaPig
Drives: C63 P31
I wish GM would make a list of details available for the 6L80 for its use in Camaro.
So many people have these questions, and it would be nice to hear detailed answers from GM.
SonnyakaPig is offline   Reply With Quote
Old 05-12-2010, 05:08 PM   #5
Good to know, damn AFM
Old 08-24-2010, 09:57 PM   #6
VictoryMuscleCars
VictoryMuscleCars's Avatar
Drives: 2012 Camaro SS RS Convert
Totally agree! I am finding some really good info on tap shifting here on Camaro5, but still would be nice.
Tom P
VictoryMuscleCars is offline   Reply With Quote
Old 08-25-2010, 01:30 AM   #7
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
They wont. Most people ordering the slushboxes are gonna slap it into D and floor it. Only the certified car nuts like us will find out all the details.
9/26/09 Took delivery!
Old 08-25-2010, 02:10 AM   #8
KeepItGreasey
So It'll Go Down Easy
KeepItGreasey's Avatar
Drives: Camaro SS/RS
Hello All,
Joe
#1 - the computer will not allow a manual gear shift if it is not "proper". i believe the car will automatically up-shift as well if you're red-lining the engine for too long.
#2 - the car will act as if it is in "D" until the tap shifters are used while it is shifted into "M". at that point, the computer will not allow you to make any improper gear shifts, such as, slamming it into 1st gear while rolling at 55mph... or, shifting into 6th while rolling at 15mph.
#3 - AFM is indeed active in both "D" and "M". i have a Camaro that has suffered from a string of defects, one of which being a very noticeably jumpy and noisy shift between v4 mode and v8 mode when re-applying pressure to the accelerator after coasting. i can just as easily duplicate the AFM "symptoms" in "M" while using paddle shifters as i can in "D".
i think you're wrong... or, maybe it's just that my car is screwed up.
but think of it this way...
why are you engaging "M" and using the paddle shifters? because you want to drop it into 1st gear and make a quick take-off.
when you're in "D", you automatically take-off in 2nd gear. and if you're punching it, or attempting to accelerate at all, you will be in "v8 mode" anyway. after all, this is the concept of AFM engines - 8 cylinders firing when power is needed; 4 cylinders firing when you're coasting or the engine is under very little strain while maintaining the current speed.
KeepItGreasey is offline   Reply With Quote
Old 08-25-2010, 06:30 AM   #9
CFD
Drives: 2SS/RS L99 BLACK
I believe you are correct in the car taking off in second when in "D". One of my very first posts was about this but most said it was not true, if not my car is screwed up like yours.
CFD is offline   Reply With Quote
Old 08-25-2010, 11:05 AM   #10
StlRomAniaN
StlRomAniaN's Avatar
Drives: IOM 2010 Camaro 2SS/RS
In manual mode, the car won't upshift until you upshift, period. No matter how long you're bouncing off the limiter.
StlRomAniaN is offline   Reply With Quote
Old 08-25-2010, 01:23 PM   #11
KeepItGreasey
yup, that's why the 2nd gear "D" take-off doesn't have half the kick that 1st gear "M" take-off does.
yeah you're right, just read through that section in my manual.
APPARENTLY... switching into "M" without using the tap shifters does affect the auto-transmission shifting habits, keeping it geared lower and shifting stronger to increase performance - learn something new everyday with this car.
and no, it wont automatically up-shift no matter how long you're bouncing off the limiter. i honestly thought i read it somewhere. seems like a good safety feature... good way to keep from screwing up your engine by trying to attain freeway speeds in 1st gear.
tap shift
DIY Raptor Dual Stage Shift Light. ThunderSS Camaro DIY & HOW-TO instructions & discussions 47 05-27-2019 08:48 AM
Manual shift - 1-4 ? calflan V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 27 01-19-2015 10:39 PM
V6 Questions I'd Like Answered The_Blur Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 36 07-14-2012 10:44 AM
Did Camaro (automatic) reviewers use tap shift ? trudawg660 5th Gen Camaro SS LS LT General Discussions 30 11-09-2010 07:55 PM
ice-t has some questions for you (transformers related) CamaroSpike23 Off-topic Discussions 0 07-06-2008 08:34 PM
