Old 05-08-2010, 09:24 PM   #1
hooded
Drives: 2012 Zl1 Camaro
Found over 25% Leakage out of cylinders 1,2,6,5 and 7
Went into the dealership with the AC not blowing cold air, and talked about a minor surging I had since I first bought the car 2SS/RS. They found the leakage through the exhaust valves. Anyone else have this problem? Or I'm I the only lucky one?
hooded is offline   Reply With Quote
Old 05-08-2010, 09:34 PM   #2
Red Jewel RS
Red Jewel RS's Avatar
Drives: 2010 Camaro 2SS
What kind of "surging" do you mean? Under acceleration or maintaining your speed?
I noticed mine when under acceleration it surges a little under around 5 grand and then it sets you back. I am assuming this is normal? LT1/RS
Red Jewel RS is offline   Reply With Quote
Old 05-08-2010, 10:27 PM   #3
hooded
It was only at idle. It was very minor didn't really seem to effect power during acceraltion.
Old 05-09-2010, 09:19 AM   #4
Eric Baker
Drives: Black/Black 2SS/RS 6M
You sure you don't just mean the cam lope? It's normal for the engine to rumble and shake a little while at idle, some may think the engine is missing/skipping/surging.
Eric Baker is offline   Reply With Quote
Old 05-09-2010, 09:36 AM   #5
joelster
joelster's Avatar
Drives: '94 Z28+ '15 Z/28
Is your car a 6-speed or is it an auto?
joelster is offline   Reply With Quote
Old 05-12-2010, 08:54 PM   #6
O2BQIK
Drives: 1991 Camaro RS
Dude, he said the dealer found exhaust valves leaking...doubt they would tell him that if there was nothing wrong
O2BQIK is offline   Reply With Quote
Old 05-12-2010, 08:58 PM   #7
ron10
Drives: 2010 2SS IOM L99
what all are they going to replace?
Old 05-12-2010, 09:08 PM   #8
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
vin ?
Old 05-12-2010, 09:42 PM   #9
HeaterMan
HeaterMan's Avatar
Drives: 2018 PP GT
I'm surprised how many of the guys here assume a rough idle is cam lope. cam lope is consistent and is a reflection of the cams duration and overlap. i highly doubt GM installed a cam in these cars with that kind of overlap which would affect emmisions. also overlap and duration tend to reduce engine vacuum at idle. a car with a big cam will have an even rythm in the idle and will be more pronounced when the engine is cold although fuel injection should compensate for that. these cars do not have a big cam. I have a casm in my 455 which has 238*/248* @.050 and it has a lope.
HeaterMan is offline   Reply With Quote
Old 05-12-2010, 09:57 PM   #10
hooded
The car is a M6. They removed cylinder heads and took them to the machine shop. Reinstalled and found my idle to be much better. ALso the climing through the RPMs on full acceleration is much smoother.
Old 06-02-2011, 05:23 PM   #11
CyberDan
CyberDan's Avatar
Drives: 1SS Camaro
Mine does this also, is this supposed to be normal?
CAI Cold Air Intake, VMax CNC TB, Borla Sport Catback Exhaust, EE Oil Catch Can, Eibach Sway Bars and Drop Springs, AAC concept side markers, stealth signal bulbs, Heritage grille, Sparks Restorations front and rear modern SS emblems
CyberDan is offline   Reply With Quote
Old 06-02-2011, 06:32 PM   #12
ffrcobra_65
cool dealer! they hooked you up!
Old 06-02-2011, 08:40 PM   #13
SC2150
Heater is right on.
The dealer is truely outstanding....VERY impressed. Was the car tuned? Very unusual for a new motor to have leaking exhaust valves...especially that many unless there was a lapping & assy error. A tune gone wrong can burn exhaust valves/pistons but they would have seen that w/the heads off. Wonder if there is a certain run of heads w/this issue.....
Old 06-03-2011, 09:51 PM   #14
greenmachinedriver
greenmachinedriver's Avatar
Drives: white 2010 ss and 2011 6.2 silvy
every manual trans ls3 owner i know has comented on the rough or unstable idle, i think it may be normal. mine also does. your dealer really went above and beyond for you which is great.
greenmachinedriver is offline   Reply With Quote
P0300 Misfire Code Help black-knight 4th Generation Camaros 4 02-08-2010 01:45 PM
