Old 05-12-2010, 12:07 PM   #1
camaro789
Drives: Camaro
Exclamation v6 Automatic Rear Axle fluid ?
Can V6 Automatic Rear Axle use Mobile 1 Rear Differential Fluid 75W-90 LS ?
the manual says Mobile 1 Rear Differential Fluid 75W-90 without LS
thanks a lot !
camaro789 is offline   Reply With Quote
Old 05-12-2010, 02:26 PM   #2
zen
Drives: 2011 CTS CPE & 2010 2LT/RS CGM
I presume the "LS" is for limited slip differentials. It has a "slippery" additive added. Should be ok for any differential.
zen is offline   Reply With Quote
Old 05-13-2010, 01:02 AM   #3
camaro789
Drives: Camaro
Yes,"LS" is for limited slip differentials,anyone used LS on v6 at ?
Old 05-13-2010, 03:08 AM   #4
camaro789
Drives: Camaro
anyone knows ?
Old 05-13-2010, 05:16 AM   #5
Not Paid 4
Not Paid 4's Avatar
Drives: The Wheels of this BEAST...
Location: You must be Young and Stupid before you become Old and Wise, Canton Georgia
Forget Mobil One and Switch to Amsoil. Checkout there web site it is very helpful. I think there Severe Gear has the additive in it, but check it out. Don't be afraid to call them either because you will get a Tech on the phone with answers.
Not Paid 4 is offline   Reply With Quote
Old 05-13-2010, 10:08 AM   #6
2010 Bumblebee
2010 Bumblebee's Avatar
Drives: Transformers Edition Camaro 2SS/RS
If you read the bottle on mobil 1 is says speciall formulated for LS differentials and if you need additive that you still may need to add it in. That's why I didn't buy it. It was too confusing.
A V-6 auto has a regular diff and a V-6 manual has a LS diff if I'm correct.
So you would put regular or synthetic 75w-90 gear lube in without any additive.
The Yellow Camaro Club
http://www.camaro5.com/forums/group.php?groupid=128
Northern Massachusetts & Southern New Hampshire Camaro Club
http://www.camaro5.com/forums/group.php?groupid=127
The mother of all supercharger questions thread
http://www.camaro5.com/forums/showthread.php?t=77958
My 2010 Camaro Review
http://www.camaro5.com/forums/showthread.php?p=2025442#post2025442
2010 Transformer Edition Camaro L99 Auto
2010 Bumblebee is offline   Reply With Quote
Old 05-13-2010, 11:09 AM   #7
John VS
John VS's Avatar
Drives: 2010 Camaro 2LT CGM, IOM Int.
I replaced mine with Amsoil Severe Gear 75w-90.
John VS is offline   Reply With Quote
Old 05-13-2010, 06:48 PM   #8
FastOil
Drives: none
Yes severe gear already is LSD ready,,, if you are running higher horsepower and launching the car and racing, we reccomend 75W110 or 140 and we also have the additive for these
FastOil is offline   Reply With Quote
Old 05-13-2010, 10:17 PM   #9
camaro789
Drives: Camaro
hwo about MOTUL GEAR 300 75W90 ?
Old 05-14-2010, 12:54 AM   #10
camaro789
Drives: Camaro
waiting
Old 05-14-2010, 05:22 PM   #11
FastOil
Drives: none
Motul is pretty good fluid, i would get Redline over them.
Clicking sound from rear axle multiSS Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 80 07-06-2015 05:57 PM
rear differential fluid drain/fill plug location Dentyneice Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 9 11-27-2010 11:54 PM
Mustangs................ vontivonti 5th Gen Camaro SS LS LT General Discussions 4051 12-21-2009 11:42 PM
Help!!! Hearing a Strange Noises from rear end of V6 6 speed Bigred1981 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 10-17-2009 12:18 PM
