Old 10-15-2008, 08:25 PM   #1
domano 68
domano 68's Avatar
Drives: 2014 1LE
Tic-toc console gauges
Is it true that the 4 "classic" first gen gauges only come on the 2SS package? TIA
domano 68 is offline   Reply With Quote
Old 10-15-2008, 08:31 PM   #2
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Drives: 2010 1SS:RS:LS3:SW
2LT and 2SS only yes...
BUT they will be available as a part from the dealer for installation on any model.
A.K.A - Diarmadhi (old handle) - So much to do.. So little money
Owner : Fast-Stache Industries LLC
The_Stache is offline   Reply With Quote
Old 10-15-2008, 08:36 PM   #3
RallyFever
Senior Member
RallyFever's Avatar
Drives: 2010 Camaro 2SS
Will the car be pre-wired for the gauges or will the dealership need to install the appropriate wiring/sensors?
RallyFever is offline   Reply With Quote
Old 10-15-2008, 08:50 PM   #4
FenwickHockey65
General Motors Aficionado
FenwickHockey65's Avatar
I think they'd need to wire them, since the alternative to the gauges is a storage bin.
2023 GMC Canyon Elevation
Old 10-15-2008, 10:19 PM   #5
The_Stache
SoCal Race Team #13
The_Stache's Avatar
Actually they wiring harness is already in place, same with the sensors. The gauges just tie into the harness, but if not installed the plugs just get hidden behind panels.. this is almost the same with ALL factory options (fog lights, aux power outlets etc..) The reasoning is that you only need 1 harness then, you just don't install the additional hardware. this saves on costs because there is only 1 to keep track of for quality checks and installs.. no wrong part to install.
Old 10-15-2008, 11:02 PM   #6
srtclg1007
srtclg1007's Avatar
Drives: 08 C6 NPP, MZ6 436hp
This is very good news. Do ya'll think there will be any other 2SS options I could put on my 1SS later on???????
srtclg1007 is offline   Reply With Quote
Old 10-15-2008, 11:05 PM   #7
FenwickHockey65
Hmm...that's interesting. So if you wanted to install the gauges sometime down the line, you could just remove the panel and plug them in?
Old 10-15-2008, 11:08 PM   #8
headpunter
Not That sad..considering
headpunter's Avatar
Drives: Man
Location: the part of washington the capital forgot about.
Send a message via AIM to headpunter
correct.
headpunter is offline   Reply With Quote
Old 10-15-2008, 11:13 PM   #9
GamerGuyZ28
5TH GEN BURNOUTS!
GamerGuyZ28's Avatar
Drives: 95 Z28, and a 2000 Z28
Dumb question alert... what do the 4 gauges have, i know one is torque, but is it live torque output at the shaft?
GamerGuyZ28 is offline   Reply With Quote
Old 10-15-2008, 11:34 PM   #10
camaro5's Avatar
Drives: X-15 Velocipede
It's cost effective to wire everything on every unit, regardless of actual options present.
Usually, these accessories will come with do-it-yourself instructions, including electrical connections.
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 10-15-2008, 11:35 PM   #11
camaro5's Avatar
The Torque gauge is now trans temp. I'll let GM explain.
Volts
Oil Press
Oil temp
STANDARD DISCLAIMER
Old 10-15-2008, 11:38 PM   #12
GamerGuyZ28
5TH GEN BURNOUTS!
Man that would have been sweet though, to have live torque output shown.
Old 10-15-2008, 11:40 PM   #13
camaro5's Avatar
Something went wrong, or toque is not PC when pushing the V6?
STANDARD DISCLAIMER
Old 10-15-2008, 11:42 PM   #14
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
You can get one in aftermarket.
http://www.jegs.com/p/G-Tech/758772/10002/-1
1SS Gauges 69 rs/ss 5th Gen Camaro SS LS LT General Discussions 13 10-16-2008 08:20 AM
Production console gauges found fastball Camaro Photos | Spyshots | Video | Media Gallery 13 10-04-2008 09:54 PM
