Old 05-21-2010, 01:22 PM   #1
fargomike
The Dude Abides
fargomike's Avatar
Drives: Black 2SS M6
Body Rattle ?
So here is what a guy in town here (Fargo ) told me when I asked him about options .
" Called a few in town and nobody will touch the camaros and they do not recommend after market exhaust/catback systems because you end up with a body rattle after it's installed and headers he said are a whole other story. he has 2 friends with the new camaros that put catbacks on and the 1 has had it back to gateway several times for the rattle and they told him its the catback and that is why they do not recommend after market exhaust installation on them. another freind installed a catback and ended up taking it back off and sending it back because of the rattle "
What is he talking about ?
fargomike is offline   Reply With Quote
Old 05-21-2010, 01:27 PM   #2
camarowa
camarowa's Avatar
Drives: 2013 SVT Raptor, sold 2010 Camaro
aftermarket exhaust might touch (causing a rattle) on the oem tunnel brace. Nothing a few extra washers or an aftermarket brace can't fix.
- Pfadt Suspension Package; Springs & Sways
- Brembo Brake Upgrade (Yellow); Courtesy Fesler Built
- Custom Magnaflow Exhaust
- Blacked-Out Bowties & RS Emblems, Front bowtie delete
- Full Dynamat Extreme Trunk Coverage
- Tinted side markers
- Interior DSV Customs Leather Upgrades
- Airaid CAI V2
- Forgestar F14 Gunmetal 20x9, 20x11
- Doug Thorley Shorties
camarowa is offline   Reply With Quote
Old 05-21-2010, 01:28 PM   #3
SikMaro
SikMaro's Avatar
Drives: 2004 CTS, Arrived! 2ss/rs ABM!
when you put on some full cat back exhaust systems the pips are lower than stock usually so when you go over a bump the exhaust pipse move and hit the cross member brace and you get a rattle. you can either raise your exhaust with a little cutting or you can put bigger spacers on the cross member brace to space it more so it doesn hit. i had the same problem and i went with option b and just put spacers
2010 Camaro 2SS / A6 / Aqua Blue Metallic / Gray Int. / Sunroof / NPGB4Q / 2G1FK1EJ6A9160475
1100 - 09-24-09 1st Step
3800 - Born 10-27-09
6000 - 11-11-09
SikMaro is offline   Reply With Quote
Old 05-21-2010, 01:44 PM   #4
fargomike
The Dude Abides
fargomike's Avatar
Gotcha , so hello new tunnel brace ?
Old 05-21-2010, 01:48 PM   #5
djsnoflake
Faith Keeper
djsnoflake's Avatar
yeah, the 'big problem' can be solved with about 2 bucks worth of longer bolts and some washers
Old 05-21-2010, 02:01 PM   #6
bmbbl be
bmbbl be's Avatar
Drives: 2010 CAMARO SS
i have the solo mach x and had a rattle ,,,,but it was something i overlooked on the install.....took 15 minutes to fix.
bmbbl be is offline   Reply With Quote
Old 05-21-2010, 06:01 PM   #7
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Make sure you pick a tunnel brace that is designed to drop down in the exhaust pipe area. I believe there are several TB's out right now and some do, while some don't.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 05-22-2010, 05:46 PM   #8
Don O
Camaro and Vettehead
Don O's Avatar
Drives: 2SS/RS IOM L99 69 427/400 Vette
See this post for the brace. Just bought one since I put on a Magnaflow cat back last week and have the rattle.
http://www.camaro5.com/forums/showthread.php?t=83336
Don O
Nothing sucks more than that moment during an argument when you realize you're wrong.
Don O is offline   Reply With Quote
Old 05-22-2010, 05:55 PM   #9
JSC81
JSC81's Avatar
Drives: 2010 1SS/RS M6
Just the answer I was looking for! I just installed Flowmaster AT's cat back and I knew what the rattleing was since I put it on myself. Its sitting directly on top of the tunnel brace, just enough to catch some vibration and rattle.
JSC81 is offline   Reply With Quote
Old 05-22-2010, 07:14 PM   #10
Gnarlygianni
Gnarlygianni's Avatar
Drives: Black Camaro 2SS
had the same problem the guy who installed just bent the brace so it had a curve in the middle. doesn't look half bad.
Gnarlygianni is offline   Reply With Quote
Old 05-23-2010, 02:02 AM   #11
axis
Search Ninja
axis's Avatar
That defeats the purpose of the brace though. That brace isn't rigid but it doesn't have to be since it's there to stop lateral movement. Now that it's bent, it can bend more with lateral movement.
Halltech CF 102 fed
Old 05-23-2010, 07:59 AM   #12
Andrew@SPItuning
Andrew@SPItuning's Avatar
Drives: 2010 SS
MBRP systems come with a new tunnel brace - no rattle. Sounds to me like the biggest problem with aftermarket exhaust systems is the installers not the manufacturers.
Andrew@SPItuning is offline   Reply With Quote
Want to run a 102MM throttle body on your Camaro? IPS Brandon Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 09-11-2016 02:07 PM
Ported throttle body sale matt d. V8 Bolt-Ons & Tunes 3 11-24-2009 12:11 AM
MDinduction- $165.00 Ported throttle body matt d. V8 Bolt-Ons & Tunes 13 11-01-2009 09:28 AM
Hardcore racers rejoice!! GM Performance Parts to offer new Camaro body in white radz28 5th Gen Camaro SS LS LT General Discussions 23 12-22-2008 09:57 AM
