Old 05-24-2010, 02:43 PM   #1
2010LS
2010LS's Avatar
Drives: 2010 LS
IAT relocation
Did the relocation, I put it in the snorkel on the fender side away from the radiator and fans. This really reduced my IAT readings on the dashhawk, and when the car heatsoaks, it almost instantly gets back close to ambient, but I'd discovered something else. Has anyone else using the dashhawk noticed some wacky ambient readings thru the dashhawk after the mod? Pre-mod, my ambient readings thru the DH were usually a bit lower then what the radio is saying, like 5 degrees or so. I just chalked it up to the DH probably getting it's feedback from a different sensor then the radio. After the mod, I'm getting pretty low readings, like today for example the radio is saying 82, my IATs are around 72 and the ambient thru the DH has said as low as 59? The car feels good and runs good, but that seems a bit off to me. Anybody have any ideas?
2010LS is offline   Reply With Quote
Old 05-24-2010, 03:43 PM   #2
devildoc
devildoc's Avatar
Drives: '12 Toyota Tacoma Dbl
Does the same thing to me. No clue!
STANDING 1/4MI: 13.948@99.87
6600RPM HP/TQ Gains - 30.54HP/24.3TQ (NOT PEAK)
devildoc is offline   Reply With Quote
Old 05-24-2010, 04:05 PM   #3
RedJewel2SS
12.23s@113mph
RedJewel2SS's Avatar
Drives: 2SS/RS, A6, just a few bolt ons
dry ice hidden in your intake
RIP Cammie 7/15/2009 - 4/1/2011
RedJewel2SS is offline   Reply With Quote
Old 05-24-2010, 08:07 PM   #4
mrray13
Drives: 2010 1LT RS Rally Yellow
I never used my DashHawk for the ambient, left that up to the car, lol.
mrray13 is offline   Reply With Quote
Old 05-25-2010, 01:37 PM   #5
2010LS
2010LS's Avatar
Drives: 2010 LS
sensor
give it a try, they must reference a different sensor, cause the readings will be different. Post relocation, the readings are drastically different. Moving in clean air, my ambient is reading in the high 50s, low 60s, while ambient via the radio and actual is in the 80s. Somehow, after adding the new sensor, the voltage to the ambient sensor must be effected.
Old 05-25-2010, 01:52 PM   #6
mrray13
I'm back at factory location with my IAT for now. Although performance seems to have suffered. I'll give the DashHawk a look see with the ambient air temp though!
Old 05-25-2010, 02:51 PM   #7
devildoc
devildoc's Avatar
Yeah my AAT is at 47 right now and the car shows 73, lol.
Old 05-25-2010, 03:31 PM   #8
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Interesting... few times I checked mine, like in the morning before even starting the car, all three temps would agree, IAT, AAT and Radio...
I now that my IATs would drop below the Radio Ambient... I was concerned at first, but everything I read said IAT sensors aren't particularly accurate....
Seems odd the AAT sensor would be tied the IAT sensor... unless it uses the IAT sensor as a reference point...
scrming is offline   Reply With Quote
Old 05-25-2010, 03:35 PM   #9
devildoc
devildoc's Avatar
Could be? As long as it runs I don't care!
Old 05-25-2010, 04:20 PM   #10
2010LS
2010LS's Avatar
Drives: 2010 LS
runs
I agree that I don't understand it as well. What I initially wondered, is if the new IAT was showing too cool a temp vs real ambient, would the engine be tricked into adding a bunch of timing thinking it was cool, and then knock it's @ss off, but I have done some wide open runs when I'm reading cooler IATs then the radio is saying, and it isn't particularly pulling a bunch of timing, pretty much like before. It will bounce between 0 and 1 degree of retard, with the occassional bounce to 3 and back to 0. But I am running 87 octane currently so that seems about normal.
Old 05-25-2010, 04:30 PM   #11
scrming
scrming's Avatar
Pretty much what I found as far as pulling timing... so to me it was all good...
Old 04-13-2011, 11:31 AM   #12
tony312
new comer
tony312's Avatar
Drives: 2011 camaro v6 1lt rs
Can you guys tell me what I need too do the reelection?
tony312 is offline   Reply With Quote
Scrming's Injen Intake - Install and Info scrming Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 242 06-15-2014 04:43 PM
Hose relocation kit brooks35 V8 Bolt-Ons & Tunes 1 05-24-2010 11:00 PM
Did the air relocation mod.... MaddawgXXXL Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 44 05-23-2010 12:25 AM
v6 CEL, shorties, IAT relocate, Flowmasters mrray13 Tuning / Diagnostics -- engine and transmission 12 01-13-2010 05:17 PM
ADM Race Intake IAT Test (VIDEO AND SCAN LOG - STEP INSIDE) freemaSSon Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 27 11-16-2009 06:50 AM
