Old 05-26-2010, 03:19 PM   #1
Badger
Badger's Avatar
Drives: 2010 ABM SS #14 of 2,027
Broken Valve stem????
Well my car is in the shop for a stage 2 cam upgrade and tune....I already had Kook's LT's and full exhaust on with the STOCK tune...and a CAI....my baseline was 425rwhp....My guy starts the install and when removing one of the rocker arms he finds a broken valve stem in the tip area...He says he has never seen this and it just should not happen..Now the fun part to deal with the General for warranty work...He said I probably would have never known as it was still holding together...in a way I'm glad I went in for this upgrade or it may have been an issue down the road....I just hope I don't get a run around from GM on the warranty...I do not race this car but I do some spirited driving on occasion..I'm guessing a bad valve from the factory?? anyone else seen this at all??
"One of the ordinary modes, by which tyrants accomplish their purposes without resistance, is, by disarming the people, and making it an offense to keep arms."
-- Constitutional scholar and Supreme Court Justice Joseph Story, 1840
Badger is offline   Reply With Quote
Old 05-26-2010, 03:36 PM   #2
FB3
FB3's Avatar
Drives: 2014 Camaro 2SS RS LS3, BRM, NPP
It will be very interesting to see how this plays out. My initial guess is that you are in for a long, hard fight to get this covered by warranty.
However, since it was never tuned you may have a chance. Definitely keep us posted on the proceedings.
Experience is the best teacher but the tuition is very high.
FB3 is offline   Reply With Quote
Old 05-26-2010, 03:39 PM   #3
ron10
Drives: 2010 2SS IOM L99
i'll bet this is going to be fun.i can just see it now.good luck.
Old 05-26-2010, 03:48 PM   #4
toehead93
Drives: 2014 2SS/1LE
You're not the only one:
http://www.camaro5.com/forums/showthread.php?t=85077
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 05-26-2010, 03:49 PM   #5
Badger
Badger's Avatar
I hear ya....like I said ,stock tune in place...I don't think an exhaust system would cause a failure like that
Old 05-26-2010, 04:01 PM   #6
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
I think the part where he was installing a new cam is gonna screw you. How do you know he didn't break it? Thats what they will say. BS or not thats how it will go down.
9/26/09 Took delivery!
Old 05-26-2010, 04:32 PM   #7
silverfox
silverfox's Avatar
Drives: 2010 camaro ss
I bet it was an intake valve because the intake rockers are offset a bit and maybe caused that.
[SIGPIC][/SIGPIC]Va.Speed built 427 stroker
LS2 Darton sleeved 427 stroker.Callies dragonslayer crankshaft. Callies I beam rods. Wiseco blower pistons. Mast cnc 12 degree big bore ls3 heads-2.2 intake &1.6 ex. 6 bolt 270cc-.750 deck. Lunati link bar lifters.T&D roller rockers.COMP-VA. Speed special cam 605 lift, 238dur. Procharger F1R @15psi. ARH headers with custom 3'' exhaust all the way.Magnaflow mufflers. QTP cutouts.Rossler built 6l80e trans. DSS 1400hp axles.
Pfadt suspension.-Coilovers, sway bars,motor mounts,trailing arms. Aeromotive eliminater pump.
907rwhp.
silverfox is offline   Reply With Quote
Old 05-26-2010, 04:53 PM   #8
Kenneth
Drives: 2010
Which engine is this L99 or LS3? Just curious.
Kenneth is offline   Reply With Quote
Old 05-26-2010, 05:10 PM   #9
Badger
Badger's Avatar
LS3
Old 05-26-2010, 05:13 PM   #10
Badger
Badger's Avatar
I don't know...I'm not a mechanic...is it possible to break a valve stem while disassembling a rocker arm?? Good Question...I would hope a reputable shop would step up and admit they did it if that were the case.
Old 05-26-2010, 05:13 PM   #11
busarider1971
Drives: 78 z28,82 z28 cf 339hp,10 2ss/rs
damn dude and fellow LEO...im going thru the same thing...but i just added a cai. mine was an exaust valve. the dealer is fixing it. but i dont know with all your mods they will be looking for a tune or say that it was running lean because of the LT. is yours a M6 or A6?
busarider1971 is offline   Reply With Quote
Old 05-26-2010, 05:28 PM   #12
BSR-1
BSR-1's Avatar
Drives: 17 ZL1 M6 Black
If you already have the guy installing a cam & he sees a broken valve just go to GM & buy a valve & have your guy replace it. can't cost that much for a valve can it?
I say this because I bet if GM catches wind of all your mods they're not gonna cover it anyway, (or any thing else down the road).
BSR-1 is offline   Reply With Quote
Old 05-27-2010, 01:00 AM   #13
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
this seems easier to me if you are going to get the cam and tune in the future anyway. If you are now not getting the cam and tune then I would fight Gm on it.
Old 05-27-2010, 07:27 AM   #14
SK360
Drives: 2005 Pontiac GTO
No way....
You undo the bolt and lift the rocker off... no way to break a valve stem while doing so.
You know the head has to come off to replace the valve right? So add a new head gasket, head bolt kit, labor of pulling the head and cleaning up the gasket surfaces and spilled coolant. Sounds easier and cheaper to let the dealer fix it if it is under warranty.
SK360 is offline   Reply With Quote
Valve Stem Cap BLU BY U Wheels and Tires Talk Sponsored by The Tire Rack 8 12-15-2009 08:59 PM
Tire Monitoring System monevz28 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 11-22-2009 04:42 PM
rubber seal inside valve stem cap carfansince73 5th Gen Camaro SS LS LT General Discussions 2 11-13-2009 07:34 AM
Do you have to replace valve stem if they are removed for powdercoating? quanine10 Wheels and Tires Talk Sponsored by The Tire Rack 8 06-05-2009 11:23 PM
L99 Delete Whats involved? jsharp Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 59 05-26-2009 11:54 PM
