Dont H8 Me Cuz U Aint Me
Drives: 2016 SS Sedan, 2017 Explorer Sport Join Date: Feb 2010
JBL MS-8
Goes in showstyle Monday morning. Gary Biggs will be doing the install and setup. The LCD will be installed up where your homelink and sunroof controls are replacing the Seatbelt/airbag screen for the attachment point!
Zach
Rhymin and Stealin
Thought you had one in already??? didn't it magically fix all you noise problems?
yes I just havent had time to post the latest pics. it also was hidden under the back sub enclosures and I got it all fancied up now.
I fully recommend finding your local JBL car audio dealer and having one installed before changing out your B.A. system.. it gives it new life and really creates sound unparalleled to anything else out there. So just imagine what it did to my setup ;-)
#6 |
Here's a little about the unit!
AUDIO INPUTS Many factory-installed systems include on-board equalization and crossovers that make simple connection of aftermarket products difficult. The MS-8 includes the signal-summing circuitry, signal-conditioning EQ and time-correction processing that are necessary to reconstruct a flat, full-range, two-channel signal when you use the MS-8 with factory-installed equipment. Aftermarket head units with line outputs provide a flat, full-range, two-channel signal on their front line outputs, so you need to connect only those channels to the MS-8. Connecting an aftermarket head unit If you’re using the MS-8 with an aftermarket head unit that has RCA-type outputs, connect the head unit’s front left and front right outputs to the MS-8’s line inputs 1 and 2 only. Do NOT connect any other head-unit output signals to the MS-8’s line inputs 3 – 8. During the calibration/setup process, the MS-8 will “normalize” the input signals and derive as many output signals as your speaker system requires.
#7 |
The wait is over!
Drives: 2010 Camaro, IOM, L99, Auto Join Date: Mar 2010
I am digging the orange interconnects... if you dont mind sharing, what are they?
Ordered - 4/17/2010
Delivered - 5/29/2010 AlphaDamp CLD Mat - Get more Sound Deadening with less Sound Deadener |
#8 |
Hooker Audio TS "Twisted Stuff" series.
#9 |
The wait is over!
Thanks
Ordered - 4/17/2010
#10 |
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 68 Camaro 327ci 2SS/RS 376ci LS3 Join Date: Mar 2008
The best set up that i have seen,
![]() Did you replace all the speakers? If you dont mind me asking, how much was all of this?
6000 Vehicle Delivered to Customer 6-23-10 |
#12 |
![]() Drives: 2SS Camaro Join Date: Oct 2009
The JBL MS-8 is an amazing system. Would recommend it. Just make sure you calibrate it properly once installed which is a very time consuming process. Even after 3 months of installing it, I still tweak the frequencies from time to time, but what a difference it made to the sound!
#13 |
![]() Drives: 2010 1SS/RS SIM L99 Join Date: Jul 2009
Did you guys replace the stock BA amp with the MS-8 or keep it and install the MS-8 on BA amp outputs?
#14 |
My BA amp is bypassed as I have a full custom sound system. But with the MS-8 you can run signals direct from your existing amplification with no problems at all and a 100% increase in sound quality.
I'll try and post pics of the new system.. the pics you see above was version 1.
| Camaro Style offering Double Din Special and other audio items | Indpowr | Audio / Visual / Electronics/ Gauges / Nav | 99 | 11-16-2010 09:12 PM |
| Decided to go JBL | The 2010 Sin | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 48 | 06-03-2010 08:29 PM |
| How do i improve my stereo? | dr1ven | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 44 | 05-13-2010 10:51 PM |
| JBL Subwoofer Install | Bumble_Bee | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 6 | 03-29-2010 11:13 AM |
