Old 05-31-2010, 11:31 AM   #1
hamad_311
Drives: 2010 Victory Red Camaro 2SS/RS
Exclamation V8 Camaro A6 6L80E - I think its breaking down
Hey Guys,
Im really having a bad time with my ride's trans, when i drive with half an open throttle everything is fine even at WOT, however when cruising when the trans shifts from gear to gear it shifts with some sort of a nudge and a heavy shift. when the trans is really really warm its better a bit. also on slowing down when it down shift its really rough i can feel the downshift once or twice till i stop. On low speeds it just seems to want to stay at that same gear doesnt want to up shift unless i step more on, and if i lift my leg it just stays on the same gear and "stays heavy"
any who have the same issue?? ways to fix?? guys who are more mechanical do u know what is causing this??
hamad_311 is offline   Reply With Quote
Old 05-31-2010, 01:22 PM   #2
2010 Bumblebee
2010 Bumblebee's Avatar
Drives: Transformers Edition Camaro 2SS/RS
Low fluid ?? Take it to the dealer .
The Yellow Camaro Club
http://www.camaro5.com/forums/group.php?groupid=128
Northern Massachusetts & Southern New Hampshire Camaro Club
http://www.camaro5.com/forums/group.php?groupid=127
The mother of all supercharger questions thread
http://www.camaro5.com/forums/showthread.php?t=77958
My 2010 Camaro Review
http://www.camaro5.com/forums/showthread.php?p=2025442#post2025442
2010 Transformer Edition Camaro L99 Auto
2010 Bumblebee is offline   Reply With Quote
Old 05-31-2010, 01:24 PM   #3
hamad_311
ill look into that, thanx man
Old 06-01-2010, 10:41 PM   #4
The Yeti
On the wrong side of town
The Yeti's Avatar
Drives: Pontiac G8 GT
Is your TCM tune stock? The G8's have the same trans and we had issues with 2-3 flares and sometimes surging until the trans warms up. They put out a bulletin for it for the g8's and it was found there were some faulty seals in there.
The Yeti - just an 11sec NA grocery getter!!!
08 G8 GT Premium/Sports Package W/Sunroof
Pat G Tuned, Heads/Cam/gears/Stalled, Dropped, Brembos on all 4 corners and every bolt on under the sun.
April 2011 G8 of the Month
June 2012 G8 of the Month
April 2013 G8 of the Month
@G8BOARD.COM
The Yeti is offline   Reply With Quote
Old 06-02-2010, 10:34 PM   #5
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
the camaro has the updated pump with the new style seals/sealing rings
Old 06-05-2010, 12:29 PM   #6
HzMajesty
HzMajesty's Avatar
Drives: 2010 2SS/RS Blk/Blk
Send a message via MSN to HzMajesty
id say take it to the Bahrain dealer too... but knowing the "expertise" they have your better off/luckier getting an answer here...
SHOCKWAVE - 2SS/RS/M6 - Blk/Blk
JRE Tuned - ARH LT 1-7/8 w/Cats - JRE Rear 4.11 - Borla "S" Cat-Back - CAI by CAI - H&R drop - HURST Shifter - BMR Tunnel Brace; 4 Point Brace; Adjustable Toe Rod; Rear Trailing Arms - Sphon Control Arms - MTI Racing w/Fire Sleeves - Stealth Ambers - GTS Tails - Phantom Grille - Concept LED Sidemarkers - Blacked out logos - Hotchkis Bars & End links - BMR Front Driveshaft Loop (install soon) - BMR Subframe connectors (install soon)
http://www.cardomain.com/ride/3813191#
HzMajesty is offline   Reply With Quote
Setting up an IRS/Drivetrain for Drag Racing Kyle2k Suspension / Brakes / Chassis 44 06-05-2010 10:17 PM
Suspension guys out there - lets talk wheel hop Crowley Suspension / Brakes / Chassis 14 10-09-2009 01:06 AM
