Old 06-01-2010, 04:12 PM   #1
devildoc
devildoc's Avatar
Drives: '12 Toyota Tacoma Dbl
Exclamation Airaid Version 2 tube Dyno Results
First off I want to start this thread by saying these are my results done on the same dyno that I have been dynoing my car at since I got it.
I am greatly impressed with the new tube that Airaid has designed; along with the hp it creates over the stock and version 1 tube. Now you will see a total of 4 pulls on the graph I did a total of 8, 2 per situation, and took the best one of each.
Now for the results you will see that on a NO TUNE pulls the Version 2 tube made at least 7hp/5tq more than the Version 1 tube did through the mid-high rpm range. Peak number difference was 3hp/3tq.
Along those same lines the TUNED pulls were very interesting. The Version 2 tube only did 3hp/3tq difference across the board over the Version 1 tube.
The weather definitely wasn't so accomadating today as has been for some of my previous pulls. I have added on the bottom my original number with only MRT V2 and today's max number and have seen an increase of 30.54hp/24.3tq. That is with a + 2100 DA difference which is terrible. So my assumtion, which may be wrong, is that if I could get close to the same DA of -792 I would make much better numbers than today. So total cost of the added hp/tq is MRT V2 (500) Airaid (300) ARH LT (1200) Trifecta Tune (570)
so $2,570.
Happy Viewing
P.S. - all results have been sent to Airaid and David and I have discussed my results and are happy to see such positive results.
STANDING 1/4MI: 13.948@99.87
6600RPM HP/TQ Gains - 30.54HP/24.3TQ (NOT PEAK)
devildoc is offline   Reply With Quote
Old 06-01-2010, 04:26 PM   #2
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Haven't digested everything yet... BUT your dyno sheets indicated they had the SAE correction on... notice on the run with the DA of -792 the SAE correction factor is .93... SO the dyno is doing it's best to even things out between the different DAs..
scrming is offline   Reply With Quote
Old 06-01-2010, 04:44 PM   #3
boxcar
boxcar's Avatar
Drives: 2LT/RS
Interesting
Thanks for the post
looks like nice gains but I'm still trying to interpret
boxcar is offline   Reply With Quote
Old 06-01-2010, 05:02 PM   #4
Maurdib
Maurdib's Avatar
Drives: 2010 Black Camaro 2LT/RS Auto
I know you can't compare dyno to dyno, but it appers Abby got more out of Shorty's and Solo Catback then LT's and Axel back seem to give, Do you have highflow cats?
BackInBlack
Performance:Vararam cold air intake
Maurdib is offline   Reply With Quote
Old 06-01-2010, 05:03 PM   #5
ROD1
Retired
Drives: 2010 Camaro RS V6 #1301 DOB 3/23/09
So does this mean you lost 3hp less than with the Version 1?
ROD1 is offline   Reply With Quote
Old 06-01-2010, 05:21 PM   #6
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
Looks like +3 with the version 2 with tune.
-3 with no tune...
Old 06-01-2010, 05:29 PM   #7
ROD1
Retired
-3 with no tune...
Originally his dynos showed a loss about 10hp when going from the stock box to the V1.
Old 06-01-2010, 05:36 PM   #8
Airaid Filters
Airaid Filters's Avatar
Drives: 2010 Camaro
-3 with no tune...
Gentleman,
NONE of the runs showed a loss in power, not sure where anybody is reading that.
The 3HP the V2 made over the V1 is “Peak” HP, but if you look through the band, the V2 made even more power at the lower to mid range part of the RPM band, where you will be driving in real world conditions.
EVERYBODY needs to understand that this is “DevilDoc’s” car with HIS modifications ( Airaid, Long Tube headers, Tune, Axle Back Exhaust ) and this does not represent what EVERY car will do or see for gains.
From speaking with Jacob, it appears he was pretty happy with the improved results and the most important of all he could feel a nice difference in the SOTP with the new V2, which in turn means it is working
Thanks,
David
Airaid Filters is offline   Reply With Quote
Old 06-01-2010, 05:44 PM   #9
ROD1
Retired
Originally Posted by David@Airaid View Post
Gentleman,
Thanks,
David
Your not understanding. When doc did his dynos with the first version he was showing about a 10hp loss. His new dynos show that he is getting 3hhp less loss than before by using the V2 instead of the V1 over the stock airbox.
Old 06-01-2010, 05:47 PM   #10
PoorMansCamaro
Drives: Really Slow
Oh, I fully understand that this is his dyno on his car. And that every car will be different, even with the same mods.
Old 06-01-2010, 05:53 PM   #11
devildoc
devildoc's Avatar
Hey ROD not sure yet about how this all works out with the DA but I have a feeling that could have something to do with it. Also, my dyno guy has a fan that blows only 30mph and he said I would possibly get much better results with a larger fan. I don't think I've lost hp since I did some 0-60 runs about an hour ago and my time has dropped pretty well with a worse DA. I went from a 5.83 in winter time to a 5.65 just now. And the DA is at 1530.
Old 06-01-2010, 05:56 PM   #12
Airaid Filters
Drives: 2010 Camaro
Hello ROD1,
I completely understand, what is not actually being “Understood” here is that you can’t compare today’s Dyno to his original test. There was no baseline for today.
You can’t take a Dyno from 3 months ago and compare it today. It’s not apples to apples in any way shape or form.
A Dyno is a tuning tool, and you need to understand a Dyno is a rough estimate of what “ A vehicle” did on that day, with it’s given modifications.
So to compare Jacob’s 1st dyno test to today is wrong and inaccurate information. In all fairness It’s just not a accurate comparison.
Thanks,
David
Old 06-01-2010, 06:04 PM   #13
ROD1
Retired
Did you do any runs with your stock airbox back on this time. I want to see a V2 verses the stock box?
Old 06-01-2010, 06:05 PM   #14
devildoc
devildoc's Avatar
The last dyno graph was strictly to show that between just the MRT V2 to now with my mods that I have gained 30hp/24tq.
Texas Speed Long Tubes & Rumbler 5 Cat-Back Dyno Results! Trevor @ Texas Speed Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 48 12-08-2018 02:37 AM
Roto-fab CAI dyno results Roto-fab 1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 102 07-30-2016 07:21 PM
V6 Dyno results collection HannoverFist Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 42 02-01-2011 06:01 PM
More 2010 SS Air Intake Dyno Results From Texas Speed!! Jason 98 TA Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 15 07-03-2009 09:58 PM
