![]() ![]() ![]() ![]() ![]() Drives: Camaro Join Date: Apr 2009
More 2010 SS Air Intake Dyno Results From Texas Speed!!
Guys here's another car that just had the final version of the Texas Speed cold air intake installed. For this test we did a baseline pull, installed intake & made 2 pulls, then went back to the stock intake.
This test should show really well the power potential of the Texas Speed air intake system. Look for more results soon, we have two other cars here for the intake install!! Enjoy the results!!
Nice gains, any pics?
http://www.camaro5.com/forums/showthread.php?t=344754 Summit White 2014 2SS 1LE Recaros, NPP exhaust, Nav 2010 2SS A6 - sold. Last edited by toehead93; 06-29-2009 at 03:22 PM. |
![]() Drives: 2010 Rally Yellow Camaro SS Join Date: Jan 2009
Hmm all pics on that site are down.
Delivered: Rally Yellow 2SS/RS (LS3) with black interior.
Event code 1100 on 1/24 Event code 3000 on 3/24 Event code 3400 on 4/27 Back to event code 3000 on 5/1 Event code 3800 on 5/5 Event code 4B00 on 5/5 Event code 4200 on 5/22 Event code 6000 on 6/3! VIN# 2G1FT1EW6A9107395 |
no tune?
great info! ALL VENDORS should follow that DYNO proceedure. STOCK MOD MOD STOCK i LOVE it! Thanks!
Why oh Why?
Windshield=10" vertical mirror= 3 7/8" (that's almost 4") vertical that means that the mirror is 38.75% the size of the vertical windshield... it sure seems like the ratio could be better... just sayin.... ![]() our collective MIRROR patch: http://www.camaro5.com/forums/showthread.php?t=24612 |
#6 |
![]() Drives: a slow 2010 Join Date: May 2009
with or without tune?
#7 |
![]() ![]() ![]() Drives: CTS-V Join Date: Aug 2008
The intake really changed the A/f's a good amount , looks almost like a full point leaner ?
#8 |
![]() Drives: 1998 GMC C1500 Ext. Cab 4.3L Join Date: Jun 2009
Is it California legal?
#9 |
![]() Drives: Toyota Tundra Join Date: Jun 2009
How about the raw numbers before and after? Some of us aren't used to reading dyno graphs! Looks like a great mod!
2010 Silver Ice Metallic 2SS/RS/A6
6/24 order placed 6/26 order confirmed NMBJ9X 7/17 1100 |
#10 |
![]() Drives: 2010 2SS/RS, CGM Join Date: Jun 2009
Looks like that is with a tune. Both runs with the CAI has the AFR leaned out quite a bit (around 12) and that gives you more power. Unless the CAI is causing it to lean out on its own.
2000: 6/18/09 2500: 6/23/09 3000: 6/24/09 TPW 7/27!!! Canceled above order when I found this: 2SS/RS, M6, CGM, Blk, GFX, Sunroof, VIN#18XXX!!! ![]() Thanks to Marty Feldman Chevrolet, Novi, MI |
#11 |
![]() ![]() Drives: 2010 Camaro, 2SS/RS Join Date: May 2009
Changing to a CAI with more flow will add more air to the combustion chamber while maintaining the same fuel tables "should" result in a more lean dyno run, which is why there's a 19hp jump, not neccesarily a tune, but the result is the same.. More HP
2010 2SS/RS CGM American Racing Headers, Magnaflow axle back, Roto-Fab CAI, Audio Integrations Sub box, Alpine Type R 10, Alpine MRP-500 amp, Pro Clips iPhone Mount |
#12 |
![]() Drives: 1998 TA Join Date: Sep 2008
No tune I believe.
#13 |
Yes this is completely stock tuning. The leaner a/f is why intakes are working so well. It's also the reason I have atleast 10 bad intake designs sitting here working to get the air fuel that's correct & that doesn't do weird stuff at other rpm's. We dont just build a intake & hope she works. We've tested it now on probably 5 different cars as well as on the engine and chassis dyno at different loads & throttle points in a effort to confirm the intake is doing exactly what we want it to do! The best part will be the pricing guys, you dont have to pay tons for a intake that adds the 20hp you expect!!
#14 |
Petro-sexual
Pretty cool! It sounds like this is just not some backyard-designed intake that you guys stuck a filter on and called it a day. It sounds tuned and that's why it's working so wel.
Good job, IMVHO.
'20 ZL1 Black "Fury" A10, PDR, Exposed CF Extractor Magnuson Magnum DI TVS2650R // RFBG // Soler 103 // TooHighPSI Port Injection // THPSI Billet Lid // FF // Katech Drop-In // PLM Heat Exchanger // ZLE Cradle bushings // BMR Chassis-Suspension Stuff // aFe Bars // Diode Dynamics LEDs // ACS Composites Guards // CF Dash // Aeroforce // tint // other stuffs |
| CAMARO WIKI | Tran | Wiki | 67 | 11-27-2024 08:02 AM |
| Texas Speed Long Tubes & Rumbler 5 Cat-Back Dyno Results! | Trevor @ Texas Speed | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 48 | 12-08-2018 02:37 AM |
| 2010 Mustang GT vs 2010 Camaro SS | Fireball | Chevy Camaro vs... | 257 | 05-18-2009 11:04 AM |
| Where The Crap Is The Texas Speed SS #2G1FT1EW8A9100805 | Jason 98 TA | Camaro Price | Ordering | Tracking | Dealers Discussions | 21 | 05-12-2009 10:30 PM |
| 2010 SMS Mustang | TFord | General Automotive + Other Cars Discussion | 19 | 01-22-2009 11:00 AM |
