Old 06-05-2010, 11:58 AM   #1
jagan323
I have no life
jagan323's Avatar
Drives: 06' Subaru STI, ex-Camaro V6 LLT
LLT have a fuse pull mod?
Hi guys,
Maybe this has been asked before... or maybe I just don't understand why the L99 has this "fuse pull" mod. But do the LLT V6 Automatic have any benefits from doing this?
If there is, which fuses?
Thanks =D
jagan323 is offline   Reply With Quote
Old 06-05-2010, 12:00 PM   #2
mrray13
Drives: 2010 1LT RS Rally Yellow
No, because the LLT doesn't come with two fuel octane maps, like the L99 does.
If you decide to do it, it's fuses #5 and #20.
mrray13 is offline   Reply With Quote
Old 06-05-2010, 02:30 PM   #3
zen
Drives: 2011 CTS CPE & 2010 2LT/RS CGM
Generally most GM cars monitor the last 3 or 5 starts and adjust the ECM to the average of those parameters.
"No, because the LLT doesn't come with two fuel octane maps, like the L99 does."
I don't believe the above is correct. There is an algorithm in all ECM's to compensate for the various signals that are produced by all the sensors.
zen is offline   Reply With Quote
Old 06-05-2010, 02:45 PM   #4
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Still. There will be no benefit from the 5-20 fuse pull an the V6.
Old 06-05-2010, 02:58 PM   #5
zen
There will be if the driving style changes from the previous average runs. Especially regarding the Throtle position sensor.
Old 06-05-2010, 03:01 PM   #6
PQ
Booooosted.
PQ's Avatar
I'm still not convinced of that. If it's there, it's there. If it's not, it's not. (outside of tuning anyway)
I've just not had anyone confirm this.
Old 06-05-2010, 04:31 PM   #7
zen
It especially changes the shift points if your driving style becomes more or less agressive than the previous average. Holds true on the cadillac CTS also.
Old 06-05-2010, 05:28 PM   #8
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
I think the key is going to be someone getting into that V6 ECM and really picking it apart. Its pretty tight from the factory but there is always room for improvement.
Old 06-05-2010, 07:58 PM   #9
jagan323
I have no life
jagan323's Avatar
I see... thanks for the clarification. I just needed to know. Sounded like it improved alot for the L99, so I wanted to know if it had benefits for the LLT. Thanks guys =)
Old 06-06-2010, 10:45 AM   #10
zen
The fuse pull or battery disconnect allows the volatile memory in the ECM/PCM to be cleared so that it can accept the new signals from the various sensors. (just like any computer)
Old 06-08-2010, 12:22 AM   #11
jagan323
I have no life
jagan323's Avatar
I'm in a v6, if i went from 87 to 94 octane (I dont have 91... ) would pulling the fuses help? Because I feel my car is having no differences right now. Im wondering if reseting the ECM would help it notice the knew fuel. Anyone have any ideas? =p
Fuse Pull: Low Octane Fuel Fix For L99 and LS3. Reset Fuel Map for High Octane Fuel. radz28 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 2838 05-11-2024 11:42 PM
fuse box gtjacket 5th Gen Camaro SS LS LT General Discussions 14 02-25-2011 10:26 AM
Key Fob Mod LED - My First Mod... Buhmblbe Camaro DIY & HOW-TO instructions & discussions 15 12-07-2010 05:23 PM
#230 1 Day After Fuse Pull 0-60 Scott@Bjorn3D Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 21 08-25-2009 08:53 PM
8327 after fuse pull redjewel Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 30 08-25-2009 03:24 PM
