Old 06-06-2010, 02:11 PM   #1
HOZAY
The Eponymous Jose
HOZAY's Avatar
Drives: A V6. Yes. A LLT.
Removing Rust from Brake Rotors?
Well, the humidity here in Miami has played merry hob on my Camaro's brake rotors, leaving them a wonderful shade of yellow following some torrential rainfall lately. What's the best way to get rid of that?
HOZAY is offline   Reply With Quote
Old 06-06-2010, 02:12 PM   #2
motor1
motor1's Avatar
Drives: 2010 Camaro 1SS/RS/M6.....no longer
drive it around the block...
motor1 is offline   Reply With Quote
Old 06-06-2010, 02:17 PM   #3
HOZAY
The Eponymous Jose
HOZAY's Avatar
That's what I just read, lol, and along with realizing that I haven't driven it in two days , and that I put this in the wrong forum.
Old 06-06-2010, 02:21 PM   #4
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Well, now that you know -- I just threw this into the maintinence tech section.
The rotors will even do that after a simple wash!
Old 06-06-2010, 02:27 PM   #5
zebra
just can't seem to leave
zebra's Avatar
Drives: your mom wild!!
in my build thread, i've got pics of my rotors after 3 months of sitting out behind the shop. they were nice & clean after a couple miles around town
Eve ('00 FRC): hot-air intake
Old 06-06-2010, 06:28 PM   #6
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
Yeah, it seems like rotors can pick up surface rust almost overnight when humidity is high, but it rubs right off when you apply the brakes. There's really nothing you can do about it because it occurs on the contact area of the rotors.
Old 06-08-2010, 12:24 AM   #7
thekid96
Drives: Z06, 69 Camaro
WD40 takes it right off...
thekid96 is offline   Reply With Quote
Old 06-08-2010, 12:58 PM   #8
Texhawk
Texhawk's Avatar
Drives: 69Camaro,87IROC,96 SS,Z06&Stingray
Most rotors will form rust immediately upon contact with water.
You can avoid the rust by converting to carbon ceramic rotors like on the ZR-1. (of course, then you have to worry about chipping them everytime you take a wheel off:()
Texhawk is offline   Reply With Quote
Hawk Performance Brake Pad "Updated" KILLER74Z28 Suspension / Brakes / Chassis 34 05-04-2016 12:11 PM
Brembo 2SS Brake rotors Front and Rear Complete with Pads 55Designs Suspension / Chassis / Brakes 4 06-07-2011 03:58 PM
Racing Brake 2 pc Rotors Installed mtcwby Suspension / Brakes / Chassis 36 11-13-2010 06:07 PM
DBA Brake Rotors, Hawk Brake Pads, and Motul Fluids! AJ@ECSMotorsports Suspension / Chassis / Brakes 49 11-13-2010 04:57 PM
2010 Camaro SS Brembo Heavy Duty Cross Drilled Brake Rotors In Stock Ready To Ship Tim@Lingenfelter Suspension / Chassis / Brakes 4 12-07-2009 09:26 PM
