Old 10-26-2008, 05:37 PM   #1
72 Z27
Drives: '70 Z28/RS & '14 Z28
Dimensions
I am ordering a new enclosed trailer and what to make sure that the 5th gen (along with the first 4 generations) will be able to fit correctly. The trailer will have a door on the driver side so you don't have to crawl out of the cars. I have looked at the spec sheet for the new car, but need some other dimensions that maybe someone on the site has. Here are some dimensions I would like to have:
1. Distance from either the front or rear wheel center line to the back of the drivers side door.
2. Distance from either the front or back bumper cover to the back of the drivers side door.
3. Distance from the front bumper cover (the farthest forward point preferably) to the center line of front wheel.
4. Distance from back bumper cover to the center line of the rear wheel.
5. Height from bottom of door to ground.
Additional question:
The "track" dimension, is that from the outside edge to outside edge of the tire/wheel?
I know that a lot of the above dimensions are pretty much the same, but the answer to just one or two would be helpful.
Thanks
Jeff
72 Z27 is offline   Reply With Quote
Old 10-26-2008, 07:13 PM   #2
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
I doubt anyone has all those dimensions. I suggest finding a side on shot and overlay a gird and use that. Do the same thing with front and rear pictures.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 10-26-2008, 07:34 PM   #3
72 Z27
I figured that no one would, but was worth a shot. Can't believe I didn't think of the grid. Thanks
Jeff
Old 10-26-2008, 08:06 PM   #4
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
Wheelbase (in/mm): 112.3 / 2852
Overall length (in/mm): 190.4 / 4836
Overall Width: 75.5 / 1918
Overall height: 54.2 / 1377
Track (front) (in/mm): 63.7 / 1618
Track (rear) (in/mm): 64.1 / 1628 (LS, LT)
63.7 / 1618 (SS)
Curb weight (lb/kg): 3750 / 1705 - LT automatic
3741 / 1700 - LT manual
3769 / 1713 - LS automatic
3780 / 1718 - LS manual
3913 / 1779 - SS automatic
3860 / 1755 - SS manual
Weight balance: 52% front / 48% rear
I piss excellence
and fart awesomeness
Old 10-26-2008, 08:27 PM   #5
72 Z27
63.7 / 1618 (SS)
I'm looking for the specific dimensions above, but thanks.
Jeff
Old 10-26-2008, 09:10 PM   #6
Gomerr
Drives: 1991 Honda Civic
All information currently known is on the camaro5.com wiki.
once more detailed information becomes available the wiki will be updated as well.
for wanting such detailed information your gonna have to do tape measurements at a display that you can actually get close to, not be barred from.
frankly with the wiki information you can make a pretty damn good idea of the scaling your needing. otherwise wait 4 months
Gomerr is offline   Reply With Quote
Old 10-26-2008, 09:55 PM   #7
72 Z27
It was a long shot, but hoping maybe, just maybe somebody took some of these measurements while at the Indy Bash. My father was suppose to, but didn't while there and unfortunately I was unable to make it to Indy myself. With that being said, I will do some scaled measurements like mentioned in the second post of the thread.
Jeff
Old 10-26-2008, 10:30 PM   #8
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
You know what you might want to do? Print out this picture on an 8.5x11; it's the SS, and it's still to scale. Grab a ruler, and use the overall length measurement Camarospike provided to setup some ratios. You can do some simple math and come out with real close (not 100% accurate) measurements of what you're looking for. Sound okay?
Old 10-26-2008, 10:39 PM   #9
72 Z27
Attachment 9886
Thanks, and done.
Jeff
Camaro Dimensions vs. Competition (a comparison) LSxcellent 5th Gen Camaro SS LS LT General Discussions 19 07-26-2008 10:57 PM
Dimensions? LSxcellent 5th Gen Camaro SS LS LT General Discussions 22 07-23-2008 12:41 PM
2010 Camaro SS -- NEW closeup photos of front-end!!! -- 7/11/08 Tran Camaro Photos | Spyshots | Video | Media Gallery 591 07-17-2008 08:27 PM
Camaro Update: A Few Little Things... camaro5 5th Gen Camaro SS LS LT General Discussions 162 06-02-2008 12:40 PM
