Old 06-18-2010, 02:28 PM   #1
ULTRAZLS1
ULTRAZLS1's Avatar
Drives: 14 Silverado LTZ Z71, 16 Camaro SS
Leaking catch can
My RevXtreme catch can is leaking from the bottom even though the valve is closed.
Anyone else have this problem?
What should I do?
thanks
ULTRAZLS1 is offline   Reply With Quote
Old 06-18-2010, 02:30 PM   #2
RedJewel2SS
12.23s@113mph
RedJewel2SS's Avatar
Drives: 2SS/RS, A6, just a few bolt ons
are you sure it is closed? with it fully closed the threads should be all the way out, not all the way in.
RIP Cammie 7/15/2009 - 4/1/2011
RedJewel2SS is offline   Reply With Quote
Old 06-18-2010, 02:50 PM   #3
ULTRAZLS1
ULTRAZLS1's Avatar
Pretty sure.
But I have opened and closed it now a couple times so I cant remember anymore.
Clockwise takes the threads all the way out and closes it correct?
I think that is how I had it...
Old 06-18-2010, 03:51 PM   #4
RedJewel2SS
12.23s@113mph
Originally Posted by ULTRAZLS1 View Post
Pretty sure.
i'm gunna go check. its been over 1000 miles since i checked it last so something should be in there.
Old 06-20-2010, 04:18 AM   #5
RevXtreme1
RevXtreme1's Avatar
Drives: 2010 RPE600 Camaro - 608rwhp
If it is defective please give us a call at 941-755-3535 and we will be more than happy to replace it..It will require you to send yours in and we will ship you a new one out asap.
Thanks
Josh
RevXtreme1 is offline   Reply With Quote
Old 06-22-2010, 06:45 PM   #6
ULTRAZLS1
ULTRAZLS1's Avatar
Gave it a few more days when I was positive it was turned in correctly.
Still leaking. Ill send it in within the next couple days im sure.
Old 06-24-2010, 03:28 PM   #7
ULTRAZLS1
ULTRAZLS1's Avatar
Turns out we had an extra drain valve sitting around in the garage with the same threads. I just replaced the original one and now it is fine...so far.
Looks like the lip where the valve seals in the original part was not sufficient/defective. The lip on the valve I replaced it with has a much more noticeable step-down/larger lip. This is the only explanation I can think of as to why it was letting oil by...
Thanks for the quick reply though...it was nothing major as I suspected.
DIY: PCV catch can install lawdogg149 Camaro DIY & HOW-TO instructions & discussions 57 11-05-2018 05:15 PM
Elite Oil Catch Can flht99b Vendor and Seller review / feedback / experiences 20 06-08-2010 06:00 AM
New Install Oil Catch From Elite Engineering BUMBLEB Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 25 04-21-2010 08:34 AM
Elite Engineering catch can finally installed on my LS3 adub4185 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 10 03-26-2010 11:34 AM
My rearend is leaking! tcslc Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 10 07-15-2009 11:49 PM
