Old 06-23-2010, 10:13 AM   #1
tom692010
Drives: 4 wheels
18" drag radials
I just installed some 18" nitto but when I drove about a mile I had the stability trac and all the gauge lights come on If I turn the car off and let it sit and restart the car there are no lights an it starts normal. Anyone run in to this when they went to a smaller tire size?
tom692010 is offline   Reply With Quote
Old 06-26-2010, 01:20 PM   #2
usa1camaro1969
Back on the dino-juice
usa1camaro1969's Avatar
Drives: '10 LS + a few more
I went to a shorter tire on the front and the same thing happened. The way the service manager at the dealer described it the stabilitrac is involved with the ABS and a bunch of other systems. The sensors in the tires are now reading they are going at different speeds which is tripping the stabilitrac.
usa1camaro1969 is offline   Reply With Quote
Old 06-27-2010, 06:01 AM   #3
Ovenmitt
Drives: 2011 RJT 1SS
Send a message via AIM to Ovenmitt
IF your rear and front tires don't match respectively by size, your TC will go bonkers and you'll have to turn it off. Thats generally what you'll have to do with odd-sized drag radials for track trips.
Ovenmitt is offline   Reply With Quote
Old 06-28-2010, 12:19 PM   #4
tom692010
Drives: 4 wheels
I only use the 18's for racing on the back. I get about 5 minutes with nothing on the gauges except for the tc ans stability off if I do it right away.
18" M&H Drag Radials on Z06 wheels Supercharged SS Wheels / Tires 20 05-22-2010 12:35 PM
18" or 20" drag radials tom692010 Wheels and Tires Talk Sponsored by The Tire Rack 5 05-14-2010 11:20 AM
18" Wheels and drag radials? lewylew Wheels and Tires Talk Sponsored by The Tire Rack 1 05-13-2010 06:18 PM
Launch control + 18" drag radials = one VERY unhappy PCM thesubfloor Dragstrip and Launch Techniques Discussion 2 04-20-2010 08:39 AM
18" Drag Radials Merc Wheels and Tires Talk Sponsored by The Tire Rack 4 09-25-2009 12:33 PM
