Old 07-05-2010, 08:56 AM   #1
Ex-stang
Ex-stang's Avatar
Drives: "Sergeant" a 1LT/SIM/RS/CONN/BA/M6
Eibach lowering kit on its way, anyone know a good installer? (montreal region)
Well the Eibach pro-kit is on its way ordered from performanceparts.com.Should arrive in next few days.Have heard people having issues with bumpy performance because of the preload not being set properly on install ( huh ).
Need a reputable shop that can install align and set camber etc for a professional set-up.
Anyone have any clue, just drop by the post and add your suggestions for reputable shops in and around Montreal (north shore, south shore etc).
You know pics will be up as soon as installed !
quoted from another thread!
Front
Camber -1.25
Toe - OUT .1
Rear
Camber - 1/2 the Front
Toe - Zero
" Have the tech loosen every rotational bolt / bush in the suspension. Drive the car SLOWLY and CAREFULLY around the lot with the bolts a couple of turns loose. Put it back on the alignment lift. Without taking any weight off the wheels, tighten all the bolts. All the bushes are now timed to your new lowered ride height. "
I've looked at all the sellers of lowered springs instructions and no one mentions this step. I wonder just how many folks or install shops either drop spring or coil over users actually loosened every suspension point and recenter the bushings. I was well aware of this step but this thread seems to be the first to mention it is necessary.
Ed M.
This is something that should be done whenever ride height is changed. It takes some time and effort and that is why IMO that this step is skipped. What I have not mentioned in this thread is if you skip this step it can lead to premature wear and or failure of the rubber bushes. The rear lower in control arm bush is a steel jacketed bush. It is never going to adjust by itself to the new ride height. It will only fatigue into a more relaxed state. Other bushes that are rubber could in theory eventually rotate to the proper position, but the OE design is that the ferule twist and the bush not rotate.
I cannot speak to why this is not standard operating procedure for other companies because it is the correct way to do the job.
UPDATE!!! 2010-07-07
My springs are here!!!!! Getting em installed at the local MIDAS shop near my house..Tech said hes done hundreds of lowered cars, itl be his first 2010 camaro.
I downloaded pfadt spring install guide and bringing it with me tommorow morning...
Il post pics with the new dropped car, Thanks too 99 i found a new name for my car ...Calling it "Sergeant"
Ex-stang is offline   Reply With Quote
Old 07-05-2010, 07:39 PM   #2
06blownSS
06blownSS's Avatar
Drives: 2010 Camaro SS
I have the pro-kit installed on my car. I did it at my local garage that I've been going to for years and had NO issues at all, and he is by no means a specialist. He has done the springs on 4 of my other cars but the Camaro has been the most valuable to date. I wasn't overly worried about installing springs its a straight forward install for any mechanic that knows how to uninstall and install springs.
Black on Black on Black 2010 Camaro 2SS LS3;K&N intake, Dynatech 1 7/8 catted LTs, Borla S Cat Back, Eibach prokit, Pfadt rear trailing arms, ZL-1 driveline, BTR Stage III Cam, Tuned by Performance Redline 444.1whp & 442.9 ft-lb
06blownSS is offline   Reply With Quote
Old 07-05-2010, 08:06 PM   #3
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
never hear of "timing' the bushings, but you will love the lowered stance.
Old 07-06-2010, 10:50 AM   #4
RickRay
INJACC
RickRay's Avatar
Drives: 2010 CGM 2LT/RS AUTO
ESP Performance .. Cobra Sport..both in Laval. Try talking to any Midas dealers?
Member of 'Club Elite' #70
2LT/RS Auto / Solo HFC / Solo Mach X-LLT J-Pipe / JBA Headers Shorty
CAI - Cold Air Inductions / VMAX TB / Trifecta Tune
Hotchkis Max Strut Brace / Blade Dovetail Spoiler / Elite Catch Can
ACS T3 Hood Ports / T2 Bumper Ports / T2 Splitter / ACS T1 Led Light Kit
ACS Rockers / ACS Composite Hood Liner / ACS Upper Rear Quarter Ports
ACS Front Wheel Mud Flaps / ACS Rear Wheel Mud Flaps / Vitesse Throttle Controller
Pedders Drop Suspension / BMR Lower Control Arms / Style 41 ZL1 Wheels /
Oracle Afterburners / Oracle Concept SMD Side markers
Complete SS Brembo Brakes Set
RickRay is offline   Reply With Quote
Old 07-07-2010, 09:15 AM   #5
Ex-stang
Ex-stang's Avatar
Thanks rick !
Old 07-07-2010, 08:33 PM   #6
Ex-stang
Ex-stang's Avatar
Shameless bump for the update in original post...
Old 07-07-2010, 08:37 PM   #7
lee
lee's Avatar
Drives: 2010 2ss/rs
how much did they charge you for the install?
lee is offline   Reply With Quote
Old 07-07-2010, 08:45 PM   #8
Ex-stang
Ex-stang's Avatar
They quoted an hour per wheel havent brought it in yet (tommorow morning)
Im guessing maybe 160.00$ install plus alignement fees......
Old 07-07-2010, 09:06 PM   #9
RickRay
INJACC
RickRay's Avatar
Way to go Sergeant See you Friday night....
Old 07-07-2010, 10:24 PM   #10
ACS Composite
ACS Composite's Avatar
Drives: 2010 Camaro
I went to resort ideal for my suspension install.
If you call ask for Said, he looked after my car, very prompt service.
ACS Composite is offline   Reply With Quote
Old 07-08-2010, 08:23 AM   #11
Ex-stang
Ex-stang's Avatar
Thanks ACS i just put him in my contacts!!!!!
Soo when are us v6 ers getting that front lip
Old 07-10-2010, 09:08 PM   #12
Ex-stang
Ex-stang's Avatar
They are on and man getting the oe specs for the alignement was a pain i nthe ass even the gm dealers machine here in Terrebonne didnt have the specs for the 2010 camaro...found em online here they are for those interested ....
Name:  camaro alignment specs.jpg
fe2 = v6
fe3 = v8
wrs = rally sport
wbs is a typo should read wrs as in the `with`wrs package confirmed by dealer dbs doesnt exist
Eibach ProKit Lowering Springs in Stock | FREE S&H! AJ@ECSMotorsports Suspension / Chassis / Brakes 139 11-17-2010 03:23 PM
Want to Lower Your Camaro? Step Inside! Eibach Springs and Sways Now Shipping! Kris@BMCPerformance Suspension / Chassis / Brakes 20 01-15-2010 10:09 PM
Eibach Lowering Springs and Sway Bars Now Shipping @ BMC Performance Kris@BMCPerformance Suspension / Chassis / Brakes 6 11-14-2009 09:34 PM
Best prices on Eibach pro-kit springs & question on camber adjuster kit topgun1 Suspension / Brakes / Chassis 4 10-14-2009 07:00 PM
