Old 07-09-2010, 07:45 AM   #1
jtzako
Drives: 2010 IBM Camaro SS
Clearing a CEL
Will this car clear its own CEL if the problem that caused the CEL is now fixed? I've got a CEL and I know why it appeared, I fixed the issue, but the CEL remains even after about 30 miles of driving (and also tried 5/20 fuse pull).
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
jtzako is offline   Reply With Quote
Old 07-09-2010, 10:52 AM   #2
jagan323
I have no life
jagan323's Avatar
Drives: 06' Subaru STI, ex-Camaro V6 LLT
sorry, whats a CEL? =/
jagan323 is offline   Reply With Quote
Old 07-09-2010, 10:58 AM   #3
caverman
caverman's Avatar
Drives: '69 SS Convertible
You could disconnect the battery or go down to the local AutoZone or Pepboys and rent a code reader to clear it. They are usually free to rent. You just have to put up the cost of the scanner first then they refund the money when you bring it back.
Build Journal
Old 07-09-2010, 10:59 AM   #4
Steve Dallas
Commits weekly crime
Steve Dallas's Avatar
Drives: 2017 Camaro 1LT
Check Engine Light
2017 Camaro 1LT - Blue Barchetta IV
I fire up the willing engine, responding with a roar. Tires spitting gravel I commit my weekly crime.
Steve Dallas is offline   Reply With Quote
Old 07-09-2010, 11:51 AM   #5
jagan323
I have no life
jagan323's Avatar
Originally Posted by Steve Dallas View Post
Check Engine Light
Ugh, FACEPALMING Myself LOL... i shoudl have just searched... sorry. I've seen CEL a lot on some Intake topics... and i've wanted to get an Intake... seeing people talking about CEL... i thought it was like pro street talk.. so i never asked o_O
Old 07-09-2010, 12:04 PM   #6
The Flash
The Flash's Avatar
Drives: Firebird 95, Equinox 05, Camaro 2SS
Keep an eye on the warranty issue!
jtzako: I seem to recall reading that even after you manage to clear the code of a warning message, the actual ocurrance of the message and/or malfunction is still recorded in the car's electronic log.
So, the next time your dealer connects his diagnostic/scan tool to your vehicle it will show up.
Therefore, I suggest you keep a good record of everything that you did to correct the CEL problem : invoices of any parts or fluids you installed or used, orders and receipts of any shop you might have used so that you can demonstrate a proper procedure was performed so that this not become an issue your dealer might use to claim that your warranty is void.
Safe riding to you,
The Flash
The Flash is offline   Reply With Quote
Old 07-09-2010, 12:15 PM   #7
jtzako
Safe riding to you,
The Flash
It was just an O2 sensor disconnected at the cats. No big deal just enough to get the engine light to come on. Unfortunately the light didnt turn off on its own. I'll try and scan it tonight and see if its a 'stored' condition or an actual active problem still.
Old 07-09-2010, 01:31 PM   #8
Jefe's SS
Drives: 2010 2SS/RS IOM L99
Is the gas cap tight?
Jefe's SS is offline   Reply With Quote
Old 07-09-2010, 01:37 PM   #9
Frank in MD
Raining Blood
Frank in MD's Avatar
Drives: 2014 SS Performance Sedan
Onstar can tell you why your engine light is on, but can't turn it off even if the issue was resolved. Push the Blue Onstar button, have them check to see if the car is throwing a code, then take it in to the dealer.
Frank in MD is offline   Reply With Quote
K&N CAI installed, now getting CEL OrangeFury Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 12 07-14-2010 03:37 PM
CEL PO496 Dr Jkel Tuning / Diagnostics -- engine and transmission 5 07-07-2010 10:32 AM
CEL Question... getarz4u15ster Tuning / Diagnostics -- engine and transmission 17 05-07-2010 11:20 AM
Tire pressure monitor CEL after tire change B.Buster Wheels and Tires Talk Sponsored by The Tire Rack 6 04-01-2010 08:45 PM
v6 CEL, shorties, IAT relocate, Flowmasters mrray13 Tuning / Diagnostics -- engine and transmission 12 01-13-2010 04:17 PM
