Old 07-09-2010, 10:35 AM   #1
rforbes
rforbes's Avatar
Drives: IOM SS/RS
Radiator Capacity
Does anyone know the radiator fluid capacity for the L99? Have not been able to find it on Google.
rforbes is offline   Reply With Quote
Old 07-09-2010, 02:51 PM   #2
adub4185
Drives: 2010 2SS RS, 2023 Camaro ZLE
Send a message via AIM to adub4185
The owners manual should have the capacity listed. Why are you changing the coolant out Rick? Hope to see you at Friendly tomorrow, I'll have a red seat handle waiting for you.
adub4185 is offline   Reply With Quote
Old 07-09-2010, 03:49 PM   #3
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: ...
Search and ye shall find:
http://www.camaro5.com/forums/showthread.php?t=49508
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 07-09-2010, 04:09 PM   #4
rforbes
rforbes's Avatar
Drives: IOM SS/RS
I will be there at Friendly
I am draining it and putting some stuff in it that is called "Water Wetter" made by redline. It is supposed to help your radiator run cooler and protect it from corrosion. Also improve heat transfer and reduce cylinder head temperature. Supposedly it works best by using less antifreeze, (In warmer climates), and more water. I talked to a couple of Vette owner that swear by it.
Old 07-09-2010, 08:48 PM   #5
adub4185
I put watter wetter in my M3. It does keep temps down during the summer months. My car runs a lot cooler. I always thought that you just added it to your coolant. I have never drained the coolant to add that stuff before. Let us know how it goes.
Old 07-09-2010, 09:11 PM   #6
firefighter1
firefighter1's Avatar
Drives: 625 rwhp red jewel ss COTW 11-8-10
If I rememer correctly 1 12oz bottle treated an entire 3 to 4 gallons which would be about 11 to 12 quarts. So you shouldn't have to drain the system. Just remove about 12 oz with a turkey baster and replace with the water wetter. If you need a 12 oz measuring device I have about 30 in a handy carrying case you can borrow when I'm done!
firefighter1 is offline   Reply With Quote
