Merritt
Drives: 2010 Synergy Green Camaro Join Date: Jun 2010
CEL with Doug Thorley Shorties??
Are people getting the same CEL with the Doug Thorley shorties as the people with the JBA's? Are the Doug Thorley's having the same "sealing" issue? I am trying to decide which of the 2 to buy.
Merritt
![]() 2010 Synergy Green, Airaid V2, MRT V2, DT Shorties, Eibach springs and sway bars, ???? |
Mike and Debbie
Drives: 2014 Corvette Stingray 3LT Z51 Join Date: Mar 2010
About 100-150 miles on my DTs with no CEL
Drives: '15 Z06, '01 NBM SS, '97 SS Join Date: May 2009
Not one CEL from any of the first group...correct me if I'm wrong guys and gals.
JBAs are getting blasted with sealing issues. I have yet to take a call on a set of DT V6 Shorties that have had the same issue. Let er rip!! Doug Thorley V6 Shorties info on the Sponsor Marketplace Bolt ons thread. -Ivan |
![]() Drives: Synergy Camaro, Escape Join Date: Feb 2010
How much are these costing to get put on?
![]() Drives: 2010 Camaro 2LT CGM, IOM Int. Join Date: Mar 2009
Over 1,000 miles on mine. No CEL.
#6 |
![]() Drives: Victory Red 2lt RS V6 auto Join Date: Mar 2010
Forgive me for not sticking to the subject here guys, but how much do the DT shorties cost? I almost have enough for my CAI and was having these headers in mind for my next mod. I've read somewhere on this forum that a fellow member had this problem after installing long tube headers if I'm not mistaken.
#7 |
![]() ![]() Drives: 2006 White Corvette Convertible Join Date: Feb 2010
350 shipped... and around 350 or so to install, depending on where you take it.
The Corvette is an animal.
#8 | |
These retain the factory Cats. -Ivan |
#9 |
Whats a Millwright?
Drives: 2LT/RS SIM, 05 Wht Denali Join Date: Feb 2010
The DT should not get the code issues the JBA's are getting because of the weld from header to cat. The JBA's have a "stacker" flange that is the cause of the leaks which causes a CEL to appear. There are a cpl people who have had no issues with the JBA and then there is a few , like me, who have resolved the issue. The DT's however are not as "Do It Yourself" friendly as the JBa are. Just be sure you choose a trustworthy shop to do the welding on your pipes and you should have no problems with the Doug Thorley headers.
#10 |
Drives: White 2010 RS/SS Join Date: Dec 2009
The JBA's don't through a cel if they are installed correctly.
#11 |
![]() Drives: '10 Camaro LTRS, '12 Pro4x Frontier Join Date: Jul 2009
On the SS you probably are not seeing any CEL. There are a lot of V6 people including myself that are having difficulties with the JBA's working without throwing a Check Engine Light. Mainly because of what Mankind stated the stacker flange is leaking.
#12 |
#13 |
NEcamaro5
If you can weld and have the welder it's not that bad .removing the manifolds and installing the header is just time consuming .there's one bolt on each header that's a pisser .One cool thing is atleast the bolts come off easy do to it being new.
#14 | |
Has anyone done a dyno with the DT shorties? Just curious what (if any) gains people are getting from them. |
| Doug Thorley headers and axle-back ROCKS! | SPANKT U | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 13 | 01-07-2010 10:36 AM |
| Doug Thorley Shorties Installed | WadeWilson | Camaro Photos | Spyshots | Video | Media Gallery | 15 | 12-13-2009 06:45 PM |
| Anyone have Doug Thorley shorties L99 dyno results? | AntivenomSS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 0 | 11-10-2009 11:44 AM |
| Doug Thorley shorties install questions | ssmike | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 27 | 10-26-2009 12:49 PM |
| Doug Thorley Shorties w/ GMPP Mufflers (video) | Rallyman6 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 23 | 07-23-2009 08:25 PM |
