Old 07-22-2010, 04:09 PM   #1
tytus03
Drives: F150/2010 camaro 2ss blk ls3
10% Ethanol Fuel ?
suddenly around here all the gas stations say "up to 10% ethanol" will that hurt the camaro?
tytus03 is offline   Reply With Quote
Old 07-22-2010, 04:13 PM   #2
tw3ss
Drives: 2010 2SS/RS A6 SW/IOM
NO its everywhere.
tw3ss is offline   Reply With Quote
Old 07-22-2010, 04:16 PM   #3
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Unless you're in a special place, gas has always had 10% ethanol in it. At least for the last MANY years.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 07-22-2010, 04:18 PM   #4
Gunmetal
Gunmetal's Avatar
Drives: Cyber Grey 1SS/RS w/Body Kit
same for Illinois and Missouri
Gunmetal is offline   Reply With Quote
Old 07-22-2010, 04:24 PM   #5
ramar
2nd Childhood
ramar's Avatar
Drives: Synergy Green
We had trouble with our Bass Boat motor using the gas here in Missouri. Also any small engines, lawn mowers etc. I think ethanol eats the rubber, at least the gaskets on the boat motor had to be replaced. Anyway mechanic told us to put in the 91 octain this one gas station sells in town that has no ethanol. I started to put that gas in my V6 camaro and my gas mileage has improved and the car seems to run better. We now put the higher octane in everything we have except the Flex Fuel Avalanche. No issues for over a year where we had problems before.
ramar is offline   Reply With Quote
Old 07-22-2010, 04:44 PM   #6
cybercoaster
cybercoaster's Avatar
Drives: 2017 2SS 50th Anv, 1972 RS
I only use 100% gas (still around here) at 91 octane. The user manual says you can use ethanol but not E85 or more then 10% ethanol or methanol (eats rubber etc.).
cybercoaster is offline   Reply With Quote
Old 07-22-2010, 05:32 PM   #7
fee5fofum
fee5fofum's Avatar
Drives: 2012 CTS-V Coupe & 2SS/RS
This should help you find Ethanol -Free Gas Stations in your State/Area :
http://pure-gas.org/index.jsp
Hope this info helps...
fee5fofum is offline   Reply With Quote
Old 07-22-2010, 06:51 PM   #8
Rockhead
Hoser.
Rockhead's Avatar
Drives: 2018 Z06
Originally Posted by tw3ss View Post
NO its everywhere.
Yup just like mustangs.
Speed is a substitute for clearance.
Rockhead is offline   Reply With Quote
Old 07-22-2010, 07:12 PM   #9
Markushi
Drives: a beater :(
Wow, there is none in Michigan.
Markushi is offline   Reply With Quote
Old 07-22-2010, 08:29 PM   #10
hollywoodjose
hollywoodjose's Avatar
Drives: 2010 Black 1LT
there's none in the places i go the most here in WA, would it be bad to switch back and fourth? like since there's only a couple places I go that have it and all others dont.
picked up 5-13-09 1LT, C&C, Sunroof, 19" p.a.wheels, lloyd mats, tinted windows, gill inserts, ralley stripes
hollywoodjose is offline   Reply With Quote
Old 07-22-2010, 08:33 PM   #11
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Not at all. All vehicles from 1985 on have been designed to accept at least E10 blends.
Originally Posted by hollywoodjose View Post
Would it be bad to switch back and fourth?
Nope. The car's don't have sensors to know the difference, they'll burn it just like pure gas.
Old 07-22-2010, 11:03 PM   #12
Dalefj
Drives: 2017 Camaro 2ss
If you can find pure gas buy it!!! Yes e10 will not actually hurt the car but the motor will run better off of real gas and will get better MPG and more power. Keep the alcohol at home not in your car.
Dalefj is offline   Reply With Quote
Old 07-22-2010, 11:54 PM   #13
axis
Search Ninja
axis's Avatar
Tell that to the FI guys. They make MONSTER power with E85.
Halltech CF 102 fed
Old 07-23-2010, 08:09 AM   #14
x626xBlack
ARMY of one.
x626xBlack's Avatar
Drives: 2011 Black SS/RS
I suspect the 10% did not just show up recently, you just noticed it recently. Or someone decided to put the labels on the pumps.
x626xBlack is offline   Reply With Quote
Stock Injectors vs Magnuson Kit Injectors Mark-HD Forced Induction - V8 24 01-27-2010 08:04 PM
Why i think you cant do a Dyno in the same day 2SSRS@Gen5diy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 123 10-22-2009 07:37 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 05:29 PM
Americans unwilling to pay for big fuel economy gains, carmakers say Scotsman General Automotive + Other Cars Discussion 7 04-18-2008 12:27 PM
