Old 07-23-2010, 08:20 PM   #1
aet08
Drives: c
Exclamation Please help! - L99 + Vortech (V-3 si) + 3.33 pulley + Kooks full (1 7/8" headers, 3")
from forum post: http://www.camaro5.com/forums/showthread.php?t=96246
I originally installed the Vortech V-3 Si kit on my L99 (Automattic V8 w/ VVT) and got an amazing 170HP increase over stock. Putting me at 483 RWHP.
I wanted more HP so I ordered the following:
-Kooks full exhaust package 1 7/8" headers, hi flow cats, xpipe, mufflers, 3" piping.
-Vortech Fuel Pump Voltage Booster
-Vortech 3.47 and 3.33 pulley.
-Custom Tune by Vortech
After the following upgrades I only got 20 HP increase! Putting me at 503 RWHP
I can't seem to get the boost over 8.8PSI. We removed the idler pulley and the belt is on TIGHT AS ALL HELL. We checked for air vacuum leaks and there are no leaks.
The first pull we did produced 530HP but we have not be able to get similar results after that.
We think it might be the VVT kicking out the extra boost. If this is true is it possible to tune this out?
Can someone please help out, I'm hurting over here.
This dyno is with a 3.47 pulley, showing PSI boost
The following dynos are with a 3.33 pulley (at/close sea level altitude)
aet08 is offline   Reply With Quote
Old 07-23-2010, 08:31 PM   #2
Huck1974
Drives: 2011 2SS
More experience with procharger, but I would check for belt slip even though it is tight. Buy a gatorback. Check for a leaky BOV.
Huck1974 is offline   Reply With Quote
Old 07-24-2010, 12:14 AM   #3
Mike@RMCR
Mike@RMCR's Avatar
Drives: Supercharged
Sounds like a possible timing problem. Also check boost with a known good mechanical gauge. Sometimes boost gauges can read off if they have never validated the calibration.
Also I would check for a blown pipe that has came apart. Sometimes they are easy to miss.
If you want have your tuner call me on Monday. We will get this worked out for ya. No need to sweat it. Sure its a simple fix.
Last but not least. Dyno's are only a tuning tool. Dont get distracted by #'s. All dyno's read differently even when they are the same brand.
What was your baseline HP?
Hope this helps.
Mike@RMCR is offline   Reply With Quote
Old 07-24-2010, 12:49 AM   #4
aet08
Drives: c
My rwhp before the addons was 483 then 503 on the same dyno machine.
We tried manual boost gauge and it was the same.
I'll have Sean give you a call Monday.
Thanks mike
Old 07-24-2010, 08:19 AM   #5
JANNETTYRACING
JANNETTYRACING's Avatar
Your in California, you have an L99, you are on 91 octane fuel, all you should expect is 503 with a 3.33 pulley.
With 93 octane and 3.33 pulley, on L99s we see 525 RWHP consistantly fully warmed up.
When you make the first pull with a Vortech it can be artificially High because everything is cold, I have seen this many times, I throw that Dyno sheet out and work with the ones that repeat over and over.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 07-24-2010, 11:00 AM   #6
aet08
Drives: c
That still doesn't explain why the boost is so low. I should be getting 9.5 to 10psi at my altitude.
20hp increase after adding 5k worth of upgrades? It's like WTF
I'm pretty sure it's directly related to the boost being low. It's gotta be leaking somewhere
Ted.
Old 07-24-2010, 11:01 AM   #7
aet08
Drives: c
You're at sea level right? What PSI you get with 3.33?
Old 07-24-2010, 12:10 PM   #8
JANNETTYRACING
Originally Posted by aet08 View Post
You're at see level right? What PSI you get with 3.33?
8.5
Old 07-24-2010, 12:15 PM   #9
aet08
Drives: c
Would you recommend going down to a 3.12" pulley then?
that should put me around 9.5PSI
Old 07-24-2010, 12:22 PM   #10
JANNETTYRACING
Do you Own a Shovel?
You will need it to pick up the pieces of Piston that shoot out the tail pipes
You will need, Water Meth Injection or Race fuel, and Our MSD FPVB Kit and another custom tune to run that much boost on 91 octane.
Ted.
Old 07-24-2010, 01:11 PM   #11
aet08
Drives: c
ok, Thanks Ted.
Had I known this I wouldnt have spent so much to upgrade the full exhaust and fuel pump for 20 hp.
I still think I can gain more. I have faith in Mike rmcr
Old 07-24-2010, 01:31 PM   #12
general23cmp
Drives: 2010 RS SS
Also keep in mind that the upgrades have improved the flow of the engine and thus increasing boost becomes more and more difficult. That's really not a bad thing either as you can thus make more power at less boost.
Not saying that is the total solution....just something to consider.
general23cmp is offline   Reply With Quote
Old 07-24-2010, 10:42 PM   #13
aet08
Drives: c
what are my options to get more power with my shitty 91 octane? I don't want race fuel
Old 07-24-2010, 11:18 PM   #14
lock
lock's Avatar
Drives: 11 2SS/RS E-Force Supercharged
Can toss in octaine booster on each fill up. Really sounds like you should put in a meth setup.
11 IOM 2SS/RS E-Force Supercharged. 616 RWHP/578 RWTQ. Click link for my journal!!!
lock is offline   Reply With Quote
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3656 11-01-2025 02:41 PM
V8 Camaro Aftermarket Exhaust Video Clips Compilation tjbusa Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 591 07-06-2022 09:38 AM
Headers for an L99 Automatic.....17/8 or 1 3/4 ? Jekyll-N-Hyde Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 34 08-02-2010 02:54 PM
JBA releases exhausts, headers and midpipes. Bewenched Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 09-16-2009 04:04 PM
Kooks 1 7/8" Headers Robert@G-Force Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 34 07-09-2009 09:30 PM
