Old 07-24-2010, 09:48 AM   #1
VenomZ302
Live to Win, Dare to Fail
VenomZ302's Avatar
Splash Guards: A Question About Options
So I've seen RPI's splash guards and GM's splash guards. In some pictures, I like the way GM's guards look, but I'm not sure they'll look all that great on my Aqua Blue Metallic SS. So then I saw the RPI ones and thought they may be a good solution.
So here's my question: can I easily swap between the two guards or would I have to drill different holes or something for each set?
Also, does anyone have pictures (close up and from a distance) of the splash guards (both types)? Especially pictures of them on Aqua Blue Metallic Camaros?
I've seen some pictures around here, but I'd love to see more to help my finalize my decision. Thanks in advance!
3/13/09 - Ordered Aqua Blue Metallic 2SS/RS M6!
7/13/09 - Built!
8/11/09 - Delivered!
2G1FT1EW2A9124579
Old 07-24-2010, 01:29 PM   #2
Sidewinder
Drives: 2SS/RJT/A6/Received 09/09/09
http://www.camaro5.com/forums/showth...75#post2111975
Sidewinder is offline   Reply With Quote
Old 07-24-2010, 03:01 PM   #3
VenomZ302
VenomZ302's Avatar
Thanks for the picture! By the way, do the guards ever scrape against speed bumps?
7/13/09 - Built!
2G1FT1EW2A9124579
Old 07-24-2010, 03:36 PM   #4
Sidewinder
I have not experienced any problems with speed bumps or any other road hazards. Splashguards are not difficult to install and offer some additional protection that is well worth the effort.
Old 07-24-2010, 04:17 PM   #5
jtzako
Drives: 2010 IBM Camaro SS
The ones I have are thing black flaps that do not require drilling/tape etc. They are almost not visible from the sides.
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
jtzako is offline   Reply With Quote
Old 07-24-2010, 04:25 PM   #6
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
RPI's require no drilling and attaches to factory holes.
GM's does require drilling.
Old 07-24-2010, 04:27 PM   #7
rydahog
rydahog's Avatar
Drives: camaro ss
you need to drill one hole in bottom of g.m.'s spash guard.. easy as pie....i dont think your color comes in these however...so far most have used black and does not look bad. that is unless you get them painted yourself to your color..but all in all..they look better then rubber store bought ones....IMHO...
oops..there is one hole to drill in rear bottom of each guard..and 2 holes in front guard...but its NOT like drilling a real hole..its all plastic..
rydahog is offline   Reply With Quote
Old 07-24-2010, 06:45 PM   #8
JJChevy
Drives: SIM 2SS/RS
I got the GM guards and opted to not drill any holes when I put them on. So far, the tape and the two mounting screws already on the car has worked fine.
I've had them on for about two months and no issues. Maybe as time goes on I will have to make corrections but no concerns right now.
JJChevy is offline   Reply With Quote
Old 07-29-2010, 12:45 AM   #9
AZ5G
AZ5G
AZ5G's Avatar
Drives: 2010 Transformer Ed. 1SS M6
I used the GM parts on "B". I dont mind the looks and it's definitely kept the AZ rock chips in check...DD
AZ5G is offline   Reply With Quote
Installed splash guards (1/2 of them) Burnt_RS 5th Gen Camaro SS LS LT General Discussions 47 07-02-2010 08:22 AM
IOM Splash Guards For Sale boatingbent Exterior Parts & Accessories 3 05-10-2010 06:51 PM
Splash Guards?? shishworm Cosmetics and Lighting Modification Discussions 8 03-21-2010 01:40 PM
Splash guards badge removal destroyer4 5th Gen Camaro SS LS LT General Discussions 22 05-11-2009 08:22 AM
2010 Camaro splash guards fit with ground effects? Supercop29 Cosmetics and Lighting Modification Discussions 4 05-05-2009 04:39 PM
