Old 07-25-2010, 06:48 PM   #1
Speaker
Drives: 2011 black SS/RS, w/ ground effects
what is this fuse pull ppl keep talkin bout??
my 2011 is comin in 2 weeks and im not sure what type of gas to put in it. the dealer told me 87 would be fine but not sure if i believe him. and what does it mean to do the fuse pull?
Speaker is offline   Reply With Quote
Old 07-25-2010, 07:14 PM   #2
spyderbuddy
V8 guy's correct me if I am wrong, but the 1SS, 2SS, And 2SS/RS requires 93 octane fuel
The V6 only excepts the lower grades of fuel
Old 07-25-2010, 07:16 PM   #3
gibblet342
Chris
gibblet342's Avatar
Drives: 2010 2SS/RS CGM
http://camaro5.com/forums/showthread.php?t=38964
This is the thread discussing the issue. The V8 needs premium gas, the manual says recommended, but use nothing lower. You will get a knocking sound and will trash your performance.
2010 SSRS - CGM
Nosce Te Ipsum
gibblet342 is offline   Reply With Quote
Old 07-25-2010, 08:00 PM   #4
PHEOX
Drives: '06 Jeep Wrangler
93 octane only, unless you can only get 91. And the fuse pull should only be done if a lower octane of gas is put in.
PHEOX is offline   Reply With Quote
Old 07-25-2010, 09:25 PM   #5
Lucky SOB
Drives: 2010 Camaro 2SS/RS
Only run premium in your V8
Lucky SOB is offline   Reply With Quote
Old 07-25-2010, 09:26 PM   #6
fearless
Drives: 2010 camaro 1ss grey/black
I just did fuse pull today in my ls3 like a idiot first 2 tanks were 87. It feels more responsive and seems more peppy unless its just me wanting it to work haha.
fearless is offline   Reply With Quote
Old 07-25-2010, 09:38 PM   #7
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
Fuse pull is for the L99. The "fix" for the LS3 is a battery disconnect.
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 07-25-2010, 10:14 PM   #8
John Shields
"Back in Black"
John Shields's Avatar
Drives: '10 1LT/RS Black w/Silver Stripes
I have seen a lot of threads on this (ehem, search function is golden)... but none have posted real actual numbers that show any significant improvement. No one that I've read on here actually tested it with a controlled environment. I'd really like to see that, and see if this does in fact make any difference.
To the Jerkoff in SW Denver Driving the Black Camaro:
Quit making us look bad by driving like a tool and cutting people off (my wife included)!
John Shields is offline   Reply With Quote
Old 07-25-2010, 11:51 PM   #9
Pumpkin1LT
I wouldnt say "only accepts the lower grades of fuel".. Perhaps a typo? It will take lower octane without any damage (unlike the SS).. However I have always and only put premium in my V6.
Pumpkin1LT is offline   Reply With Quote
Old 07-26-2010, 12:00 AM   #10
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
It won't knock. You'll be on the low fuel table before you hear knocking.
Depends on what you consider controled. 150 plus timed runs with a 6.2 second 0-60 and a best of 5.9, original fuse pull, first run 5.1, second run 4.9 and averaged 5.2 ever since. Videoed it and used accelerometer.
Old 07-26-2010, 12:06 AM   #11
Sterling
Sterling's Avatar
Drives: 2010 Camaro 1LT/RS M6
You just read it wrong...
What was meant was...
The V6 only... (only the V6)
accepts the lower grades of fuel.
Sterling is offline   Reply With Quote
Old 07-26-2010, 12:22 AM   #12
John Shields
"Back in Black"
No I wouldn't call that controlled. I'd like to see four or more gas fills (2 of each or more I could care less), with both the lower unleaded and then the premium blend. Let the tanks run dry and then fill up and go again. Note the mileage obtained (MPG) and run a controlled drag run and compare.
Then I'd like to see the results of the MPG and if there's any significant difference. The problem is some people say they get better times, or feel a performance difference but of course we get better over time and the vehicle smooths out.
Old 07-26-2010, 12:44 AM   #13
camaroitalia
Go Harder Than Baltimore!
camaroitalia's Avatar
Drives: 2010 CGM
we put in regular, we also have a 2ss and my brother does work on gas lines at the stations. most of the time u pay for premium and ur still getting regular. they dont change it and u only think ur gettin top of the line.
Old 07-26-2010, 07:48 AM   #14
Stormyone
Stormyone's Avatar
Drives: 2010 Camaro 2SS/RS IOM/IOM M6
something about that doesn't sound right.... if it were that simple then someone could test the fuel from either and expose the fraud.... why isn't that happening?
Life is too short to drive a dull car....
Stormyone is offline   Reply With Quote
Fuse Pull on LS3? Atomic Autosports Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 49 08-06-2010 10:37 PM
Anyone tried a Fuse Pull on LS3 95RedCamaroz28 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 09-12-2009 02:33 PM
Does 'fuse pull' work on 6 speed SS? yellow1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 19 09-10-2009 07:28 PM
#230 1 Day After Fuse Pull 0-60 Scott@Bjorn3D Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 21 08-25-2009 08:53 PM
8327 after fuse pull redjewel Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 30 08-25-2009 03:24 PM
