Old 07-27-2010, 02:58 PM   #1
naga
Always be positive!!!
naga's Avatar
Drives: IMB 1ss/ MT
Question What oil to use in the rear Diff
hey guys i was wondering what oil to use in the rear diff and what number?? also what are the torque specs for the rear diff?
Borla ATAK catback/ K&N CAI/ Diablo Tune for now
naga is offline   Reply With Quote
Old 07-27-2010, 03:08 PM   #2
blazzin1
blazzin1's Avatar
Drives: 2010 2SS/RS R6P
I don't have the Owner's Manual in front of me, but it's all in there with the GM part numbers (including the additive). Or some folks are using Royal Purple products, but I'd rather stick with the GM stuff to alleviate any possible warranty issues.
blazzin1 is offline   Reply With Quote
Old 07-27-2010, 03:09 PM   #3
SSLarry
Drives: 2SS LS3
Uh...it's all in the manual, dude. Give it a read.
http://www.camaro5.com/forums/showthread.php?t=33993
Rear Axle (V8 Engine)
Rear Differential Fluid 75W-90 Limited Slip to GM Specification 9986226.
GM Part No. U.S. 89021677 and Friction Modifier 1052358,
in Canada 89021678 and Friction Modifier 992694.
Rear Axle
When to Check Lubricant
It is not necessary to regularly
check rear axle fluid unless you
suspect there is a leak or you hear
an unusual noise. A fluid loss could
indicate a problem. Have it inspected
and repaired.
How to Check Lubricant
A. Fill Plug Hole
B. Drain Plug Hole
To get an accurate reading, the
vehicle should be on a level surface.
If the level is below the bottom
of the filler plug hole, add some
lubricant. Add enough lubricant to
raise the level to the bottom of the
filler plug hole.
What to Use
For 218 mm rear drive module
(RDM) V6 manual, V8 automatic
and V8 manual:
To add lubricant when the level
is low, use 75W-90 LS gear oil
(GM Part No. US 89021677
and 1052358, in Canada
Part No. 89021678 and 992694)
meeting GM Specification 9986226.
To completely refill after draining,
see Recommended Fluids and
Lubricants on page 10-7. Then fill
to the bottom of the filler plug hole
with the Synthetic Gear Lubricant.
For 195 mm RDM V6 automatic:
is low, use 75W-90 gear Oil
(GM Part No. US 89021677,
in Canada Part No. 89021678)
meeting GM Specification 9986115.
SSLarry is offline   Reply With Quote
Old 07-27-2010, 03:16 PM   #4
thedak
416ci - LS3 - 537/501
thedak's Avatar
Drives: 2006 Pontiac GTO
Send a message via AIM to thedak
Torco RGO is titties.
thedak is offline   Reply With Quote
Old 07-27-2010, 03:30 PM   #5
Fishdadddy
Fishdadddy's Avatar
Drives: 2010 2SS/RS ; 1970 Firebird Formula
I'm gonna use Royal Purple
Fishdadddy is offline   Reply With Quote
Old 07-27-2010, 03:32 PM   #6
Blackhawk6
Blackhawk6's Avatar
Drives: Born:18 Sept 2009 #47903
Royal Purple
2010 Camaro 2SS________________________________________Litho#140
Blackhawk6 is offline   Reply With Quote
Old 07-27-2010, 05:32 PM   #7
maxhunter
Drives: 3... (4 now!) camaros and counting
Mobil 1 LS
1978 Type LT, 1981 Z28 project, 1999 Hugger Orange V-6 Car, 2010 2LT RS is FINALLY HERE!
68 Chevelle, 98 Z71, couple harleys
maxhunter is offline   Reply With Quote
Old 07-27-2010, 07:46 PM   #8
naga
naga's Avatar
Drives: IMB 1ss/ MT
hey guys i use royal purple (SAE 5W-30) engin oil on my V8, but I found this behind the bottle and on their web site stating that- Royal Purple Motor Oil delivers superior protection and improves performance in four-cycle gasoline and diesel engines. Does that mean that its only for 4 cyclinder cars and not V8's..
Old 07-27-2010, 07:48 PM   #9
naga
naga's Avatar
Drives: IMB 1ss/ MT
If your gonna use royal purple why did you go with Mobile 1 engin oil... Im just asking cause i saw an awesome oil change that you did on your car few weeks ago..
Old 07-27-2010, 07:48 PM   #10
naga
naga's Avatar
Drives: IMB 1ss/ MT
Rear Axle
and repaired.
A. Fill Plug Hole
B. Drain Plug Hole
filler plug hole.
What to Use
and V8 manual:
Thanks for the Infor helpped alot...
Old 07-27-2010, 09:00 PM   #11
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
Really???? 4 cycle not 4 cylinder.
ackeight is offline   Reply With Quote
Old 07-27-2010, 09:31 PM   #12
naga
naga's Avatar
Drives: IMB 1ss/ MT
I looked it up and it says that 4 cycle is FOUR-STROKE ENGINE.. so what you mean that 4 cycle not 4 cylinder!!!
Old 07-27-2010, 09:42 PM   #13
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
Yes your v8 is fine with that in there. That is what I wrote. Suck squeeze bang blow= 4 cycle.
Old 07-27-2010, 10:05 PM   #14
naga
naga's Avatar
Drives: IMB 1ss/ MT
awesome thanks man!!!!
Oil Changes Dave McFly Off-topic Discussions 6 05-18-2010 05:50 PM
Oil Change Ramp mjlash22 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 17 01-21-2010 11:40 PM
Suspension guys out there - lets talk wheel hop Crowley Suspension / Brakes / Chassis 14 10-09-2009 01:06 AM
