Old 08-01-2010, 09:59 AM   #1
JS
JS's Avatar
Drives: 2010 Camaro SS
LS3 doesnt seem to have alot of H/C guys?
LS1 had many H/C combo's over the yrs..
Doesnt seem that many Camaro owners are going H/C setups
WHERE ARE YOU GUYS
SOLD
2010 Camaro 1SS/A6
12.59@111.31
Magnaflow Magnapack Axleback & Resonated X-Pipe/OBX LT Headers/Airaid Cold Air Kit/Injection Connection Tuned
JS is offline   Reply With Quote
Old 08-01-2010, 10:10 AM   #2
JANNETTYRACING
JANNETTYRACING's Avatar
WHERE ARE YOU GUYS
Tough to justify the cost of cylinder heads when the LS3 Heads are SOOOO Good.
There really isn't much room for improvement on the LS3 heads, Unlike the LS1s that have a lot of room for improvement.
LS1 made 320 hp
LS3 makes 425 hp that is a Huge difference which makes it harder to improve on.
Our Untouched LS3 Long Block is making 742 RWHP so Why take it apart?
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 08-01-2010, 10:19 AM   #3
JS
JS's Avatar
Yes we have made over 650RW so far with FI & cam using tock heads too...
Never really thought about it but I guess your right Ted, just not worth the expense as the gains arent that good?
Looks like a Maggie and cam setup will suffice
SOLD
2010 Camaro 1SS/A6
12.59@111.31
Old 08-01-2010, 10:29 AM   #4
dmax86
dmax86's Avatar
Drives: 2016 Z06 C7R
right cheer!
2013 ZL1 BONE STOCK! LOL
dmax86 is offline   Reply With Quote
Old 08-01-2010, 12:05 PM   #5
OrangeChevyII
Drives: 2010 RS/SS2
WHERE ARE YOU GUYS
With the G6x3 cam I made 495 with a stock crank pulley, 538 with Lg stage 2 heads.
Check sig
2010 SS/RS SIM
First to run 11's (11.83)on a stock long block.
First to run 11's cam only
First to run 11's all motor
First to run 10's (10.96) and did it with a 100% bonestock long block and a power adder (nitrous)
First to run 10's (10.55) on motor in 2010 Camaro
First to break into the 5's (5.97) 1/8th mile
First to cut a 1.5X sixty foot
First to cut a 1.4x sixty foot
First to car to cut a 1.3x 60ft
OrangeChevyII is offline   Reply With Quote
Old 08-01-2010, 12:19 PM   #6
Josh @ Spartan LSX
Josh @ Spartan LSX's Avatar
Drives: A wrench
I've done 4-5 LS3/L92 heads/cam setups so far. The porting on these heads is usually worth around 20-25, not nearly as substantial as the older LS heads that could pick up 60rwhp.
Josh @ Spartan LSX is offline   Reply With Quote
Old 08-01-2010, 02:44 PM   #7
JS
JS's Avatar
We have made 500RW in a couple of 2010 C6 with a cam only setups too
Still a solid 25RW wouldnt be a bad upgrade..
We only saw 4RW from a LSXR102 which imo was not too good.
The LSXR seems to help a FI setup but doesnt do much on a stock cube NA setup.
SOLD
2010 Camaro 1SS/A6
12.59@111.31
Old 08-01-2010, 08:19 PM   #8
Slowhawk
Drives: 1999 Trans Am
There are some H/C cars around. Alot of people just don't post on boards (they do read them though). As you know JS,it's not about the peak hp #'s,it's about the average power. With a set of good head work you can gain alot across the board.We like to get the work done,mill them to alot higher compression and run a small cam.Stock drivabilty (as low as 1100rpm in 1st gear) with a good power of 500hp/450-470tq and peak at 6200rpm.You could also go all out and hit 550hp but I'm not a fan of how the cars drive in traffic.
Slowhawk is offline   Reply With Quote
Old 08-02-2010, 12:03 AM   #9
JS
JS's Avatar
Thanks Don, as always a logical answer from your lips
SOLD
2010 Camaro 1SS/A6
12.59@111.31
Old 08-02-2010, 01:50 AM   #10
LC
ou mai gad
LC's Avatar
Drives: SW 2SS x2
I have the small bore LS7s under my desk.. gathering the small stuff to install them on the LS3...
LC is offline   Reply With Quote
Old 08-02-2010, 09:33 AM   #11
Josh @ Spartan LSX
Drives: A wrench
This is exactly how I like to build them. Simple, effective, easy to tune, power everywhere.
IMO, these cars need compression and TQ to effectively move around 4000lbs + driver + huge wheels + shitty 3:45 gearing.
Old 08-02-2010, 12:41 PM   #12
JS
JS's Avatar
Totally agree with Don and Damian..
We have been running a 220's-230's 600's 113 to 116 cam setup in these cars
Great drivability and power threw the rpm...
SOLD
2010 Camaro 1SS/A6
12.59@111.31
Old 08-02-2010, 01:35 PM   #13
bi11ymc
"Silver Street"
bi11ymc's Avatar
Drives: 2010 2SS/RS L99
Something like this for a TVS 2300 setup? 223/231 .610/.617 115+4
Silver Street - 2010 Camaro 2SS/RS, SIM, Gray, Cyber Gray Rally Stripes, Polished Wheels, Automatic (L99) - 553 RWHP/510 RWTQ
CAI Inc., ARH LT Headers with Cats, Borla Touring Cat-Back; Pfadt Coil Overs, Sway Bars, End Links, and Trailing Arms; Comp Cams Blower Cam, Dual Springs, Push-Rods, and Lifters; GM LS2 Lifter Trays, 6.2 MLS Head Gaskets, Crank Bolt, and LS2 Front Cover; 3-Bolt Conversion Timing Gear, Katech C5R Timing Chain, ARP LS2/LS3 Head Bolt Kit, Melling Hi Volume Oil Pump, TVS 2300 Supercharger (Black); Build by Vengeance Racing; Custom Tune by Vengeance Racing
bi11ymc is offline   Reply With Quote
Manual vs Auto GTAHVIT vs PQ... The video wars. 76z28 5th Gen Camaro SS LS LT General Discussions 443 08-26-2010 01:26 PM
Engine Dyno Testing LS3 Intakes INSIDE!! LS3 vs Ported vs FAST Jason 98 TA Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 10-01-2009 01:55 PM
LS3 Engine Dyno LSA Comparison Data Inside!! Jason 98 TA Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 09-14-2009 09:26 PM
Advice---Supercharged L99, S/C'd LS3 or LS9? CamaroZR1 Forced Induction - V8 25 09-25-2008 10:21 AM
5th Gen Camaro LS3 info from Chevy Hi-Po...READ TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 295 03-07-2008 11:06 AM
