Old 08-02-2010, 11:19 AM   #1
mcdoogle6969
mcdoogle6969's Avatar
Drives: 2010 Camaro SS, 2008 Heritage 300C
Is Nitrous safe?
I was looking at getting a bottle for a 100-150 shot on my Camaro, mods so far are 2" x 3" LT ARH's, intake, and exhaust.
I heard from a lot of people in my town that Nitrous is pretty much taking a sludge hammer to your motor, so I decided to ask the people who will know more then them, you guys.
So pretty much the question is, is Nitrous safe??
mcdoogle6969 is offline   Reply With Quote
Old 08-02-2010, 12:09 PM   #2
tony1
tony1's Avatar
Drives: 2SS/RS Vortech/L99
NO!!!
tony1 is offline   Reply With Quote
Old 08-02-2010, 12:19 PM   #3
DEW
Drives: Hoopdee
It better be, my dentist gives it to me every visit!
2LT - CYBER GRAY METALLIC - BLACK RALLY STRIPES - MANUAL TRANNY - POLISHED 19" WHEELS
BUILD - 6/12/2009
Airaid V2, Flowmaster AT
DEW is offline   Reply With Quote
Old 08-02-2010, 12:30 PM   #4
silverfox
silverfox's Avatar
Drives: 2010 camaro ss
Do a search on youtube for nitrous explosion. Pretty scary!
[SIGPIC][/SIGPIC]Va.Speed built 427 stroker
LS2 Darton sleeved 427 stroker.Callies dragonslayer crankshaft. Callies I beam rods. Wiseco blower pistons. Mast cnc 12 degree big bore ls3 heads-2.2 intake &1.6 ex. 6 bolt 270cc-.750 deck. Lunati link bar lifters.T&D roller rockers.COMP-VA. Speed special cam 605 lift, 238dur. Procharger F1R @15psi. ARH headers with custom 3'' exhaust all the way.Magnaflow mufflers. QTP cutouts.Rossler built 6l80e trans. DSS 1400hp axles.
Pfadt suspension.-Coilovers, sway bars,motor mounts,trailing arms. Aeromotive eliminater pump.
907rwhp.
silverfox is offline   Reply With Quote
Old 08-02-2010, 12:33 PM   #5
boostedyards86
boostedyards86's Avatar
Drives: Cummins 3500
yes and no. do ur research. dont buy cheap parts, and take it to a competent and experienced nitrous tuner.
85 Buick TType - 5.3l GT4202r 10.86 at 126
boostedyards86 is offline   Reply With Quote
Old 08-02-2010, 01:10 PM   #6
LC
ou mai gad
LC's Avatar
Drives: SW 2SS x2
just be sure to keep an eye on timing... my cars knock on stock timing..
too much timing + nitrous = invisible pistons...
LC is offline   Reply With Quote
Old 08-02-2010, 01:34 PM   #7
JANNETTYRACING
JANNETTYRACING's Avatar
It is up to the operator and installer.
If you don't know Everything about NOS then don't mess with it.
I am not Against it, I run it in my car, but it is not for everyone.
Supercharger is Dead Reliable and you never have to refill a bottle.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 08-02-2010, 01:49 PM   #8
boostedyards86
x2
Old 08-02-2010, 02:06 PM   #9
Dave Coyle
Dave Coyle's Avatar
Drives: 2010 SS , 1970 Z-28, 2002 Avalanche
If you set it up the correct way it is very safe and reliable!!! The key is to set it up the right way. Make sure you have an up dated fuel system the will maintain at least 4 psi at wide open throttle with the NOS ingaged. Any thing less than 4 psi of fuel and you will run a "rich" NOS mixture and that is where you will get a piston melt down. I ran a 150 HP shot in my Z-28 on a 327 ci for 8 years and the only thing I had to do was after 5 years and over 30 bottles the valves started to reciede into the heads, not because of the NOS but because they were "old" camel hum heads that were not set up to run unleaded. While I had her apart I decided to freshen up the bearings and to my surprise they were as good as the day I put them in. I still changed the bearings but really did not need to and the "forged" pistons looked great! You don't need forged at NOS levels of 125 or less and some say that with the new pistons of todays standards you can run up to 150 HP shots. In fact, the only reason I pulled that motor was because I built and 468 Ci. rat that run the same numbers as the 327 only I didn't have to use NOS which is getting harder to find shops to fill and the cost for the NOS is getting up there too.
Just my 2 cents on it.
IF IT'S WORTH HAVING, IT'S WORTH WAITING FOR!!!! (AND IT WAS)
434RWHP/403RWTQ
Livernois Motorsports 2C Cam kit
Kooks 1 7/8 LT Headers/Hi-Flo Cats/Corsa Exhaust
Roto-Fab CAI / Port Intake
Precission 2400/2800 Converter/3.73 AAM gears
Livernois Motorsports Tune
Best time: 11.97 @ 117 MPH
Dave Coyle is offline   Reply With Quote
Old 08-02-2010, 02:55 PM   #10
Rshep
Drives: 2010 SS
if it is done right it is the cheapest way to gain horsepower, do it wrong and it can be the most expensive. I had it on my 4th gen and it was awesome.
Rshep is offline   Reply With Quote
Old 08-02-2010, 03:03 PM   #11
mcdoogle6969
Ted.
I would go the blower route, but a nitrous kit is around 600 bucks then however much the installation and tune would be. A blower is 8 grand and however much installation and the tune would cost. I can't afford that, at all.
Old 08-02-2010, 03:04 PM   #12
LC
ou mai gad
LC's Avatar
Drives: SW 2SS x2
you are going to spend it on refills anyway...
at least here.. at 50 bucks a refill.. it adds fast!
Old 08-02-2010, 03:19 PM   #13
Granatelli
Drives: 2SS Victory Red
Nitrous is safe - You just need to pay attention. As an example, most people do not realize Nitrous wants to go into the engine at 900 to 1100 psi. To low and the power you want is really not there plus the fuel can hurt the rings to much Nitrous pressure and there is not enough fuel to compensate so the nitrous eats the rings
You can’t go wrong with a 120hp Nitrous kit - it is definitely the poor mans way to make a quick hundy.
Most off the shelf systems do not include the proper Gauge to check pressure so buy 1 of those. Then you will need a nitrous bottle heater. The bottle heater keeps the Nitrous at 900 to 1100 psi. I also recommend a good window switch. The window switch tells the nitrous when to turn on and off. Do not just rely on WOT - you need that too but the RPM window switch is a huge help
Check out this video and how too
http://www.gmsvideos.com/video/2722
http://www.gmsvideos.com/video/2689
http://www.gmsvideos.com/video/7598
Granatelli is offline   Reply With Quote
Old 08-02-2010, 03:44 PM   #14
mcdoogle6969
That's some really neat information! Thank you!
Nitrous info CamaroSpike23 Forced Induction - V8 65 03-19-2020 09:22 AM
Introducing the Nitrous Outlet 2010 Camaro Nitrous System! Nitro Dave Forced Induction 33 04-17-2010 09:01 PM
Nitrous Outlet 2010 Camaro Nitrous System and Accessories! Nitro Dave Forced Induction 9 11-27-2009 12:49 AM
Nitrous Info Milk 1027 Wiki 0 08-12-2009 07:26 PM
