Old 08-03-2010, 01:19 PM   #1
Chad's ZL1
THERAPY
Chad's ZL1's Avatar
Drives: Red Rock Metallic ZL1
How to take off front bumber with ground effects?
The other day I was going to take off my front bumber to get it repainted and was able to get to every single bolt to loosen it up except for the two bolts underneath the front bumper. I have ground effects on my car so there are two holes in the ground effects where the bolts are but the holes are smaller than my sockets. Anyone dealt with this. Advice would be greatly appreciated. I was told that I did not have to take off the front ground effects to get to the two bottom bolts. Thanks in advance!
Chad's ZL1 is offline   Reply With Quote
Old 08-03-2010, 01:30 PM   #2
UT-Engineer
Just Cruisin'
UT-Engineer's Avatar
Drives: 2010 Synergy Camaro
im guessing the GFX for the SS are different than the V6 correct? I have a V6 and my GFX are bolted all the way around but also rivited in near the center so there isnt a way for me to remove my GFX after the dealer installed them. Agian, the SS may be a different set-up, not sure....
2010 Synergy Green Camaro
25% Tint - CGM Painted GM GFX - 20" Niche M102 Wheels
UT-Engineer is offline   Reply With Quote
Old 08-03-2010, 01:35 PM   #3
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
No, he wants to remove the whole front bumper, but can't get to the last two bolts on the underside of the car (towards the center, right?) because the holes in the GFX where those bolts are located are too small to fit his socket set through.
Chad, you may need to widen out those holes, but IIRC, the ground effects were supposed to be drilled with 1.25" holes using a hole saw when installed. I can't imagine a socket that's bigger than that...
Maybe the installers didn't make the hole the right size?
My VIN = 2G1FK1EJ9A9105017
Old 08-03-2010, 03:10 PM   #4
Michael_Js
SoCal C5 Family Member
Michael_Js's Avatar
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M
Send a message via AIM to Michael_Js Send a message via MSN to Michael_Js
This may not help, but...
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; ********; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers;
Michael_Js is offline   Reply With Quote
Old 08-03-2010, 07:57 PM   #5
Chad's ZL1
THERAPY
Chad's ZL1's Avatar
on the diagram it's figure 42. Those are the two bolts that I can't get to because of my ground effects. I sure hope I don't have to drill those holes any bigger. I don't want to mess up the painted ground effects. I don't even have a scratch on the underside of it. Thank you guys
Camaro Ground Effects Memo 7/7/09 - proper installation tips CamaroScotty Camaro DIY & HOW-TO instructions & discussions 40 06-14-2010 08:13 AM
Wanted: Front Splitter for factory ground effects Blue70SS Exterior Parts & Accessories 5 03-09-2010 12:58 AM
Autoblog drives V6 Camaro w/ ground effects and GMPP wheels. Shares public reaction. Tran 5th Gen Camaro SS LS LT General Discussions 1 07-13-2009 11:17 AM
For those of you who have ground effects sledhead 28 5th Gen Camaro SS LS LT General Discussions 5 07-03-2009 01:25 PM
Ground Effects (ground clearance) cerberus 5th Gen Camaro SS LS LT General Discussions 9 06-14-2009 05:10 PM
