Old 08-08-2010, 08:54 AM   #1
Strokedhog
Strokedhog's Avatar
Drives: 2010 2SS M6 Black
Billet Prototypes Catch Can Installed
These are pix of the Billet Protoype Catch Can installed. I mounted on an L brackest to the bolt that holds the fans and shroud in place. This is the amount of oil collected after only 150 miles of driving. The engine has 4000 miles total and I feel the blow bye and oil seems excessive. Who knows how much has slopped up the intake. Gonna contact the dealer I will follow up.
Strokedhog is offline   Reply With Quote
Old 08-08-2010, 09:20 AM   #2
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
You happen to know the capacity of that catch can ? Looks "smallish" in the pictures . Thanks.
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 08-08-2010, 10:01 AM   #3
Strokedhog
Strokedhog's Avatar
Not sure a guess would be 12 oz. about the size of a soda can. That would be the bottom or the resivoir. However it does work.
Old 08-08-2010, 06:54 PM   #4
The Stig
knows 2 facts about ducks
The Stig's Avatar
Billet catch can holds one (1) quart if I remember correctly
Click to view my build thread
Old 08-08-2010, 09:13 PM   #5
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
There's no way that's a quart sized can. I would guess 12-16oz at best.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 08-09-2010, 12:28 AM   #6
Jaysin
Jaysin's Avatar
Drives: 2015 Chevrolet SS
I like where you've installed this. Thanks for the idea.
Jaysin is offline   Reply With Quote
Old 08-09-2010, 02:58 PM   #7
eggydoo
Drives: 2010 Camaro SS
agreed..mine is way on the other side...
Will prob change location tonight.
eggydoo is offline   Reply With Quote
Old 09-09-2010, 04:03 PM   #8
Team NoviStretch
Drives: Camaro
Do you mind sending me some more pictures? I have never even considered that location yet. What did you have to do to fit it like that? Can you still unscrew the bottom of the can?
Team NoviStretch is offline   Reply With Quote
DIY: PCV catch can install lawdogg149 Camaro DIY & HOW-TO instructions & discussions 57 11-05-2018 05:15 PM
L99 Kenne Bell 2.8L Installed + Pics SonnyakaPig Forced Induction - V8 38 05-17-2010 04:20 PM
Installed RevExtreme oil catch can FFPM73 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 40 03-27-2010 03:10 PM
Elite Engineering catch can finally installed on my LS3 adub4185 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 10 03-26-2010 11:34 AM
Doug Thorleys headers installed norcalwheelman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 34 07-23-2009 12:48 PM
