Old 08-10-2010, 09:02 PM   #1
zero
zero's Avatar
Drives: Black 2SS/RS LS3
high flow cats exhaust leak question
I just installed some high flow cats and was wondering how to tell if there is any exhaust leaks? also anyone have any banging against tunnel brace on LS3, I couldnt check it out as it was dark when I went to try them out.
zero is offline   Reply With Quote
Old 08-10-2010, 09:08 PM   #2
bi11ymc
"Silver Street"
bi11ymc's Avatar
Drives: 2010 2SS/RS L99
I still have the stock exhaust system on my 2 month old Camaro and it bangs the tunnel brace. I haven't bothered to get the dealer to fix it because I am replacing the entire exhaust from end to end soon.
Silver Street - 2010 Camaro 2SS/RS, SIM, Gray, Cyber Gray Rally Stripes, Polished Wheels, Automatic (L99) - 553 RWHP/510 RWTQ
CAI Inc., ARH LT Headers with Cats, Borla Touring Cat-Back; Pfadt Coil Overs, Sway Bars, End Links, and Trailing Arms; Comp Cams Blower Cam, Dual Springs, Push-Rods, and Lifters; GM LS2 Lifter Trays, 6.2 MLS Head Gaskets, Crank Bolt, and LS2 Front Cover; 3-Bolt Conversion Timing Gear, Katech C5R Timing Chain, ARP LS2/LS3 Head Bolt Kit, Melling Hi Volume Oil Pump, TVS 2300 Supercharger (Black); Build by Vengeance Racing; Custom Tune by Vengeance Racing
bi11ymc is offline   Reply With Quote
Old 08-10-2010, 09:33 PM   #3
RedJewel2SS
12.23s@113mph
RedJewel2SS's Avatar
Drives: 2SS/RS, A6, just a few bolt ons
if it is really loose, then you might here a whistling sound.
if it is only slightly leaking, then after a few hundred miles you will see some black soot gathering around the connections.
if you made the connection straight and torqued to specs, you shouldn't have any problems.
RIP Cammie 7/15/2009 - 4/1/2011
RedJewel2SS is offline   Reply With Quote
OK...I'm starting a better V6 exhaust examples thread!! KMPrenger Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 612 09-06-2024 09:00 AM
Solo High Flow Cats Installed Strokedhog Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 1 08-08-2010 03:42 PM
corsa exhaust with high flow cats... what to expect ? mikeSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 07-25-2010 04:44 PM
Tom Henry / Stainless Works Exhaust Video (LT's, high flow cats, X-pipe, S-turbo) TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 92 08-27-2009 04:59 AM
