05-11-2010, 02:25 PM | #113 | |
Drives: Previous '04 SSR; '10 2SS; '16 2SS Join Date: Mar 2009
I can see there is a lot of work for this, but the results will be worth it. I'd be interested in your report on painting the CHEVROLET with a paint pen, as well as seeing pictures of the final product. Good luck as you continue.
2022 LT1, Vivid Orange Metallic.
Order placed 1/25/22 Took delivery 5/28/22 |
05-11-2010, 03:15 PM | #114 | |
Drives: 2010 Camaro 2SS/RS Join Date: Apr 2010
jeff did you use the sharpie paint pen? |
05-11-2010, 07:22 PM | #115 | |
Drives: 2010 2SS/RS, 2006 2500 Silverado Join Date: Dec 2009
"Watch your thoughts, for they become words. Choose your words, for they become actions. Understand your actions, for they become habits. Study your habits, for they will become your character. Develop your character, for it becomes your destiny." |
05-11-2010, 07:29 PM | #116 |
Paint pen, awesome idea
05-11-2010, 09:44 PM | #117 |
Drives: '69 SS Convertible Join Date: May 2009
Just to throw my two cents out there on the paint pen.....
I tried the paint pen myself and it didn't work out so great. The problem I had was maintaining the flow of paint that came out of the pen. A little pressure on the tip and the paint will start coming out really fast. That's what happened to me on a couple of the letters. Then the paint tried to run and was thicker on parts of the letters than others. If you wait even 15 seconds or so to start spreading out the thicker paint it already has started to dry and then gets real clumpy on the letters. I ended up using vinyl letters. It was probably the most expensine part of the whole deal but after sanding and spraying my cover about 4 different times I didn't have the patients any more. I'm not trying to deter you from using the paint pen but just be aware of the issues I had. Plus I would recommned you try to find something similar that you can practice on to get the hang of it.
Build Journal |
05-12-2010, 08:02 AM | #118 | |
She is on Ebay....look at her store. The Chevrolet is like $18 shipped.
Build Journal |
05-12-2010, 08:50 AM | #119 |
As several others have done, I did my lettering with a wide tip sharpie. I taped off the top and bottom of the lettering (but not between them) and then added two coats with the sharpie. It was very easy, didn't run and looks exactly like paint. They come in quite a few different colors at a hobby store. just make sure to get the extra wide one and the flat tip will cover the whole width of the letter in one pass.
2010 Camaro 2SS/RS ( Corsa Catback Exhaust | Vararam | VMAX TB | Custom Tune - 386HP/383TQ)
05-12-2010, 10:30 AM | #120 |
Sharpies come in a rainbow of colors, including white
05-12-2010, 11:20 AM | #121 |
engine cover lettering
OK, having a problem deciding on if to put the "PERFORMANCE DIVISION"
sticker on engine cover. Yes it looks nice, but............... 1. The only performance division GM ever had was the High Performance division, which got canned by the beancounters in 2009. 2. the current performance division is nothing more than a ECO division with more latte sipping gloBULL warmers than real engineers Does anyone know if there is even a Racing or Motorsport division, department, watercooler discussion group left in GM?? Would like to put something on the engine cover that reflected some level of racing heritage or the current GS and GT racing camaro efforts. Any suggestions would be appreciated, thanks. |
05-12-2010, 04:19 PM | #122 |
Living the American Dream
Drives: 2010 Camaro RS/2SS Rally Yellow Join Date: Oct 2008
Just got the painted engine cover back from the painter (again). They did much better this time.
I added a brushed trim ring (from Emblem Pros) to the V8 on the front which looks really good.
Rally Yellow 2SS/RS w/Cyber Gray Stripes
Customer pick-up: June 17 2009 C5 Indiana Camaro Club Central Indiana Camaro Club |
05-12-2010, 07:02 PM | #123 |
Drives: 2010 2SS/RS IBM Join Date: May 2010
05-12-2010, 10:40 PM | #124 |
To be fair, I've only tried the black sharpie, so I'm not sure how the other colors would look. The black came out perfect.
05-12-2010, 10:44 PM | #125 |
Drives: Camaro 2SS/RS and 2001 Ford F250 Join Date: Oct 2009
I want to paint my engine cover and fuse box red. Can I just clean them really good and spray the red or do I need to lay down a couple costs of white first like i've seen some of you do?
05-13-2010, 07:27 AM | #126 |
Jeff - giantsfan said he wants to paint both engine cover AND fusebox cover red. In that case, would you recommend he used white as a primer on both so he's starting with a similar base? That sounds like a good idea to me, but since I'm ultimately painting white, there's no primer for me to use
Thread Tools | |
Similar Threads | ||||
Pfadt Race Engineering releases new Camaro V8 Engine Mounts | PfadtRacing | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 43 | 06-07-2011 12:09 PM |
List of Intakes that will work with the TVS-2300 MagnaCharger | JJ2010 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 26 | 03-19-2010 02:11 AM |
The BEST Break for a new car. "very long" | Darin Morgan | General Automotive + Other Cars Discussion | 346 | 02-04-2010 06:49 PM |
Who is still waiting for their engine cover? | OHIOSS | 5th Gen Camaro SS LS LT General Discussions | 7 | 08-22-2009 11:18 PM |
Camaro ls3 news...true or false? | Dark Knight | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 74 | 06-05-2008 05:29 PM |
