Old 09-14-2010, 09:01 PM   #1
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
2010 Chevrolet Camaro SS: Suspension Walkaround
Found this link . . . good read.
http://blogs.insideline.com/roadtest...alkaround.html
By Dan Edmunds | March 23, 2010
I'm tired of unintended acceleration. I want to get back to talking about acceleration that is fully intended (and appreciated) and the cars that are built to manage it well. What better way to take the automotive equivalent of a Silkwood Shower than a suspension walkaround of our 2010 Chevrolet Camaro SS?
Let's get right to it, shall we?
Up front, there's a coil-over MacPherson strut.
But the lower end does not have the single L-shaped lower arm that most strut suspensions have. Instead, there are two lower links (white), each with its own ball joint, just like the closely-related Pontiac G8 GT.
The front stabilizer bar (green) connects to the strut body via a long, slender link (yellow) for a 1:1 motion ratio.
Like most cars with north-south engines and rear-wheel drive, the Camaro's steering arm (yellow) acts ahead of the axle centerline. The hub carrier it attaches to (white) is aluminum, unlike the Pontiac G8, which uses one made of steel.
Here's a closer look at the dual lower links and their ball joints. The forward one (yellow) comes in from above so that the steering arm can sneak past underneath.
Them's some big brakes - much bigger than the 2-piston sliding calipers found on the front of our dearly departed G8 GT. These calipers (green) are 4-piston fixed units from Brembo. A clump of mass-damping weights (white) have been unceremoniously stuck to them (where they don't show much), presumably to quell a resonant vibration. The ventilated rotors (yellow) are 1-piece cast units.
Out back, the rear multi-link suspension looks very, very similar to that found in the G8 GT. Like the Pontiac, "multi" in this case means three links and one L-shaped upper arm.
Two links (green forward, red aft, behind the shock) make up what amounts to a lower wishbone. The fully boxed upper arm (white) curves off behind the shock to meet its hidden second pivot. A toe-link (yellow) keeps the wheel pointed in the right direction.
Here's a snail's-eye view of the lower links and their wishbonesque arrangement.
Left to right (and bottom to top): forward lower link (yellow); toe link (green); and upper arm (white). The forward upper pivot of the upper arm, a pillow ball, is just barely visible. The rear pivot is a higher volume rubber bushing that's hidden off behind the spring and shock.
The rear lower link does quite a bit of work as the spring/shock assembly and the stabilizer bar connect to it. The shape is slightly different from that of the G8 GT, but it's very close. The stab bar motion ratio looks about the same(0.4:1), but the spring/shock motion ratio looks a little smaller (0.7:1).
Like the front, the Camaro's rear knuckles (yellow) are made of aluminum. Those of the Pontiac G8 GT are steel. They also house ginormous 4-piston fixed Brembo calipers of an open design for easy pad swaps and an external crossover tube (black) to send fluid to the outer pair of pistons.
That'll do.
Front tires: 245/45ZR20 (103Y), weighing in at 63.0 pounds
Rear tires: 275/40ZR20 (106Y), weighing in at 67.5 pounds.
franknbeans is offline   Reply With Quote
Old 09-14-2010, 10:14 PM   #2
sunsfan
sunsfan's Avatar
Drives: 1970 Camaro, 2010 Camaro
nice find some good info and pics.
2010 Camaro & 1970 Camaro
sunsfan is offline   Reply With Quote
Old 09-15-2010, 02:39 AM   #3
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
Very informative. Thanks for the info!
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 09-17-2010, 10:31 AM   #4
JusticePete
Drives: Camaro Justice
You made a valuable post to a link that gives a good overview of the ZETA II suspension. If you found the material interesting I think you will enjoy these two threads.
ZETA II Suspension -- The Book
GM Designs in Chassis Strength / Crash Test Videos
Old 09-19-2010, 03:35 PM   #5
dmiller66
Tampa Gulf Coast Family
dmiller66's Avatar
Drives: '13 2SS/RS, Blue Ray Metallic, Auto
Great article. However, I was a little disappointed when I took off one of my wheel and saw "Made in China" on my "Chevrolet".
dmiller66 is offline   Reply With Quote
Old 09-19-2010, 04:54 PM   #6
khabboub
khabboub's Avatar
Drives: Sold c7, in the market!
is this the same and/or similar to the v6?
khabboub is offline   Reply With Quote
Old 09-19-2010, 05:09 PM   #7
pincoin
Camaro owner since 1982
pincoin's Avatar
Drives: 2012 Camaro 2SS-RS Conv IBM L99
2012 Camaro RS-SS Conv IBM, L99
1968 Camaro RS Coupe 327 AT
1968 Camaro RS-SS Conv, sold 1993
pincoin is offline   Reply With Quote
Old 09-19-2010, 05:54 PM   #8
BLUESMOKE69
BLUESMOKE69's Avatar
Drives: Saturn Astra 08
Keep the lessons coming!!! Super Cool Stuff!!
FORTIS CADERE, CEDERE NON POTEST
BLUESMOKE69 is offline   Reply With Quote
Old 09-19-2010, 06:39 PM   #9
Tech
Tech
Tech's Avatar
Drives: 2010 Camaro 2SS
Send a message via AIM to Tech
thanks for taking the time...now to replace 90% of it with aftermarket parts!
Tech is offline   Reply With Quote
Old 09-19-2010, 06:57 PM   #10
franknbeans
Whipped
Drives: 2010 CAMARO
Nice, my second homepage post.
Old 09-19-2010, 07:09 PM   #11
iPODFAN11
iPODFAN11's Avatar
Drives: 2019 Shock ZL1
Saw the same on a 2010 Equinox. Emailed Chevy...
...got this in response...
Thank you for contacting us recently regarding outsourcing of parts. We appreciate you advising General Motors of your concerns and providing us the opportunity to review them, as we recognize individuals have many different views.
General Motors is present in different parts of the world. That’s what makes GM a global company, and as such, utilizes manufacturing capabilities overseas. Rest assured that our vehicles are as reliable as any products on the market. At General Motors, we have such confidence in the vehicles that we produce that we provide a comprehensive warranty to protect our customers. We constantly monitor current procedures to ensure quality is built into all of our vehicles. We also watch closely for technological innovations which may be utilized in improving and reinforcing the quality of our products.
We have documented your concerns and will forward your comments to the appropriate department. Your thoughts and opinions are very important to us. Thank you again for taking the time to let us know how you feel.
Sincerely,
The General Motors Consumer Support Team
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
we're certainly looking at it -- but right now, the emphasis MUST be on getting the Camaro V6 and SS out -- and having it exceed your expectations....
Once that's done....................
iPODFAN11 is offline   Reply With Quote
Old 09-19-2010, 07:38 PM   #12
wrbear
Banned
Drives: 2010, 2SS, IOM/CGM Stripes, 4/24/10
You the man!
wrbear is offline   Reply With Quote
Old 09-19-2010, 09:11 PM   #13
mdinferno
mdinferno's Avatar
Drives: 2010 IBM 2LT/RS
excellent post
mdinferno is offline   Reply With Quote
Old 09-19-2010, 11:46 PM   #14
JoeFire
JoeFire's Avatar
Drives: 2010 2SS/RS Transformers Edition
Great post. It's always nice to learn more about what we drive around in.
2010 2SS/RS Transformers Edition w/ sun roof. Delivered 7 Dec 2009
2012 Transformers bumper vinyl| Rear tire vent vinyl by SLP|Airaid CAI|Kooks headers w/ high flow cats, Borla S type cat back| Customized tune from Lew, Dyno'd 421HP and 375TQ at 4600' and 82ºF
JoeFire is offline   Reply With Quote
Does the v6 have enough power? cstproductions Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 305 08-29-2012 09:27 PM
...looking for a 2010 Camaro Indy Pace Car replica?? List of dealer's with allocation fbodfather 5th Gen Camaro SS LS LT General Discussions 63 04-24-2010 09:51 PM
Ambient lighting (ABL) - the FINAL update = LIMITED TO DOOR PANELS CamaroScotty 5th Gen Camaro SS LS LT General Discussions 338 04-15-2009 05:33 PM
