11-06-2010, 07:15 PM | #1 |
Shark attack!
Ok so... the Automatic has a manual gear..?
Hey there every one.. i figured i would finally introduce myself in a post.. I'm David AKA Taintedveins a senior in highschool .. and I drive a 2011 LS.
SO let me just get down to my questioning.. and find something that might help me out a bit. The other day i tested out the manual gear with in the automatic and noticed there was a distinct sound difference after its use. it sounded as if there was more power. Now i would want to use that gear more often but it seems too simple for its use.. So has any one else used this gear and do you notice any differences? |
11-06-2010, 07:20 PM | #2 |
Drives: 2011 2SS/RS A6, IOM Join Date: May 2009
Huh?
nt
11-06-2010, 07:21 PM | #3 |
Drives: 2011 CGM 2SS/RS A6 Join Date: Sep 2010
It is in Sport mode, holds shifts longer, more aggressive.
Read your manual.
11-06-2010, 07:21 PM | #4 |
Shark attack!
nt? i have the car right outside ill take a picture for proof...
11-06-2010, 07:22 PM | #5 |
Shark attack!
11-06-2010, 07:23 PM | #6 |
I like teeth.
Drives: #198 Join Date: Oct 2009
11-06-2010, 07:25 PM | #7 |
Shark attack!
when i meant proof i was gonna take a shot of the shifter and show it while in the gear on the display. But thank you for your words they help :P
11-06-2010, 08:39 PM | #8 |
Drives: 2010 Summit White 2LT/RS Join Date: Jan 2010
If you shift it to "M" and dont shift yourself via the pushbuttons on the steeringwheel then it stays in sports mode and shifts aggresively on its own. Otherwise, you manually shift through at your pleasure with the tapshift buttons......hope this answers your question?
Every man is a damn fool for at least five minutes every day; wisdom consists in not exceeding the limit.
-Elbert Hubbard |
11-06-2010, 08:41 PM | #9 |
Shark attack!
Yes it does thank you. that was my curiosity i wanted to know what the S meant anyway lol
11-06-2010, 08:44 PM | #10 |
Go Harder Than Baltimore!
Drives: 2010 CGM Join Date: Jun 2010
Im still scared to go into sport mode lol So I can just shift from D to M. then back at any speed? Also if i accidently hit the tap, can i put it back to D at any time?
11-06-2010, 08:46 PM | #11 |
Shark attack!
11-06-2010, 08:47 PM | #12 |
No prob....yeah, as soon as you shift up or down with the tapshift the "S" will change to an "M" and whatever gear you're in on the DIC (i.e. M3, M4, etc.)
-Elbert Hubbard |
11-06-2010, 08:49 PM | #13 |
Sports mode is fun!! Try it out on an open road sometime....or if you just want to get a feel for what it's like drop it down before you pass someone
And, yes, that means you can shift in and out of it while driving.
-Elbert Hubbard |
11-06-2010, 08:49 PM | #14 |
Red Brick of Vengeance!
Drives: 12 Second Brick Join Date: Jun 2009
Yes, you can move it from D to S... and from S to D... and S to Mx and Mx to D with no issue... it's all computer controlled and the car won't let you do anything really bad... like trying to down shift when you are already at a high RPM... the DIC will simply display SHIFT DENIED... LOL
Similar Threads | ||||
WTT AW 2010 2LT RS Automatic for manual | blakechase | Autos For Sale / Wanted | 3 | 10-11-2010 12:10 PM |
Manual Tranny Drivers..RPMs starting out in first gear? | autobotaz | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 8 | 09-15-2010 12:22 PM |
Manual on the go with your Apple devices | LED Crazy | 5th Gen Camaro SS LS LT General Discussions | 2 | 09-11-2010 11:21 PM |
Manual vs. Automatic | MClarenF1 | 5th Gen Camaro SS LS LT General Discussions | 94 | 05-16-2010 08:12 PM |
Manual OR Automatic ? | Patfan1987 | 5th Gen Camaro SS LS LT General Discussions | 5 | 10-20-2009 03:21 PM |
