Old 05-16-2011, 02:36 PM   #1
Tran
Administrator
Tran's Avatar
Arrow 2012 Camaro V6 Engine's New Cylinder Head Design Adds Power, Saves Fuel
Head Games: 2012 Chevy Camaro Adds Power, Saves Fuel
New cylinder head design combines key parts into single aluminum casting
2011-05-16
PONTIAC, Mich. – In auto production, more power, better fuel economy and fewer emissions rarely appear together. But the 2012 Camaro 3.6L direct injection V6 engine achieves all three by combining the exhaust manifold with the cylinder head into a single aluminum casting.
Each integrated exhaust manifold cylinder head – a V6 has two -- replaces a cast iron exhaust manifold, six bolts, a gasket and a heat shield and three bolts. By eliminating this joint, the potential for a gasket failure is eliminated. And the change reduces engine weight by 13 lbs. or 6 kg per engine. Reducing mass helps improve fuel economy and the 2012 Camaro 2LS model is EPA estimated at 30 mpg highway.
“Reducing engine mass of this magnitude doesn’t happen often,” said Ameer Haider, GM assistant chief engineer for V6 engines. “Engineering usually looks for reduction in terms of grams not pounds. It’s just like removing a set of golf clubs from your car when you don’t need them – ultimately it saves fuel. When combined with other mass reductions, the customer will see better fuel economy over time with better performance.”
Extensive simulation and bench testing was performed to perfect cylinder-head airflow. Intake airflow is improved 7 percent with the use of larger intake valves (38.3 mm v. 36.9 mm), which are primarily responsible for an increase of 11 horsepower. Exhaust flow is 10 percent better than the previous V6.
Lower emissions, narrower engine size and noise reduction round out the list of benefits for the new head design. With the catalytic converter closer to the engine exhaust point, the emissions reduction process begins sooner, resulting in lower emissions. The new cylinder heads decrease the overall width of the engine by 4.6 inches (117 mm) for significantly more packaging space in the engine bay making underhood work easier. Due to less surface area, the new design contributes to a 1 decibel reduction in engine noise at idle.
“The new, patented design benefits the customer in all the key areas without any tradeoffs, said Haider. “Emissions, performance, fuel economy, and noise all improve with the integrated exhaust manifold.”
Tom Sutter, Chief Engineer for GM V6 engines, describes the unique cylinder head design change and the integrated exhaust manifold, all resulting in fuel savings and improved performance.
The new integrated exhaust manifold cylinder head on the right is compared to the old on the left. The photo shows the reduced complexity of the design by eliminating the need for a separate exhaust manifold, heat shield, gasket and associated fasteners.
Old 05-16-2011, 02:58 PM   #2
dmginc
dmginc's Avatar
Drives: In Circles
sucks for anyone that wanted to put headers on their 2012 v6...but is a very interesting design, cant wait to see how it works in the real world.
dmginc is offline   Reply With Quote
Old 05-16-2011, 03:25 PM   #3
spoone123
Next is SS camaro.....
spoone123's Avatar
Drives: 2010 Camaro LS, Rally yellow
I want that program
Airraid CAI, Havoc Rims, Perreli tires, Remote start
spoone123 is offline   Reply With Quote
Old 05-16-2011, 03:32 PM   #5
DarkObsession
Drives: 2011 Camaro SS2/LS3
This is exactly what I was thinking... anyone who wants to seriously mod their V6 better hope that the integrated exhaust manifolds are "maxed out" from the factory because otherwise... you'll just have to dive into the heads immediately.
Speaking of heads, if anyone makes aftermarket heads for those, they are going to cost a small fortune.
2011 Chevrolet Camaro SS2/LS3 - Pretty much bone stock (SLP SkipShift Eliminator, GTO clutch fluid reservoir mod) - 13.025 @ 110.492 MPH (12s?? )
1998 Pontiac Grand Prix GTP (retired) - Cam, exhaust, CAI, 12 PSI, tune - 13.465 @ 101.04 MPH
DarkObsession is offline   Reply With Quote
Old 05-16-2011, 03:37 PM   #6
JBuzzy11
JBuzzy11's Avatar
Drives: 2010 Synergy Green
Originally Posted by sterlingnotes View Post
These heads are screaming for a turbo to be mounted right there...
unreal how far the V6 has come.. The V8's always had the power but I never thought we would see the V6 at this point, im guessing within 10 years we may see around 375hp from the V6!!!
Injen CAI, JBA headers, MRT V1.0 exhaust, Trifecta tune.
JBuzzy11 is offline   Reply With Quote
Old 05-16-2011, 03:52 PM   #7
Blade
Blade's Avatar
Drives: 2016 Camaro 2SS BVM
Hmm..........so it comes with 11 more horses off the bat.......combine that with Trifecta's new performance tune, a 2012 V6 can make 336 HP after a 300-400 dollar expense. She will be quite but the power will come much cheaper than what I paid for.
Formerly owner of:
2007 Acura TSX
1992 Oldsmobile Achieva V6
1992 Mercury Sable
Blade is offline   Reply With Quote
Old 05-16-2011, 04:01 PM   #8
GearBangr
Drives: 97Z,02TA
Originally Posted by Edge.128 View Post
WRONG. if anything we are demanding more and more parts they just aren't coming to the market. not sure why. but we are slowly starting to see that change. but these new heads may make modding much tougher, especially for those that want to add headers.
Its hard to say at this point really. Theyr trying to get more power and efficiency out of it, so I doubt they would purposely create a restriction. Instead of having 3 small ports you get one big one. It may save you in the end. Perhaps it just takes that step put of the modding process. Or you just have to buy one pipe "header" instead of the 3-1 tube header. It could go either way.
Also as stated previously, it sure looks tempting to attach a turbo to that port.
GearBangr is offline   Reply With Quote
Old 05-16-2011, 04:01 PM   #9
KILLER74Z28
MOD SQUAD
KILLER74Z28's Avatar
Drives: 2G1FT1EW9A9100666
It’s great for emissions and MPG but I’m thinking this is going to limit anything the Aftermarket Exhaust companies can do for the V6’ers “BIG TIME”. And right now it's good to be a V6'er when it comes to moding. With this new head design , I would like to see total HP gain with a full aftermarket exhaust set up. Right now most full set-ups with long tubes are getting people 30+ HP.
Who cares about the Blue Oval crowd and their little Ponys? We're getting our Camaro back-and it'll be Supercharged!-MDAII
Team LS3
KILLER74Z28 is offline   Reply With Quote
Old 05-16-2011, 04:08 PM   #10
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
They won't be maxed out on a car that sells for under $25,000. They did it to save weight and save cost, not improve performance.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 05-16-2011, 04:09 PM   #11
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
No headers with this set-up.............
Old 05-16-2011, 04:10 PM   #12
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
at least you'll save $ on NOT buying AM headers,but I think it will limit power gain options..what's next, GM designed OEM CAI?
Old 05-16-2011, 04:11 PM   #13
JKBUMBLEBEE
TEAM LLT ! NY5thGEN
JKBUMBLEBEE's Avatar
Drives: 2011 3.6L V6 328HP Camaro
-___________________________________- they really couldn't of put these in the 2011? assholes.
JKBUMBLEBEE is offline   Reply With Quote
Old 05-16-2011, 04:17 PM   #14
squat
Drives: 2011 Dodge Charger
323 HP from the factory sounds like a nice amount.
2011 Dodge Charger
squat is offline   Reply With Quote
Camaro Product Manager - interview Moose 5th Gen Camaro SS LS LT General Discussions 11 04-04-2012 06:10 PM
Camaro (concept) Press Release!! Pencil.Fight 5th Gen Camaro SS LS LT General Discussions 4 07-21-2008 03:33 PM
