Old 04-15-2012, 03:33 PM   #1
81ashenZL1
Drives: 2012 ashen gray ZL!
12 miles and check engine light is now on
little wrench icon on dash , when i look up icon in manual it says suspension.
also tried sport mode but nothing changes
anyone else have this issue? cant understand at dealership it was fine, trailerd it home backed it out of the hauler and now this :(
definately a hot looking/sounding car, cant wait to actually drive it
last 3 vin 081 ashen gray
so i guess it gets flatbed'd back to dealer
81ashenZL1 is offline   Reply With Quote
Old 04-15-2012, 03:37 PM   #2
dirishboy
as in Irish European
dirishboy's Avatar
Drives: 2012 ZL1
Spacers taken out?
dirishboy is offline   Reply With Quote
Old 04-15-2012, 03:39 PM   #3
IROCanSS
Drives: 89 IROC 350
Geez dude... Just drive it to the dealer. It will be fine.
Old 04-15-2012, 03:41 PM   #4
81ashenZL1
spacers are out thanks
live far away from dealer
Old 04-15-2012, 03:43 PM   #5
dirishboy
dirishboy's Avatar
Drives: 2012 ZL1
Take it to the local dealer you plan on servicing it.
Good time to introduce yourself and explain why you didn't buy from them but you do want service from them.
Old 04-15-2012, 03:47 PM   #6
xx_ED_xx
xx_ED_xx's Avatar
Drives: 04 Silverado
Let us know the outcome...
xx_ED_xx is offline   Reply With Quote
Old 04-15-2012, 03:49 PM   #7
81ashenZL1
thanks gonna call a local dealer in the morning an see what they say
Will post up what the results are thanks
Old 04-15-2012, 04:03 PM   #8
DAVE ZL1
Dave ZL1
Drives: 2006 DURAMAX
Suspension
Maybe something came lose when takin off straps. You'll find out sone as they hook it up. I know they didn't keep the spring spacers but if they do tell you it was the ride hight senor you might want too get a hold of some for the next time you have to haul it. No matter what it is it will be fix and away you go in that awsome ZL1. Keep in mind the factory can't control everything, it could be something they have no control of that came from out of house.
DAVE ZL1 is offline   Reply With Quote
Old 04-15-2012, 04:07 PM   #9
IROCanSS
Drives: 89 IROC 350
It's not going to be any big deal. A sensor or something is going to need replaced.
Old 04-15-2012, 04:42 PM   #10
Russell James
Russell James's Avatar
Push the Onstar button, maybe they can tell you what the code is. Possible a sensor got knocked off from the tie downs.
Did you use the frame tie down slots or were straps hanging around the wheel area? My guess is going to be strap damage to a shock connector or wheel speed sensor if the frame slots were not used.
Old 04-15-2012, 04:55 PM   #11
htron50
htron50's Avatar
Drives: 2017 ZL1 Status "Thank You!"
DO NOT CHANGE the PTM MODES WHILE DRIVING! Read manual. It says you can do permanent damage to it if changing while driving! Easy to overlook that section of manual and try to change modes on the fly.... = big mistake. Might be your cause?
htron50 is offline   Reply With Quote
Old 04-15-2012, 05:11 PM   #12
Russell James
If a button push could cause damage, the programming would simply not allow the input at that time.
You can change modes while driving. The warning you see in that section has to do with shifting the transmission while the wheels are spinning.
Old 04-15-2012, 06:12 PM   #13
b4z
Drives: '06 Pontiac GTO M6, '19 F150 2.7TT
Ummmm ,you're not supposed to shift while the wheels are spinning? That's no fun.
b4z is offline   Reply With Quote
Old 04-15-2012, 06:56 PM   #14
Al C.
Al C.'s Avatar
Drives: ZL1 #529 "El-Jefe"
Check the fuel cap, make sure it's tight. I spent $100 for a diagnostic on my Avalanche at the dealership just to find out it was a bad/loose fuel cap ($20 fix). But then again it's under warranty so let them worry bout it.
Al C. is offline   Reply With Quote
Cold air intake/ Check Engine light. Need Help! edcamaro29 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 64 02-17-2024 04:40 PM
What do all the abbreviations mean? CrzyGamr2 5th Gen Camaro SS LS LT General Discussions 77 12-07-2012 04:34 AM
Acronyms at C5 hokie2012 5th Gen Camaro SS LS LT General Discussions 34 08-10-2011 03:56 PM
Check Engine Light twnorman Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 3 01-23-2011 07:32 PM
The BEST Break for a new car. "very long" Darin Morgan General Automotive + Other Cars Discussion 346 02-04-2010 06:49 PM
