Old 07-10-2009, 12:22 PM   #1
Tran
Administrator
Tran's Avatar
Detroit Speed & Engineering's 2010 Camaro project car
As featured on Homepage.
Amazing what a body colored ground effects kit and a bit of lowering will do for the look of the Camaro
http://www.detroitspeed.com/projectp...amaro-main.htm
THE CAR: 2010 V8 Camaro with the DSE Performance Handling Kit.
THE PRODUCT: Detroit Speed is known for our performance and ride quality of early Camaros. Now you, too, can have Detroit Speed technology underneath your 2010 Camaro.
The Performance Handling Kit includes Front and Rear Drop Springs and a Front and Rear Sway Bar.
The Drop Springs lower the ride height to give your car a more aggressive stance. The increased progressive spring rates provide improved performance handling while retaining excellent ride quality. They are a direct replacement to the factory 2010 Camaro springs. The DSE Drop Springs retain the factory isolators.
The Front and Rear Sway Bars have a larger diameter than the OEM bars with an increased rate for improved performance handling. The Front Sway Bar also includes high-performance fully adjustable aluminum end links. These end links are a great way to upgrade from the small factory end links that are in your stock Camaro. The Sway Bars are powdercoated gloss black. The Sway Bar bushings and custom heavy duty end links are also black for a clean uniform finish.
Old 07-10-2009, 12:23 PM   #2
thecamaroguy
thecamaroguy's Avatar
Drives: 2020 ZLE 67 SS350
Very nice!!
thecamaroguy is offline   Reply With Quote
Old 07-10-2009, 01:44 PM   #3
LS1_Alex
Drives: Firebird Formula
Nice
LS1_Alex is offline   Reply With Quote
Old 07-10-2009, 01:46 PM   #4
jpsuperman81
Yep I'm back!
jpsuperman81's Avatar
Drives: 2017 Krypton Green 1SS 1LE
jpsuperman81 is offline   Reply With Quote
Old 07-10-2009, 01:56 PM   #5
Blownhotrodder
Blownhotrodder's Avatar
Drives: 2018 ZL1 1LE
Someone needs to make a tip that is the same shape as the openings in the rear cover. Doesnt look right with the round tip.
Blownhotrodder is offline   Reply With Quote
Old 07-10-2009, 03:19 PM   #6
tones2SS
tones2SS's Avatar
Thumbs up
DSE = 1 of the best in business for suspension components.
Top notch products with top notch service!
Old 07-11-2009, 01:08 AM   #7
DBrown21
DBrown21's Avatar
Drives: Black 2SS M6
how far do the new springs drop the car?
DBrown21 is offline   Reply With Quote
Old 07-11-2009, 01:11 AM   #8
1320junkie
Drives: The Imperial Army
smooothhh
Old 07-11-2009, 04:23 AM   #9
EKG
Drives: Right now....a Honda CR-V
I have a question. If you order a Camaro, can you get the dealer to paint the ground effects the same color as the car, or would you need to do that somewhere else?
EKG is offline   Reply With Quote
Old 07-11-2009, 04:36 AM   #10
SummoneR
Paul
SummoneR's Avatar
The dealer send it to a shop, then charges you 2-3 times more than it cost them. Just go to a reputable auto body place and have it done for around $600
Old 07-11-2009, 08:46 AM   #11
Andro
NOICE!!! ™
Andro's Avatar
Drives: Force Fed 427
Sick!
Old 07-11-2009, 10:09 AM   #12
Zabo
Gunning for Sixth
Zabo's Avatar
Drives: '03 ZR2 Blazer
Not liking it.. Lowering just doesn't look right on this car.
Zabo is offline   Reply With Quote
Old 07-11-2009, 10:27 AM   #13
chrisgalles
TEXAS FIGHT!
chrisgalles's Avatar
Drives: Awesome
Super Super Super Hot....This will be done to mine. I don't like em slammed but dropped just a couple inches and damn it makes a world of difference.
chrisgalles is offline   Reply With Quote
Old 07-11-2009, 11:00 AM   #14
King Mouse
King Mouse's Avatar
Drives: EXT
Looks good. A bit expensive.
King Mouse is offline   Reply With Quote
2010 Camaro Review Compilation Tran Camaro Price | Ordering | Tracking | Dealers Discussions 213 07-29-2011 02:59 PM
CNN: Camaro: From sketchpad to street - The rebirth of a muscle car ... Gatecrasher 5th Gen Camaro SS LS LT General Discussions 49 10-05-2009 04:33 PM
edmunds drives the v6 !!!!!!! ???????? i3litzkrieg 5th Gen Camaro SS LS LT General Discussions 47 09-02-2008 01:13 PM
NEW!! Voice Your MARKETING Suggestions/Input for Focus Group on 2010 Camaro. Mr. Wyndham 5th Gen Camaro SS LS LT General Discussions 114 05-08-2008 10:24 PM
