08-02-2015, 02:01 PM | #1 |
Drives: ZL1 1LE A10 Join Date: Mar 2015
Scary engine start
Thursday evening while starting up my car to head home from work I experienced some very serious thrashing from my engine :(
Nothing weird prior to this and I didn't do anything rough with the car in the last few days, just some normal commuting. So here's what happened: I started the car (like you do) and immediately the whole car starts shaking violently in what seemed to be a regular pattern. This went on for about 3 seconds while I was in shock, before I could get my sense together and turn the car off, it managed to knock itself out. My first thought was that there was some unburnt fuel in one of the cylinders and maybe it got into some weird timing. So I waited a minute and tried again. Same exact result. So then I open the hood and immediately feel that feeling I imagine a non-knowledgeable car person must feel when stranded along the side of the road looking at the engine with the hood up and absolutely no idea what to do next... My gut was telling me it was one of the pistons either blown or not firing. First things first I unplugged the car battery and hope to reset the computer. Tried again and same result (I knew this was a long shot). So next I tried pulling all the spark plugs and looked for some gunk that may cause a bad connection, but nothing funny. However when I pushed each of them firmly back into place and tried to start the car, it started right up - no problems except a persistent check engine light. I drove home in the slow lane staying out of boost and trying to keep it below 2k rpm as much as possible. After checking the DTCs with my HPTuners, I found a P0606 code, "ECM Failure". I cleared the code and took it for a drive and had no problems. After building up some trust I did some really hard (loud w/ spinning tires) starts and highway WOTs. Everything seemed fine with no more codes and my HPTuners didn't show anything weird during the drive. My guess is that it was a loose spark plug wire, but why would that throw a P0606? Could it actually be a faulty ECM and just coincidence that it resolved itself around the same time I messed with the spark plug wires?
Current: 2019 ZL1 1LE A10 Mods: MPS4s Tires | Borla Atak | CF Steering Wheel Previous: 2018 ZL1 1LE M6 | 2017 Z06 Z07 M7 | 2017 GS A8 | 2015 ZL1 M6 | 2013 GT500 |
08-02-2015, 02:44 PM | #2 |
Drives: 2013 ZL1 Convertible A6 BRM Join Date: Feb 2015
I've seen a lot of posts lately with the loose spark plug wire theme. Maybe there is much vibration with this engine combo that causes this loosening of the wires? Also many bad ECM posts. Maybe you are lucky your ECM went bad under warranty?
2013 ZL1 CONVERTIBLE BRM A6
OHIO |
08-02-2015, 03:53 PM | #3 |
Except I cleared the DTC. If its going to go bad again, then hopefully it goes bad a week before my warranty runs out
08-02-2015, 08:53 PM | #4 |
Drives: 2015 ZL1 Join Date: May 2012
My car did the same thing a few weeks ago. My car also flashed reduced engine power. I let it set a few minutes, started it up and it was fine. But the check engine light was still on. It had two codes, P0606 and P0113. The dealer changed out the ECM, and the battery. They did say the ECM was bad. After a few hundred miles, everything is fine, so far.
2013 Camaro ZL1,Victory Red # 441....SOLD
2013 Camaro ZL1, Summit White # 3071...SOLD 2015 Camaro ZL1, Summit White # 1325 Rotofab Cai,PCM cc,Kooks Headers,Cats delete,MF X pipe, ZLWin cam,upper/lower, Lingenfelter hx,715 rwhp,646 rwtq, BMR 1.25 Springs, Varro VD01 Wheels, |
08-02-2015, 09:11 PM | #5 |
Drives: 2013 ZL1 Join Date: Jan 2015
Sounds like limp mode to me. My buddies car would occasionally go into limp mode and had a loose injector plug that was sometimes cause it.
2013 A6 ZL1
08-03-2015, 05:54 AM | #6 |
Drives: '21 ZLE A10 Join Date: May 2012
Some have reported their ECM needed replacing and the unit itself had a few loose pins
08-03-2015, 06:30 AM | #7 |
He has NO ECM WARRANTY, he has a tune and has voided the drivetrain warranty.
08-03-2015, 06:49 AM | #8 |
Drives: 2021 300 Join Date: Jan 2015
A lot of ECM's have gone bad, It's a common replace for Chevy. But you should not have cleared the code.
08-03-2015, 06:58 AM | #9 |
But they check them for tunes, who is to say the tuner did not screw up the ECM. I do some IT work for the dealer in my town and GM voids the warranty if the ECM has been flashed with a non GM programming.
08-03-2015, 09:23 AM | #10 |
Well that's why I would not mess with a car under warranty!!!!! You pay for it in the price of the car why would you want to flush it away???
08-03-2015, 02:37 PM | #11 |
Drives: 2013 ZL1 M6 Join Date: Oct 2013
Maybe for you. Not for all. He has nothing to worry about if the ecu pins have bad soldering. If your dealer is so quick to throw you under the bus, you need to find one more reasonable...... they are out there.. now if he melted a piston, or blew out a diff thats a different story. If he lost a motor because an oil pump relief valve was stuck or something like that, which is not tune related, a good dealer will go bat, they might not win everytime but they will try.
08-03-2015, 03:37 PM | #12 |
Sarcasm loading --------
I had a tuned ECU replaced under warranty on my SS.
"The salesman actually told me to stop getting it sideways during the test drive"
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
08-03-2015, 04:13 PM | #13 |
A number of people have, it's just a dealer option. Loose pins would have nothing to do with a different tune as you don't touch the computer.
And why modify your car while it's still in warranty? Is that a real question? Besides, the factory computer is not very expensive and you retain all of your warranty for anything that is not drivetrain related. Live life, enjoy your car and make it your own.
2013 A6 ZL1
08-03-2015, 07:07 PM | #14 |
Drives: 2012 ZL1 #1329 M6 Join Date: Jun 2009
Because the car is kind of boring in stock form.
2012 Camaro ZL1 #1329 M6 Summit White
Built by Mike @ Rapid Motorsports 784rwhp 757 rwtq on 93 Octane ET - 10.97 @ 128 Heads-Blower-Snout-TB ported & prepared by Jeremy Formato of FasterProms http://www.camaro5.com/forums/showthread.php?t=395950 Rapid Motorsports 396ci Build https://www.camaro5.com/forums/showt...1#post10321301 10.832 @ 130.99 |
