Old 09-25-2009, 05:31 AM   #1
Revnic
Drives: 2000 Custom Silverado
LS3 vs LSA
Anyone know if theres anything really special about the LSA? From what I can tell its basically an LS3 with different heads/cam and a forged crank. And a blower obviously. Other than that alot of the specs are exactly the same as the LS3.
Revnic is offline   Reply With Quote
Old 09-25-2009, 10:49 AM   #2
JoshJ81
JoshJ81's Avatar
Drives: '10 Camaro 2SS/RS Black
about 200 hp difference
2SS/RS A6 L99 - Black w/White Stripes
K&N Air Intake System
Muffler Delete
JoshJ81 is offline   Reply With Quote
Old 09-25-2009, 10:52 AM   #3
Chocolate Apocalypse
Full Fledged Member
Chocolate Apocalypse's Avatar
Drives: '18 1SS 1LE
Google is your friend
'18 1SS 1LE - DD
'72 Cutlass - LSA topped 370" LS2
Chocolate Apocalypse is offline   Reply With Quote
Old 09-25-2009, 12:42 PM   #4
Revnic
delightfullly informative. its about 130hp, not 200. which can easily be explained with the super charger. takes the super charger off and how much power would it make? most likely the same, if not less than the ls3. and i already googled it, hence the differences i noted. but thanks for your effort guys.
Old 09-25-2009, 12:47 PM   #5
Robert91RS
Robert91RS's Avatar
Drives: Everywhere
The LSA gets an upgraded block, forged crank, heavy duty pm rods, lower compression hypereutectic pistons, oil squirters, and stronger cylinder heads. I hope this is the info you were seeking. And to answer your last question, without the blower the LSA would put down lower numbers than the LS3 because it was designed to be boosted for more power more reliably and more efficiently than a LS3 with just a more aggressive cam. It's not just a LS3 with a supercharger though.
Robert91RS is offline   Reply With Quote
Old 09-25-2009, 12:53 PM   #6
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
In class. Will post my info when I get to back to my room
Old 09-25-2009, 12:58 PM   #7
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
See this thread for an in-depth overview of the LSA...There's a lot different about it from the LS3.
http://camaro5.com/forums/showthread.php?t=44331
Old 09-25-2009, 01:38 PM   #8
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
Beat me to it
Camaro Z28 (HP Edition) FACTS: radz28 Camaro ZL1 Forum - ZL1 Specific Topics 44 01-29-2011 11:05 PM
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
LS3 Engine Dyno LSA Comparison Data Inside!! Jason 98 TA Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 09-14-2009 09:26 PM
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 07:02 PM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 02:00 PM
