Old 12-27-2009, 03:29 PM   #1
ittybittyfds
ittybittyfds's Avatar
Drives: 2013 Victory Red ZL1 M6 #495
Oil Catch Can Install and location
Anybody out there with a SS have a catch can?
if so what line did you tap into and where did you mount the can?
pics would be nice
2013 Victory Red ZL1 M6, Roto-Fab CAI,
ittybittyfds is offline   Reply With Quote
Old 12-27-2009, 03:39 PM   #2
lawdogg149
lawdogg149's Avatar
Drives: Corvette ZO6 CSR edition #47
I do bought from Billet tech in Florida. Installed on passenger side front of engine. Made a threaded rod that screws in under the belt tensioner. Vented both the valve cover and the valley pan port which is just below the throttle body. Will look for a pic.
Nationwide Turf
"artificial turf factory"
lawdogg149 is offline   Reply With Quote
Old 12-27-2009, 03:45 PM   #3
TooCool5
TooCool5's Avatar
What are you guys talking about? Catch cans are used in NASCAR.
Old 12-27-2009, 03:51 PM   #4
lawdogg149
lawdogg149's Avatar
No catch cans are used to allow the engines to breath fresh air as well. They work by separating oil and air. LS engines are famous for breathing oil back into the intake track. Take off your intake induction hose and look inside the throttle body. Full of oil if you run the car. This can cause poor performance. By adding a catch can you are cleaning the air the car breaths out. Factory cars are made to breath from the intake track.
Nationwide Turf
Old 12-27-2009, 04:00 PM   #5
TooCool5
TooCool5's Avatar
Ok I'll check it, Car hasn't used a drop of oil though.
Old 12-27-2009, 04:03 PM   #6
ittybittyfds
Not really sure i can see how you tapped in from the pic?
also got your PM. if you don't mind i will take you up on your offer.. When i get it if i dont figure it out by then
I ordered the Elite Engineering version.
Old 12-27-2009, 04:04 PM   #7
myold88
myold88's Avatar
I guess G.M. engineers don't know about this ?.
Old 12-27-2009, 04:08 PM   #8
tom692010
Drives: 4 wheels
interesting. is this over kill though. does it improve any mileage or hp?
tom692010 is offline   Reply With Quote
Old 12-27-2009, 04:15 PM   #9
ittybittyfds
if you dont know and want more info read this:
http://www.corvettefever.com/techart...can/index.html
Old 12-27-2009, 04:19 PM   #10
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
how much are these how hard are they to install?
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 12-27-2009, 04:24 PM   #11
Blade
Blade's Avatar
Drives: 2016 Camaro 2SS BVM
Does the V6 engine needs the catch can?
Formerly owner of:
2007 Acura TSX
1992 Oldsmobile Achieva V6
1992 Mercury Sable
Blade is offline   Reply With Quote
Old 12-27-2009, 04:31 PM   #12
ittybittyfds
Oil Catch cans vary in prices. i have seen them for $50 up to $170
The elite Engineering Catch can is marketed towards Vette's so as expected the cost will be higher
adding a catch can to any LSx engine will not hurt and help you out in the long run
Old 12-27-2009, 04:42 PM   #13
lawdogg149
lawdogg149's Avatar
Based on my experience with road course racing any car that is driven hard needs a catch can. Remember these cars are designed and built to meet strict emission's in many states. A car can not breath these oil fumes into the air from the factory. They must be sent back through the process and reburnt. My car is turbo charged so that increase's my crank case pressures alot and needs to be vented better than stock. I have also found that GM engineers designed these engines to be positive crank pressure all the time. But a friend on a very very popular corvette team advised me which ports to vent on these motors. Car revs quicker now thanks to the venting of the lower crank pressure.
I would be glad to explain to anyone how to do this process.
Nationwide Turf
Old 12-27-2009, 07:10 PM   #14
Blade
Blade's Avatar
So does anyone think the v6 engines are going to need this too?
Formerly owner of:
2007 Acura TSX
1992 Mercury Sable
How-To: Install BFxenon HID Headlights (Non-RS) BFxenon.com Camaro DIY & HOW-TO instructions & discussions 73 10-07-2016 02:03 PM
DIY : Install underdrive pulley on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 34 09-30-2013 08:25 PM
How to Install QTP Electric Cutouts Quick Time Camaro DIY & HOW-TO instructions & discussions 73 05-03-2010 12:19 PM
Aftermarket cooling The_Stache Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 6 01-11-2010 05:40 AM
DIY : Install catback on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 3 08-09-2009 04:36 PM
