RDP Motorsport
Cosmetics and Lighting Modification Discussions External and Internal cosmetics modifications.
Old 07-06-2010, 10:50 AM   #1
PieManMighty
Manual 6 Speed Tran.
PieManMighty's Avatar
Drives: 2010 2LT Camaro IOM
Send a message via AIM to PieManMighty
HID 8000K Headlights & Fogs
Installed my HID H138K 8000K Headlight Kit today. Also installed the 5202 LED Cool White Fog Lights.
Purchased them through AAC @
http://www.automotivelightstore.com/...arohidkit.aspx
Def. Worth the purchase, they really make a huge difference, Check out some of the pictures below, especially compared to the Stock Photo. I'm happy with it
One note, after the install the check engine light came on briefly, so I disconnected the negative lead to the battery for about 10 minutes, then reconnected it and it cleared... just a Lil FYI.
PieManMighty is offline   Reply With Quote
Old 07-06-2010, 11:38 AM   #2
caverman
caverman's Avatar
Drives: '69 SS Convertible
WOW....you took of the front nose to install this? Seems like a little overkill....although I'm sure it made getting to the fog lights easy enough. I wasn't told about removing a couple of the inner fenderwell screws to get access to the fogs...I came from underneath and it was a super PIA to get them in. Even when I called AAC during my install they didn't mention this...so I think I must have been one of the first they dealt with that wasn't putting Halo rings in them.
Do you think the 5202 fog light bulbs match your 8000k lights? AAC told me they would match up just fine but they don't match at all IMO. You can see a significant difference in the fogs vs 6000k lights (which I ended up with) so I can only imagine that with 8000k there is a pretty big difference.
I'm probaby going to end up buying some 6000k fog lights because the difference in the AAC 5202 and anything above 4300k just look to far apart for my taste.
http://www.camaro5.com/forums/showth...hlight=install
They have these for the 6000k but you might be able to find them for the 8000k http://www.camaro5.com/forums/showthread.php?p=2062173
Build Journal
Old 07-06-2010, 11:57 AM   #3
wylde1
I am the Stig
wylde1's Avatar
Drives: Black w/ IOM stripe 1SS
hmm since I did my headlight install with the LED signal lights I'm getting a "check turn signal message" I wonder if disconnecting my battery for a bit like you did will fix that up.
looks great man!
www.myspace.com/harmfuleffects <--have a look... Camaro5 members Wylde1 (me) and Gee-off are the guitar players! Support us by viewing! ..and maybe buy an album haha
2010 Camaro - 1SS, Black w/ Orange stripes (Delivered 26/03/2010!! VIN 2G1FS1EW5A9200086)
wylde1 is offline   Reply With Quote
Old 07-06-2010, 12:54 PM   #4
garcmol
garcmol's Avatar
looks great man!
Since you replaced the bulb with LED, you cut down the power draw when in use. Therefore the car thinks your bulb is burned out. more technical explanation I'm sure, but that's the jist of it.
Old 07-06-2010, 01:14 PM   #5
R.I.P. jesserayjames
Drives: 2010 IOM 2SSRS
I would love to put these on mine, but I do not want to take the nose off.
2010 SSRS is online now   Reply With Quote
Old 07-06-2010, 02:27 PM   #6
caverman
caverman's Avatar
You don't have to take the nose off. You can add the HID kit in about 30 min without removing anything but the factory bulbs. The fogs take a little longer and even though removal of the front nose would give you the ultimate accessibility you can get to them fairly easy but removing some of the screws on the inner fender well, pull back the fender well, and remove the fogs from there.
Since you have an RS then you already have HID headlights. If you wanted 8000k lights instead of 4300k lights I would bet you would just have to change the bulbs out. However you would need to talk to someone like AAC or BfXenon to answer that.
Your fogs on the RS on the otherhand are halogen but you can replace those if you want. AAC and other places sell the replacement bulb that should match your factory 4300k HID lights just fine.
The 5202 fog light bulbs that were used would look just fine on 4300k. Anything above that and they don't match IMO.
Build Journal
Old 07-06-2010, 04:12 PM   #7
Musclefreak
Drives: chevrolet camaro 2010
Originally Posted by PieManMighty View Post
Installed my HID H138K 8000K hid headlights today. Also installed the 5202 LED Cool White Fog Lights.
Def. Worth the purchase, they really make a huge difference, Check out some of the pictures below, especially compared to the Stock Photo. I'm happy with it One note, after the install the hid kits check engine light came on briefly, so I disconnected the negative lead to the battery for about 10 minutes, then reconnected it and it cleared... just a Lil FYI.
Man it must have been a pain to remove the front, but in the end looked really nice. Congrats!
Musclefreak is offline   Reply With Quote
Old 07-06-2010, 04:17 PM   #8
wylde1
I am the Stig
wylde1's Avatar
Yeah That's kinda what I figured the problem was. but I also changed how much power the headlights are using and I havn't had any messages from them yet. It just specifically says to check the signals. My passenger light factory harness is completely unplugged from anything, I thought that would give me more of an error message.
I was thinking about adding a resistor to raise the power consumption to get rid of the error messages, but it'd be a bit of work to figure out what resistance to use.
Old 07-06-2010, 06:51 PM   #9
PieManMighty
The nose is really not that hard to take off.... yea it's slightly tough to get to the bolts up under the fender, but with the right tools you're fine.
I took the nose off because I'm also putting Halo's in so it did require taking the whole front end off to get the headlight housing out
Old 07-06-2010, 06:52 PM   #10
PieManMighty
Thanks... my whole street lights up when i drive down it like whoahhhhh!
Old 07-06-2010, 07:06 PM   #11
Shuffler
God Bless Dawson
Shuffler's Avatar
Drives: Synergy for my Daughter
Hehehe
Shuffler is offline   Reply With Quote
Old 07-06-2010, 09:52 PM   #12
caverman
caverman's Avatar
Yes....if you do the Halos then the front should come off.
I just wanted those that are only going to do the HID to know that you don't have to remove the nose to add them.
Build Journal
Old 07-21-2010, 06:37 PM   #13
PieManMighty
Thanks for the clarification
Old 07-21-2010, 10:22 PM   #14
AACstyle
C5 Lighting Specialists
AACstyle's Avatar
Drives: www.CamaroLighting.com
You need a set of load equalizers to correct this, the PCM is not seeing the load from the LEDs. Speaking of which, looking at your sig... nice setup! Are those from ottobody? If so those are our LEDs, good stuff
Anyway, back to the load equalizers, see here: http://www.automotivelightstore.com/...er50w6ohm.aspx
This will correct the issue, you will need one per side.
Its not that bad
AACstyle is offline   Reply With Quote
Old 07-21-2010, 10:27 PM   #15
AACstyle
AACstyle's Avatar
Do you have the white or cool white 5202? The cool white is between 6000K-8000K
Old 07-21-2010, 11:13 PM   #16
caverman
caverman's Avatar
I don't know....you never mentioned there was any kind of difference. My guess would be the cool white since I ordered them at the same time that I bought the HID kit (8000k initially) and I would assume you would've suggested the correct one when I ordered it all together.
IMO even the cool white don't match. Look at the OP's original post where he says he has the cool white they don't match. The headlight has an obvious blue tint to it and the fog light is white. I guess they are kinda close if you compare them using the factory Halogen fog lights but not when compared to 6000k or 8000k. Even my wife who doesn't typically care about that kind of stuff said they didn't match and thought they looked better off then on.
Doesn't matter any more....I've got a new set of 5202 bulbs installed that are much closer. Still not exactly the same color but real close to the 6000k.
Build Journal
Old 07-22-2010, 01:16 AM   #17
Shuffler
God Bless Dawson
Shuffler's Avatar
That is my Daughter's Synergy in Justin's post where they remove the front fascia. Her new plates are GRN ENV.
Old 07-22-2010, 01:50 AM   #18
shawn18
OWTATIME
shawn18's Avatar
Drives: CaRaMo
So did you just buy 4 bulbs or what? I am really wanting this mod but not sure what parts to order. I dont want halos , I eant the same look that you have. Thanks
shawn18 is offline   Reply With Quote
Old 07-22-2010, 08:26 AM   #19
caverman
caverman's Avatar
To do it the right way you'll want a quality kit from someone like AAC or BfXenon. It will have two ballasts, two bulbs, and a relay to hook into your factory plub. Then you'll want some 5202 fog light bulbs.
If you have questions ask away.
Here is some stuff to look through:
http://www.bfxenon.com/Camaro_High_L...d-camarohl.htm
http://www.camaro5.com/forums/showthread.php?t=52542
http://www.camaro5.com/forums/showth...=1#post2122839
http://www.v-leds.com/V-LEDS-6K-HID-...-p8701564.html
Build Journal
Old 07-22-2010, 07:44 PM   #20
shawn18
OWTATIME
shawn18's Avatar
Drives: CaRaMo
Thanks!
Old 08-02-2010, 06:38 PM   #21
PieManMighty
Finally got my Dual Color Halo's from AAC finished & Installed, so I figured I'd post it here since I started the thread. check 'em out, let me know what you think.
(Sorry, couldn't get some of the night pictures to come out good :-/.... )
Old 08-02-2010, 07:11 PM   #22
garcmol
garcmol's Avatar
Awesome work bro, make it your own!
Old 08-02-2010, 07:20 PM   #23
PieManMighty
Hellz yea thanks!
Old 08-03-2010, 03:24 PM   #24
AACstyle
AACstyle's Avatar
Hellz yea thanks!
Awesome Job!
Old 08-08-2010, 03:20 PM   #25
BFxenon.com
Drives: Camaro
great write up on the install!! Looks awesome
BFxenon.com is offline   Reply With Quote
How-To: Install BFxenon HID Headlights (Non-RS) BFxenon.com Camaro DIY & HOW-TO instructions & discussions 70 12-03-2012 03:21 PM
Changed basic headlights to RS HID headlights Mane Exterior Parts & Accessories 2 05-20-2010 11:47 AM
Do halogen and HID headlights have the same headlight housing? verboten 5th Gen Camaro SS LS LT General Discussions 15 04-17-2010 11:34 AM
2010 Camaro SS HID Headlights 300sx Exterior Parts & Accessories 7 03-24-2010 05:43 PM
5202 (H16 ; 9009) Slim HID Kits !!! 09-Up Camaro Fog Light HID kits !!! HID_Guy Exterior Parts & Accessories 19 09-08-2009 01:07 AM
