Old 08-15-2010, 03:11 PM   #1
Rob191288
Rob191288's Avatar
Drives: 2010 Camaro LS
Question Need help with rear diff.
Just changed out my rear diff oil and I used Royal Purple but when I filled it back up I did not use the whole quart, is this normal? the fill hole began overflowing and I even stuck my finger in there to make sure I could feel it by the threads and I could.
Rob191288 is offline   Reply With Quote
Old 08-15-2010, 04:01 PM   #2
bmclark
bmclark's Avatar
Drives: 2016 HBM 1LT Auto V6
Rob,
Most likely not all of the fluid was drained out initially. Some people have recommended jacking up the front passenger's side to get a bit more fluid out.
Did you have the car level when draining or did you just jack up the rear?
Tri-County Camaro SWFL Treasurer
New one: 2016 HBM 1LT Auto V6
Old one: 2013 IOM 1LT Auto w/ 19" Polished Aluminum wheels
2010 Black on Black 1LT Auto w/ Convenience & Connectivity package and Sunroof
1995 Silver V6 5 speed w/ T-Tops, Z28 wheels and Borla Exhaust
bmclark is offline   Reply With Quote
Old 08-15-2010, 04:35 PM   #3
Rob191288
Rob191288's Avatar
the car was level when I drained it.
Old 08-15-2010, 06:07 PM   #4
chewy8
Drives: 96 bonneville
not a fan of r.p. meself but unless you jake the front of the car up with the drain plug out you wont get all the old oil out.
chewy8 is offline   Reply With Quote
Old 08-15-2010, 06:54 PM   #5
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
I jacked up the one side of the Camaro to help drain the extra fluid out. When re-filling with R.P. it took the entire bottle.
Edit: This was from a post when I changed the fluid a few months ago.
Here is the TIP OF THE WEEK. After I thought it was done draining I figured there had to be some more still in there since the car was sitting level side to side. I got my floor jack out and jacked the front passenger corner up until the tire was a few inches off the ground. The rear diff started to pour allot more out of the system. Those who do not do this are not getting the entire old fluid out.
By the way another TIP OF THE WEEK (from someone else this time) place a hockey puck between the jack and the Camaro jacking point, this prevents the metal from being abused.
Old 08-15-2010, 08:24 PM   #6
Rob191288
Rob191288's Avatar
Alright, should I redrain it and do it again or will it be good till I change it again?
Old 08-15-2010, 09:52 PM   #7
obe1
obe1's Avatar
Drives: 2010 2SS/RS M6 IOM, 1995 Blown Z28
No need to redrain it; you got 90% of the fluid changed. Any metal parts were already stuck to the drain plug magnet.
2010 2SS RS M6 Inferno Orange Metallic
1995 Z28 - blown, intercooled and nitrous injected - Sold
1968 Camaro - Sold
2019 Corvette Grand Sport
obe1 is offline   Reply With Quote
Old 01-14-2012, 11:15 PM   #8
gdheri
Drives: 2012 Chevy Camaro 2SS
Hi
Quick question at how many miles should i change my rear diff oil thanks alot
gdheri is offline   Reply With Quote
Old 01-14-2012, 11:58 PM   #9
MS3DALE
MS3DALE's Avatar
Drives: 2011 2SS/RS LS3/6M Litho#190
I did mine at 1,500
'11 IOM 2SS/RS LS3/6M HURST - Roto-Fab CAI-Kook's LTs-CORSA-Black Bear tuned
Proud Litho owner #190 - Homecoming Litho #120
'15 SILVERADO Z71 1500 LTZ Crew Cab - 6.2 "Midnight Edition" -Airaid intake-CORSA
MS3DALE is offline   Reply With Quote
Old 01-15-2012, 01:55 AM   #10
GoldCartridgeGamer
GoldCartridgeGamer's Avatar
Drives: 2014 Ford SVT Raptor SuperCrew
I too changed mine at 1500 and won't be looking at changing it again until 30k or 50k miles.
Phoenix (sold)
How to hug your camaro
Buy the car that you would most like to get beat in. The other guy will always be faster.
GoldCartridgeGamer is offline   Reply With Quote
Old 01-15-2012, 09:42 AM   #11
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
The manual recommends you change it the first time at 1,500.
After that it differs based on how you drive it. If all you do is drive around town it's recommended to change it every 50k but if you enjoy the car and drive it hard than every 30k.
Old 01-28-2012, 09:49 AM   #12
Marchino
Marchino's Avatar
Drives: 2010 Camaro 2SS/RS
I have not read anywhere in the manual you need to change it at first service...I have a 2010 Camaro...are you sure?
Marchino is offline   Reply With Quote
Old 01-28-2012, 09:54 AM   #13
IROCanSS
Drives: 89 IROC 350
I have 30,000 miles its probably been changed 4 times.
its quick, easy and pretty cheap and I always get shavings on the plug. I typically do it when I change the oil.
Old 01-28-2012, 09:55 AM   #14
IROCanSS
Drives: 89 IROC 350
Originally Posted by MS3DALE View Post
I did mine at 1,500
You change every 1500 miles?? So, you're good for what 3 or 4 more years, huh Rich?
Its OK, we know Chris is good for 9!
who sells aftermarket rear ends / diff (or diff parts) for the 2010 camaro fastfaster V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 102 09-03-2010 10:38 AM
Setting up an IRS/Drivetrain for Drag Racing Kyle2k Suspension / Brakes / Chassis 44 06-05-2010 10:17 PM
My Transformers Camaro Has No Rear Diff, No Driveshaft, No Suspension, No Nothing! prostreetbuyer 5th Gen Camaro SS LS LT General Discussions 109 05-23-2010 09:28 AM
Steering response.... CGM2SSRS Wheels and Tires Talk Sponsored by The Tire Rack 130 10-21-2009 06:04 PM
rear diff nfamous209 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 5 08-03-2008 03:49 PM
