Old 08-17-2010, 12:59 PM   #1
Jason 98 TA
Drives: Camaro
L99 VVT / AFM Camshaft Dyno Results & Explanations
I thought I better jump online & tell you guys we're still working very hard on L99 VVT & AFM camshafts.
Here's my quick explanation as to what VVT & AFM do in the L99 engine.
1. VVT allows us to change camshaft timing by grinding the camshaft with a lot of advance in the camshaft & slowly pulling the advance out as rpm increases.
The result is you can get the best of both worlds. Instead of being limited to +4 advance for example, you can run more advance & then slowly pull it out through the entire rpm pull. The result is a healthy power gain in the lower & upper rpm range.
Comparing the exact same camshafts next to each other we typically see about 15hp/tq down low & about 10-12hp/tq in the upper rpm range.
These gains will vary from camshaft to camshaft. As the camshafts get bigger in duration & your piston to valve clearance decreases, you find that you can put less advance in the camshaft. As a result we see less low end power gains from the VVT, but you can still get big power gains in the upper rpm range.
Stock Camshaft with Phaser disabled to full advance:
2. AFM is another item everyone is constantly discussing. The AFM lifters are a very limiting component on the L99 engine. These lifters realistically only want to go about .500" lift before the guys at Comp Cams have started seeing failures. The AFM friendly lifters require considerably less aggressive lobes to live more than just a few thousand miles. As a result we will offer AFM/VVT specific camshafts that will keep your AFM lifters happy & still gain a good bit of power.
By swapping out the AFM lifters and going to a more aggressive lobe we were able to get a solid increase in both hp & torque over the entire pull! These VVT only camshafts will require lifters to replace the AFM lifters currently in half of the cylinders.
We will be offering both VVT/AFM camshafts & camshafts for guys wanting to remove AFM. The removal of AFM will solidly gain 15hp thanks to the more aggressive lobes we can use when the AFM lifters are thrown out.
Graph showing a AFM friendly lobe compared to more aggressive lobes without AFM lifters:
With the removal of AFM we're now up over 100 flywheel horsepower at peak! The cool thing about that is while the L99 engine started approximately 30hp down from the LS3, we're now within 8hp when comparing similar duration camshafts! Imagine if the L99 had the same compression as a LS3 engine, it would easily make more hp across the board!
If your determined to keep the AFM lifters in your car & still want a camshaft we can offer gains up to approx. 80hp by just sliding in the camshaft kit!!
AFM/VVT Friendly Camshafts:
VVT Camshafts (require AFM Lifter Removal)
We will be offering roughly 3 different afm/vvt camshafts & 3 different VVT specific camshafts designed for stock cylinder heads. These camshafts will be designed with the p/v limits of the stock heads in mind. When our aftermarket casting LS3/L99 heads are complete we will be able to offer additional camshafts with more room for adjusting the VVT!!
I will be putting together packages shortly, but everyone hang tight. We're testing a few more lobe configurations before we settle on what will be used in the productions kits!
Jason 98 TA is offline   Reply With Quote
Old 08-17-2010, 01:01 PM   #2
Jason 98 TA
Drives: Camaro
If you guys notice we're up over 100 flywheel hosepower with the larger camshaft & AFM removal!
Old 08-17-2010, 01:32 PM   #3
markmass
TRI-COUNTY CAMAROS
markmass's Avatar
Drives: 2SS/RS Oct 2009
That is outstanding -- you guys have so much patience and dedication....I've already tuned out the AFM, with aftermarket exhaust is plain unlivable. I really did not see a drastic decrease in MPG if any at all!
I will be keeping tabs on this thread, certainly interested in what you come up with for the L99 - no AFM. Nice work chaps.
GET-TORQ custom CAM 223/243 LSA113, Full LS3 conversion, 3200 stall Multi-Disk TC from Circle-D, B&M Supercooler to cool that tranny down....1 7/8" Kooks Headers and High flowCats. MACH XL Catbacks. Eibach springs, R2C Performance CAI, powdercoated calipers, Footwell lighting in tune with dome lights, tints, ABL Lighting, ACS T3 ports and ACS Eagle T3 triple LED lighting kit. Heritage grill, Hex vents, ZL1 rockers, ZL1 Diffuser, Quad tips...the list keeps getting longer - whats next??
markmass is offline   Reply With Quote
Old 08-17-2010, 01:40 PM   #4
94guy
Drives: 99 Camaro; 2010 Camaro 2SS/RS
what's the duration at .050 on the smallest cam?
94guy is offline   Reply With Quote
Old 08-17-2010, 01:59 PM   #5
69 Rebel
69 Rebel's Avatar
Drives: 2010 IBM 2SS/RS Auto
Finally almost there, Great Job Jason.
Subscribed
69 Rebel is offline   Reply With Quote
Old 08-17-2010, 02:40 PM   #6
shaner74
Drives: 2010 camaro 2SS/RS
wow, I'm thinking one of the VVT/AFM cams plus FI is going to make some serious power without having to really rip into the engine too much.
shaner74 is offline   Reply With Quote
Old 08-17-2010, 02:47 PM   #7
RedJewel2SS
12.23s@113mph
RedJewel2SS's Avatar
Drives: 2SS/RS, A6, just a few bolt ons
what we all have been waiting for! check out the high rpm hp & tq gain!!!
can't wait to see how it does with the new heads and better compression!
other than the camshaft what else are you replacing in the valvetrain? springs, rods, & lifters, or just the lifters?
i'm definitely interested in your small or mid range VVT cam, DOD/AFM deleted, maybe the heads, but definitely a torque converter, trans cooler, and rear gear swap! can't wait to see the final production tests in an actual car!
RIP Cammie 7/15/2009 - 4/1/2011
RedJewel2SS is offline   Reply With Quote
Old 08-17-2010, 03:41 PM   #8
toehead93
Drives: 2014 2SS/1LE
Yes, this is all really exciting!
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 08-17-2010, 04:28 PM   #9
StlRomAniaN
StlRomAniaN's Avatar
Drives: IOM 2010 Camaro 2SS/RS
Wow, you guys have won my business
StlRomAniaN is offline   Reply With Quote
Old 08-17-2010, 04:40 PM   #10
duffmobile
duffmobile's Avatar
Drives: 2010 Camaro 2SS/RS - IOM/IOM
Love it! Can't wait to see the final results and numbers.
L99 with 2.8 LC Kenne Bell, Kooks 1 7/8 headers, Corsa Catback, R2C CAI, 491 RWHP / 500 RWTQ ---- 2010 MY #7539
duffmobile is offline   Reply With Quote
Old 08-17-2010, 05:04 PM   #11
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Sold me on the AFM delete... can't wait to see the final production release.
Torque Converter just added to my list too...
Old 08-17-2010, 05:50 PM   #12
Jason 98 TA
Drives: Camaro
We will keep you guys posted. We have one of the smaller VVT camshafts with AFM delete going in a car in Alabama this week! Hopefully he'll make 450rwhp with our cnc heads & the small camshaft!
Old 08-17-2010, 06:11 PM   #13
RedJewel2SS
12.23s@113mph
450rwhp is what i'm going for n/a!!!
Old 08-17-2010, 06:14 PM   #14
Supercharged SS
Drives: 2010 Camaro
Are you guys going to do any research with the VVT cams and superchargers? Forgive me if you have already answered this in another thread.
Texas Speed Long Tubes & Rumbler 5 Cat-Back Dyno Results! Trevor @ Texas Speed Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 48 12-08-2018 03:37 AM
Vararam CAI Testing on Dyno at England Green Racing (Pix, Vids, RESULTS!!!) TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 113 01-05-2011 04:32 PM
Dyno Results on L99? pharmd Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 05-12-2009 11:53 PM
L99 engine specifications Tran Wiki 0 10-19-2008 12:40 PM
