Old 08-17-2010, 06:46 PM   #1
Indpowr
Drives: Corvette C6
Educate me on DOD/AFM delete
What are the pros and cons of tuning this out?
Will this help the car sound better at idle?
Whats the best tuning product?, EFI Live, HP Tuner, LS Edit?
The wife wants the car to sound LOUD as possible with the new LT. Yes, I did a search on this topic.
Old 08-17-2010, 06:59 PM   #2
CombatVet0311
Drives: blk 2010 camaro 2ss l99
Car will sound the same at idle as the vehicle operates with all cylinders active at idle, you will lose a negligible amount of mpg under light load with afm tuned out but the tradeoff is the l99 sounding like a proper v8. I assume that the quality of tune you get has less to do with the tuning device and more to do with the person tuning the vehicle. Hope I was of any assistance, good luck.
CombatVet0311 is offline   Reply With Quote
Old 08-17-2010, 07:06 PM   #3
jtzako
Drives: 2010 IBM Camaro SS
FWIW, AFM only kicks in when you are off the throttle, going down hill, or on very flat ground. The second you touch the gas pedal it turns back to 8cyl mode.
Personally, if its going to be there I wish it was less sensitive. Leave it in 4cyl mode when just maintaining speed (cruise control etc) if you arent on a hill or something that requires more power.
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
jtzako is offline   Reply With Quote
Old 08-17-2010, 07:20 PM   #4
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
AFM does what your second paragraph states. It does go into AFM when cruising. That's what all the aftermarket exhaust guys are complaining about. If it only happend when off throttle, it wouldn't be a problem. It also wouldn't help much on gas savings. Technically, when off throttle, the injectors won't be pushing much fuel.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 08-17-2010, 08:11 PM   #5
Indpowr
Drives: Corvette C6
So, I do nothing with the tune on it. We just wanted it loud..
Old 08-17-2010, 08:16 PM   #6
Cal 20112SS
Drives: 2019 C7 Stingray
It's unreal how noticable it is once I put headers on. You can hear and feal it shutting down cylinders.
Cal 20112SS is offline   Reply With Quote
Old 08-17-2010, 09:17 PM   #7
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
LTs and what else? stock cat back?
All the sound from the AFM stuff is dealt with in the giant stock resonators/x-pipe thingy. Go aftermarket catback after the LTs and it will drive you crazy.
If you want it off, tell your tuner to turn off DOD/AFM. Should be easy to do. I forget what it is called in HPTuners/EFI Live. I bet DSteck, Kirk, Monte, or RWTD knows... maybe they will chime in.
.....and maybe move the thread to the tuning section. Those guys know thier stuff.
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
Old 08-17-2010, 09:25 PM   #8
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
When I first put my LTs on I had it tuned w/ HPTuners to only come on in "D" in 5th & 6th gear only. In "S" mode it's all off.
With the handhelds like Diablo and SCT you can turn it off and on very quicky when you want but with HPTuners or EFI Live it can be done gear by gear...
I'm back to using my Diablo now with a Jannetty Custom tune to turn off the rear O2 sensor codes so AFM is just off now.
Now the title of this thread says AFM/DOD Delete which is a whole different subject.
Old 08-18-2010, 01:11 AM   #9
axis
Search Ninja
axis's Avatar
Not sure what you mean by doing nothing with the tune on it. Turning off DOD won't make it louder or quieter, it just won't go into DOD. FWIW, my gas mileage hasn't suffered at all. My average MPG with it on was a little over 18mpg and it's right at 18 with it off. This is with normal driving for a month on both settings.
Halltech CF 102 fed
Old 08-18-2010, 01:16 AM   #10
Indpowr
Drives: Corvette C6
Interesting points of view. I like it per gear...that is cool. Running 5th and 6th is nice option.
We have a true xpipe and Borla.
Old 08-18-2010, 02:17 AM   #11
AntzV
AntzV's Avatar
Drives: blacked out 2010 Camaro
If you can just have it tuned off, then you don't need the DOD delete kit some companies sell???
AntzV is offline   Reply With Quote
Old 08-18-2010, 05:31 AM   #12
axis
Search Ninja
axis's Avatar
No you don't but I think you're referring to the DOD lifter swap when doing a cam. The OEM DOD lifters don't play well with most of the cams out there. This is so you can run a more aggressive cam profile to gain more HP. I think every handheld along with HP tuners and such gives you the option to turn DOD off. There's no need to change parts if you're not changing cams.
Halltech CF 102 fed
Old 08-18-2010, 06:16 AM   #13
AntzV
AntzV's Avatar
O Ok thank you for explaining
Old 08-18-2010, 08:00 AM   #14
Indpowr
Drives: Corvette C6
Okay so no dod... good now focus on afm...lol
muffler delete with xpipe and no resonators, first imprseeions caper Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 07-05-2011 05:41 PM
ATAK compared to Muffler delete, decel. popping? defragme Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 12 07-24-2010 11:01 AM
LT header and muffler delete kbui USA - Texas 6 06-17-2010 06:39 PM
Muffler Delete with Dyno clips and pictures KK2010SS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 9 07-26-2009 03:09 PM
To muffler delete or not to delete BumbleBeeSS2009 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 81 06-25-2009 05:55 AM
