Old 09-08-2010, 02:07 PM   #1
shakenbk
Drives: 2011 RED LT/RS
Weird CEL
So I had a weird CEL experience. My cel turned on again and i only have k n n filter and slp exhaust and dt shorty headers. I installed my x pipe and it turned off? Is it normal for a cel to just disappear? It was on before the xpipe and on for about 50 miles then I started my car this morning it was gone.
2011 LT/RS A6
K&N CAI , Doug Thorley Shorty Headers , MagnaFlow True X-pipe , Flowtech Purple Hornies , SLP Loudmouth V.1 , Eibach Lowering Springs , Eibach Front and Rear Sways , Red Painted Brake Calipers
Future Mods - Sinister Ram Air Hood , Powder Coat Rims Black
shakenbk is offline   Reply With Quote
Old 09-08-2010, 03:11 PM   #2
jagan323
I have no life
jagan323's Avatar
Drives: 06' Subaru STI, ex-Camaro V6 LLT
Uh, whatever caused the CEL probably was fixed... it takes a couple miles before a fixed problem gets translated to the CEL naturally. Otherwise just have a ODBII scanner and remove the code... at least thats how I do it.
jagan323 is offline   Reply With Quote
Old 09-08-2010, 05:03 PM   #3
usa1camaro1969
Back on the dino-juice
usa1camaro1969's Avatar
Drives: '10 LS + a few more
You might've had an exhaust leak that was tightened up or sealed when the x-pipe was installed. Do you know what the code was by chance?
I wake up in the morning and I piss excellence.
-Ricky Bobby
America is all about speed. Hot, nasty, badass speed. -Eleanor Roosevelt, 1936
usa1camaro1969 is offline   Reply With Quote
Old 09-08-2010, 05:19 PM   #4
shakenbk
I didn't get a chance to go to autozone to check the code.. It seriously turned on 1 day before I put the xpipe on and turned off 1 day after it was installed .
2011 LT/RS A6
Old 09-08-2010, 05:21 PM   #5
Fishdadddy
Fishdadddy's Avatar
Drives: 2010 2SS/RS ; 1970 Firebird Formula
Exhaust leak
Fishdadddy is offline   Reply With Quote
Old 09-09-2010, 06:37 AM   #6
Mankind
Whats a Millwright?
Mankind's Avatar
Drives: 2LT/RS SIM, 05 Wht Denali
X-pipe is behind the sensors and should have absolutely no bearing on a CEL. Unless the battery was disconnected for the x-pipe install and that is what reset your computer. If so you will see it again after several miles. If it comes on again try to stop at the first Twilight Zone you can and let us know what the code is.
Mankind is offline   Reply With Quote
Doug Thorley Shorties and the dreaded CEL Merritt Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 25 09-11-2010 04:56 PM
JBA Hi-Flow Cats / Midpipes CEL Diesel Don Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 08-13-2010 06:23 PM
Clearing a CEL jtzako 5th Gen Camaro SS LS LT General Discussions 8 07-09-2010 01:37 PM
Weird dreams 2000v6 Off-topic Discussions 11 03-08-2010 04:14 PM
Weird Noise In the Rear On a 2SS camaro2011 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 22 02-22-2010 07:05 AM
