![]() Drives: Sinergy Limited Edition Join Date: Sep 2010
need the 3 fuse boxes wiring diagram
I need to make some modifications to legalize my car in Spain (add rear fog light and amber rear turn signals) becouse of this I need the 3 fuse boxes wiring diagram and the wiring diagram from the harness of tail lamps and headlamps,
thanks |
Doc
are the rear fog lights to be on at all times or only when backing up? Amber turn signals could also present a problem as the current housings are red transparent plastic.
1100-7/20/2009 * 6000-2/4/10 Proud Owner of Autographed Litho # 1282010 Camaro 2 SS/RS - BLACKOUT & 2017 Camaro 2 SS - 50th Anniversary #894 WWW. NY5THGEN.COM
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
Here is the harness of tail lamps and headlamps
http://www.camaro5.com/forums/showpo...52&postcount=3 |
#5 | |
so I can take wires from turn signal from the BCM (above the accelerator), I need to know what harness from the BCM (there are about 8 harnesses of diferent colors) and what wires are head and rear the turn signals |
| NON-RS TO RS WIRING DIAGRAM w/RUNNING LIGHTS | Bone | Cosmetics and Lighting Modification Discussions | 7 | 12-11-2010 08:10 AM |
| wiring diagram | Jason Imel | 5th Gen Camaro SS LS LT General Discussions | 3 | 06-16-2010 01:42 PM |
| Connector/Pin/Wire layout for under main fuse panel. | HeavyD | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 0 | 01-25-2010 07:31 PM |
| Group Buy - Custom Speaker Boxes, Amps, Subs (Updated post 25) | TAG UR IT | USA - Texas | 41 | 10-19-2009 09:56 PM |
| Anyone got a wiring diagram? | Super83Z | 4th Generation Camaros | 5 | 09-19-2009 04:52 PM |
