Old 09-13-2010, 02:41 PM   #1
ls3lsxz
Drives: black
Smile will LS3 heads hold the boost ??
i am in progress building LS3 forged internal with ls3 heads but
i am wondering
-do the ls3 head hold the high boost with the upgrading to LS9 gaskets and 12 points stud ?
-what is the maximum power at rwhp of those heads?
-the boost will be at 18psi .
here is my combo:
-Aluminum 6.2 Liters LS3 376 ci, stock LS3 heads and (GMPP single plane EFI).
-(stock crank 58x) ,Wiscopistons and Oliver rods
(compression is 9:2:0)
-Meziere electric water pump WP319.
-SLP Heavy duty oil pump.
-160 Thermostat.
-SLP Under drive pulley.
-Turbonitics TC78 mm .96 A/R (capable to achieve 1000HP) (soon will be changed to PTE88)
-JGS 50mm Wast gate
-JGS 60mm Blow Off Valve
-AMS 500 Boost controller
-AEM Wide band air/fuel.
-inter cooler:27"x12"x3" ,3" inlet & outlet
-MAFF less.
-Patriot gold valve springs 660" lift
-Custom Turbo cam 223/234 .600/.600 115 LSA cam .-Siemens fuel injectors 60lb
-Dual wallbro 255lb in tank.
-Nasty Custom fuel system for 1000 hp .
-Stage 3 TH400 transmission with Trans brake.
-8.8" ford differential.
-car weight is 2900lbs.
thanks
ls3lsxz is offline   Reply With Quote
Old 09-13-2010, 02:45 PM   #2
usmcjlp
Drives: 2SS/RS LS3 RJT
How did you get the weight to 2900lbs? Is the car completely stripped?
usmcjlp is offline   Reply With Quote
Old 09-13-2010, 03:10 PM   #3
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Those heads can be made to hold 18 psi of boost.
Here are some ideas that you may consider:
O-Ring the block (see pic 5 in this post)
http://www.camaro5.com/forums/showpo...4&postcount=13
Use "good" head gaskets and aircraft goop. This works well but in this case was used in conjunction with o-ringing the block.
http://www.camaro5.com/forums/showpo...5&postcount=93
P.S. You meant 3,900 pounds, correct ? Or maybe it is not a 2010, but some earlier/other body style.
Old 09-13-2010, 03:42 PM   #4
ls3lsxz
Drives: black
no the car is Nissan Datsun 1976 280z lol.. but has ls3 engine
Old 09-13-2010, 03:49 PM   #5
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
I'd like to see the chassis you are working with (i'm going to assume it's a notch/hatch back?). a 2900 lbs is pretty light, considering I'm assuming you have a 10 point chromemoly cage in it, because the setup you are looking at is a very easy 9 second car.
I wouldn't push 16 psi on a stock aluminum block/head with only a 4 bolt head. That's just me.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
danhr is offline   Reply With Quote
Old 09-13-2010, 03:58 PM   #6
ls3lsxz
Drives: black
it is really light car lol....
the stock with forged rods and pistons
Old 09-13-2010, 04:03 PM   #7
armysig
Catch me if you can
armysig's Avatar
Drives: 2012 IOM ZL-1
Goodness, you're creating a monster...
armysig is offline   Reply With Quote
Old 09-13-2010, 04:15 PM   #8
Bobby @ LG Motorsports
Bobby @ LG Motorsports's Avatar
Drives: 03 Cobra
You have answered your question several times on Corvette Forum.
Bobby @ LG Motorsports is offline   Reply With Quote
Old 09-13-2010, 05:12 PM   #9
ls3lsxz
Drives: black
man this is the first time i ask for this issue
Old 09-13-2010, 09:03 PM   #10
ADM PERFORMANCE
Drives: Anything I want
That is all we use...Made well over 1000
ADM PERFORMANCE is offline   Reply With Quote
Old 09-13-2010, 09:23 PM   #11
ls3lsxz
Drives: black
[QUOTE=ADM PERFORMANCE;2327051]That is all we use...Made well over 1000[/QUOTE
do you mean i can run these heads upto 1000rwhp?
Old 09-13-2010, 09:35 PM   #12
Mayhem Matt
Mayhem Matt's Avatar
Drives: 10' 2SS/RS M6 SUPERCHRGED BUMBLEBEE
Ordered Bumblebee 10/15/2008Part of the Family 6/11/2009 #11423
My Bumblebee to Superbee build story...http://www.camaro5.com/forums/showthread.php?t=105163
Superbee's 536hp Dyno Run...http://www.youtube.com/watch?v=AE7wePluPAc
Mayhem Matt is offline   Reply With Quote
Old 09-13-2010, 11:06 PM   #13
Blk_SS
Drives: black on black 2SS/RS
280z+ls swap= im in love , pic please
Blk_SS is offline   Reply With Quote
Old 09-14-2010, 02:42 AM   #14
VRMMMM
VRMMMM's Avatar
Drives: 2010 Camaro 2SS/RS LS3
Wow, I had a 76' 280z back in the day. great car, horrible brakes. Met lots of cute girls in that car ..
Detroit Speed springs and Sway bars, MGW short shifter, BMR upper and lower control arms, BMR bushings, Roto-Fab intake, Magnaflow exhaust, MTX factory sub, painted stripes, blacked out, recessed tail lights, Pedders sub frame bushings, more on the way
VRMMMM is offline   Reply With Quote
671 rwhp from LS3 with 8.4 psi of boost and EPP Blower Cam Exotic Performance Plus Forced Induction - V8 33 04-22-2011 10:22 PM
Coolingmist Methanol Injection systems, give your camaro a BOOST! coolingmist Forced Induction 63 11-20-2010 08:34 AM
LS3 and L99? black2black10 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 05-07-2010 01:58 AM
PRC CNC Ported LS3 Heads Going on the Engine Dyno Today!! Jason 98 TA Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 10-07-2009 06:33 PM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 02:00 PM
